Alex2jf
  1. @firepower I tried to replace the original BCM4334B0.hcd file with these two and bluetooth did not work with either file on my Vontar H618
  2. Thanks @Nick A Unfortunately, that's not it. There is only alsa, no installed pulseaudio and no pulseaudio conf file I'll answer myself - looks like the solution is: start alsamixer and unmute “Left Lineout Mux” and “Right Lineout mux” with the cursor keys.
  3. Is it possible to get stereo sound through LineOut? I used Nick A's 20241007 image to set up my Vontar H618 as an internet radio player with digital LED clock, controlled by IR remote, thanks to Nick A, MMorales and everyone on this topic. Everything works fine, except it plays mono. Is there any way to fix this? MPD is used as the player and I have tried different options in audio_output section on mpd.conf - no stereo, here the current working config: audio_output { type "alsa" name "My ALSA Device" device "hw:0,0" format "44000:16:2" mixer_type "software" mixer_device "plughw:audiocodec" mixer_control "digital volume" } By the way all the mixers are mono, here the result of "amixer scontext" command: Simple mixer control 'LINEOUT',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'LINEOUT volume',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 31 Mono: 22 [71%] Simple mixer control 'Left LINEOUT Mux',0 Capabilities: enum Items: 'LOMixer' 'LROMixer' Item0: 'LOMixer' Simple mixer control 'Left Output Mixer DACL',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left Output Mixer DACR',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right LINEOUT Mux',0 Capabilities: enum Items: 'ROMixer' 'LROMixer' Item0: 'ROMixer' Simple mixer control 'Right Output Mixer DACL',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Output Mixer DACR',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'digital volume',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 63 Mono: 0 [0%]
