27 -
@going okay deeper in the disconnecting to get wifi again if i reboot or shut down I need to plug in the lan cable remove usb the wifi is back up I tried by only removing the usb and plug it back in with out lan cable but then still no wifi its as if i need to add the lan cable then remove dongle then reinsert to get wifi back. I however don't need to go in to nmuti to connect again.
@going we have done it finally. wlx00e0372f872e: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.141 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fe80::5acf:cb45:6c14:ce63 prefixlen 64 scopeid 0x20<link> ether 00:e0:37:2f:87:2e txqueuelen 1000 (Ethernet) RX packets 100 bytes 14923 (14.9 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 112 bytes 11935 (11.9 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Dont know what it was but when i used nmuti I saw my wifi and network. thank you soooo much im very happy now. now if I can only restore android back to this box i still dont know how to convert the gz file to a img i managed to decompress it folder is showing 7.8gig so that I can install arbian on a mxq box because it has more usb ports again thannnnnnkkk youuuuuuu for all the patience
@going Im trying a method on the armbian forum as follows. I made the line bold that I should change to my version where can I find out. 4. For the USB dongle with RTL8188FTV : git clone https://github.com/kelebek333/rtl8188fu.git cd rtl8188fu we need to change some EXTRA_CFLAGS too and I think it is self explanatory, just add the missing lines, remove #: nano Makefile EXTRA_CFLAGS += -Wno-error=incompatible-pointer-types EXTRA_CFLAGS += -Wno-incompatible-pointer-types EXTRA_CFLAGS += -Wno-vla EXTRA_CFLAGS += -Wno-error=date-time (exit with ctrl+x) And now second difference form post above - we use different image so we have lib/modules/5.3.0-aml-g12 but we can use uname -r make ARCH=arm64 KSRC=../Amlogic_s905-kernel CONFIG_POWER_SAVING=n sudo install -p -m 644 rtl8188fu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless /sbin/depmod -a sudo modprobe rtl8188fu
this is the output of the 3 lines that you said i need to install this is the last deb line. johan@rk322x-box:~/debs$ sudo dpkg -i linux-image-edge-rockchip_24.11.0-trunk_ar mhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb (Reading database ... 175770 files and directories currently installed.) Preparing to unpack linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736- D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb ... Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'prerm' starting . Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'prerm' finishin g. Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' starti ng. Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' finish ing. Unpacking linux-image-edge-rockchip (24.11.0-trunk) over (24.11.0-trunk) ... Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postrm' startin g. Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postrm' finishi ng. Setting up linux-image-edge-rockchip (24.11.0-trunk) ... Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' start ing. * dkms: running auto installation service for kernel 6.11.4-edge-rockchip * dkms: autoinstall for kernel 6.11.4-edge-rockchip [ OK ] update-initramfs: Generating /boot/initrd.img-6.11.4-edge-rockchip W: Possible missing firmware /lib/firmware/mrvl/sdiouart8997_combo_v4.bin for bu ilt-in driver mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sdsd8997_combo_v4.bin for built- in driver mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8987_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sdiouartiw416_combo_v0.bin for b uilt-in driver mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sdsd8977_combo_v2.bin for built- in driver mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8887_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8897_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8801_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8797_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8787_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8786_uapsta.bin for built-in d river mwifiex_sdio W: Possible missing firmware /lib/firmware/rt73.bin for built-in driver rt73usb W: Possible missing firmware /lib/firmware/bfubase.frm for built-in driver bfusb W: Possible missing firmware /lib/firmware/intel/ibt-12-16.ddc for built-in driv er btintel W: Possible missing firmware /lib/firmware/intel/ibt-12-16.sfi for built-in driv er btintel W: Possible missing firmware /lib/firmware/intel/ibt-11-5.ddc for built-in drive r btintel W: Possible missing firmware /lib/firmware/intel/ibt-11-5.sfi for built-in drive r btintel W: Possible missing firmware /lib/firmware/mrvl/sdsd8997_combo_v4.bin for built- in driver btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8987_uapsta.bin for built-in d river btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sdsd8977_combo_v2.bin for built- in driver btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8897_uapsta.bin for built-in d river btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8887_uapsta.bin for built-in d river btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8797_uapsta.bin for built-in d river btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8787_uapsta.bin for built-in d river btmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8688.bin for built-in driver b tmrvl_sdio W: Possible missing firmware /lib/firmware/mrvl/sd8688_helper.bin for built-in d river btmrvl_sdio W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_config.bin for built -in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_fw_v2.bin for built- in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_fw.bin for built-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852btu_config.bin for buil t-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852btu_fw.bin for built-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852au_config.bin for built -in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852au_fw.bin for built-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8851bu_config.bin for built -in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8851bu_fw.bin for built-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821cs_config.bin for built -in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821cs_fw.bin for built-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821a_config.bin for built- in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821a_fw.bin for built-in d river btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761bu_config.bin for built -in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761bu_fw.bin for built-in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761b_config.bin for built- in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761b_fw.bin for built-in d river btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761a_config.bin for built- in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761a_fw.bin for built-in d river btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723d_config.bin for built- in driver btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723d_fw.bin for built-in d river btrtl W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723a_fw.bin for built-in d river btrtl update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.11.4-edge-rockchip Image Name: uInitrd Created: Tue Oct 22 21:03:27 2024 Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 14944180 Bytes = 14593.93 KiB = 14.25 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.11.4-edge-rockchip to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.11.4-edge-rockchip' update-initramfs: Armbian: done. Armbian: update last-installed kernel symlink to 'zImage'... '/boot/zImage' -> 'vmlinuz-6.11.4-edge-rockchip' Armbian: Debian compat: linux-update-symlinks install 6.11.4-edge-rockchip boot/vmlinuz-6.11.4-edge-rockchip Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' finishing.
@going Im still getting no such file directory when i run the first command in this instruction could that be the problem How to install sudo apt-get install build-essential git dkms linux-headers-$(uname -r) git clone https://github.com/kelebek333/rtl8188fu sudo dkms install ./rtl8188fu sudo cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/ Configuration Disable Power Management Run following commands for disable power management and plugging/replugging issues. sudo mkdir -p /etc/modprobe.d/ sudo touch /etc/modprobe.d/rtl8188fu.conf echo "options rtl8188fu rtw_power_mgnt=0 rtw_enusbss=0 rtw_ips_mode=0" | sudo tee /etc/modprobe.d/rtl8188fu.conf Disable MAC Address Spoofing Run following commands for disabling MAC Address Spoofing (Note: This is not needed on Ubuntu based distributions. MAC Address Spoofing is already disable on Ubuntu base). sudo mkdir -p /etc/NetworkManager/conf.d/ sudo touch /etc/NetworkManager/conf.d/disable-random-mac.conf echo -e "[device]\nwifi.scan-rand-mac-address=no" | sudo tee /etc/NetworkManager/conf.d/disable-random-mac.conf Blacklist (alias) for kernel 5.15 and 5.16 (No needed for kernel 5.17 and up) If you are using kernel 5.15 and 5.16, you must create a configuration file with following command for preventing to conflict rtl8188fu module with built-in r8188eu module. echo 'alias usb:v0BDApF179d*dc*dsc*dp*icFFiscFFipFFin* rtl8188fu' | sudo tee /etc/modprobe.d/r8188eu-blacklist.conf Blacklist (alias) for kernel 6.2 and up If you are using kernel 6.2 and up, you must create a configuration file with following command for preventing to conflict rtl8188fu module with built-in rtl8xxxu module. echo 'alias usb:v0BDApF179d*dc*dsc*dp*icFFiscFFipFFin* rtl8188fu' | sudo tee /etc/modprobe.d/rtl8xxxu-blacklist.conf Then you must update initramfs For initramfs sudo update-initramfs -u For dracut sudo dracut -q --force Enable rtl8188fu module how do I install these drivers for my wifi chip https://github.com/kelebek333/rtl8188fu
@going out put off the command: johan@rk322x-box:~$ sudo apt-get install build-essential git dkms Reading package lists... Done Building dependency tree... Done Reading state information... Done build-essential is already the newest version (12.10ubuntu1). git is already the newest version (1:2.43.0-1ubuntu7.1). dkms is already the newest version (3.0.11-1ubuntu13). 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. johan@rk322x-box:~$
@going okay okay what am I doing why cant I get this im thinking of quitting. But thats not me managed to run dpkg and this was the outcome. FINISHED --2024-10-22 20:22:13-- Total wall clock time: 37s Downloaded: 12 files, 40M in 32s (1.26 MB/s) johan@rk322x-box:~/debs$ mkdir debs johan@rk322x-box:~/debs$ mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ johan@rk322x-box:~/debs$ rm -rf fi.mirror.armbian.de johan@rk322x-box:~/debs$ ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~/debs$ cd debs johan@rk322x-box:~/debs/debs$ sudo dpkg -i linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Selecting previously unselected package linux-headers-edge-rockchip. (Reading database ... 152034 files and directories currently installed.) Preparing to unpack linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb ... Armbian 'linux-headers-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' starting. Armbian 'linux-headers-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' finishing. Unpacking linux-headers-edge-rockchip (24.11.0-trunk) ... Setting up linux-headers-edge-rockchip (24.11.0-trunk) ... Armbian 'linux-headers-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' starting. Compiling kernel-headers tools (6.11.4-edge-rockchip) using 4 CPUs - please wait ... HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/confdata.o HOSTCC scripts/kconfig/expr.o LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/menu.o HOSTCC scripts/kconfig/parser.tab.o HOSTCC scripts/kconfig/preprocess.o HOSTCC scripts/kconfig/symbol.o HOSTCC scripts/kconfig/util.o HOSTLD scripts/kconfig/conf * * Restart config... * * * Kernel Features * Symmetric Multi-Processing (SMP) [Y/n/?] y Allow booting SMP kernel on uniprocessor systems (SMP_ON_UP) [Y/n/?] y Support cpu topology definition (ARM_CPU_TOPOLOGY) [Y/n/?] y Multi-core scheduler support (SCHED_MC) [N/y/?] n SMT scheduler support (SCHED_SMT) [N/y/?] n Architected timer support (HAVE_ARM_ARCH_TIMER) [Y/?] y Multi-Cluster Power Management (MCPM) [N/y/?] n big.LITTLE support (Experimental) (BIG_LITTLE) [N/y/?] n Memory split 1. 3G/1G user/kernel split (VMSPLIT_3G) > 2. 3G/1G user/kernel split (for full 1G low memory) (VMSPLIT_3G_OPT) 3. 2G/2G user/kernel split (VMSPLIT_2G) 4. 1G/3G user/kernel split (VMSPLIT_1G) choice[1-4?]: 2 Maximum number of CPUs (2-32) (NR_CPUS) [4] 4 Support for hot-pluggable CPUs (HOTPLUG_CPU) [Y/?] y Support for the ARM Power State Coordination Interface (PSCI) (ARM_PSCI) [Y/n/?] y Timer frequency 1. 100 Hz (HZ_100) 2. 200 Hz (HZ_200) > 3. 250 Hz (HZ_250) 4. 300 Hz (HZ_300) 5. 500 Hz (HZ_500) 6. 1000 Hz (HZ_1000) choice[1-6?]: 3 Compile the kernel in Thumb-2 mode (THUMB2_KERNEL) [N/y/?] n Runtime patch udiv/sdiv instructions into __aeabi_{u}idiv() (ARM_PATCH_IDIV) [Y/n/?] y High Memory Support (HIGHMEM) [Y/n/?] y Allocate 2nd-level pagetables from highmem (HIGHPTE) [N/y/?] n Enable privileged no-access (ARM_PAN) [Y/n/?] y Use PLTs to allow module memory to spill over into vmalloc area (ARM_MODULE_PLTS) [Y/n/?] y Order of maximal physically contiguous allocations (ARCH_FORCE_MAX_ORDER) [11] 11 Use kernel mem{cpy,set}() for {copy_to,clear}_user() (UACCESS_WITH_MEMCPY) [N/y/?] n Enable paravirtualization code (PARAVIRT) [N/y/?] n Paravirtual steal time accounting (PARAVIRT_TIME_ACCOUNTING) [N/y/?] n Xen guest support on ARM (XEN) [N/y/?] n Use a unique stack canary value for each task (STACKPROTECTOR_PER_TASK) [Y/n/?] (NEW) * * Memory initialization * Initialize kernel stack variables at function entry > 1. no automatic stack variable initialization (weakest) (INIT_STACK_NONE) 2. pattern-init everything (strongest) (INIT_STACK_ALL_PATTERN) (NEW) 3. zero-init everything (strongest and safest) (INIT_STACK_ALL_ZERO) (NEW) choice[1-3?]: Enable heap memory zeroing on allocation by default (INIT_ON_ALLOC_DEFAULT_ON) [N/y/?] n Enable heap memory zeroing on free by default (INIT_ON_FREE_DEFAULT_ON) [N/y/?] n Enable register zeroing on function exit (ZERO_CALL_USED_REGS) [N/y/?] n # # configuration written to .config # SYNC include/config/auto.conf.cmd HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.[ch] HOSTCC scripts/dtc/libfdt/fdt.o HOSTCC scripts/dtc/libfdt/fdt_ro.o HOSTCC scripts/dtc/libfdt/fdt_wip.o HOSTCC scripts/dtc/libfdt/fdt_sw.o HOSTCC scripts/dtc/libfdt/fdt_rw.o HOSTCC scripts/dtc/libfdt/fdt_strerror.o HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o HOSTCC scripts/dtc/libfdt/fdt_addresses.o HOSTCC scripts/dtc/libfdt/fdt_overlay.o HOSTCC scripts/dtc/fdtoverlay.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/fdtoverlay HOSTLD scripts/dtc/dtc HOSTCC scripts/kallsyms HOSTCC scripts/sorttable HOSTCC scripts/asn1_compiler CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/devicetable-offsets.s UPD scripts/mod/devicetable-offsets.h MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/file2alias.o HOSTCC scripts/mod/sumversion.o HOSTCC scripts/mod/symsearch.o HOSTLD scripts/mod/modpost MODPOST scripts/mod/Module.symvers Done compiling kernel-headers tools (6.11.4-edge-rockchip). Done compiling kernel-headers tools (6.11.4-edge-rockchip). And this is still my output johan@rk322x-box:~$ sudo apt-get install build-essential git dkms linux-headers-$(uname -r) git clone https://github.com/kelebek333/rtl8188fu sudo dkms install ./rtl8188fu sudo cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/ [sudo] password for johan: Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-headers-6.11.0-edge-rockchip E: Couldn't find any package by glob 'linux-headers-6.11.0-edge-rockchip' E: Couldn't find any package by regex 'linux-headers-6.11.0-edge-rockchip' fatal: destination path 'rtl8188fu' already exists and is not an empty directory. Error! Your kernel headers for kernel 6.11.0-edge-rockchip cannot be found at /lib/modules/6.11.0-edge-rockchip/build or /lib/modules/6.11.0-edge-rockchip/source. Please install the linux-headers-6.11.0-edge-rockchip package or use the --kernelsourcedir option to tell DKMS where it's located.
@going Thank you so much for the indepth explanation I will gove it a go tonight again. My level of linux especially command is very beginners I have always just used linux to install klipper for my 3d printers but I do believe with time it will come and I will understand it. I have been a Windows user all my life and this is a whole new venture
@MaxT thank you this helped: But seems there's a conflict of interest see output johan@rk322x-box:~/debs$ sudo dpkg -i linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: regarding linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb containing linux-libc-dev-edge-rockchip:armhf: linux-libc-dev-edge-rockchip conflicts with linux-libc-dev linux-libc-dev:armhf (version 6.8.0-47.47) is present and installed. dpkg: error processing archive linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb (--install): conflicting packages - not installing linux-libc-dev-edge-rockchip:armhf Errors were encountered while processing: linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb
@Werner @going Hi buddy i have done the exactly line by line that you have said I should run. however im stuck at the last part where I should run sudo dpkg -i it says no such file or directory. see terminal output. FINISHED --2024-10-22 14:17:35-- Total wall clock time: 1m 54s Downloaded: 12 files, 40M in 1m 48s (380 KB/s) johan@rk322x-box:~$ mkdir debs mkdir: cannot create directory ‘debs’: File exists johan@rk322x-box:~$ mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ mv: replace 'debs/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb', overriding mode 0644 (rw-r--r--)? mv: replace 'debs/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb', overriding mode 0644 (rw-r--r--)? yes mv: replace 'debs/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb', overriding mode 0644 (rw-r--r--)? ^C johan@rk322x-box:~$ rm -rf fi.mirror.armbian.de johan@rk322x-box:~$ ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb [sudo] password for johan: dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory
@going Im sure by now when you see a notification you dont even want to open it but please bare with me I have tried to google but nothing came up. once I understand this I will get it right next time. wget is running and download 12 file is says it saving them in a temp folder see output in console I tried to cd in it but says no such file directory I really want to install the headers to get the wifi up and running please look at the complete terminal and tell me what and where im doing it wrong. im further than a while back but stuck at sudo dpkg -i file name johan@rk322x-box:~$ sudo wget -r -l 1 --accept=deb -np https://fi.mirror.armbian.de/.testing/rk322x-box [sudo] password for johan: --2024-10-21 19:57:49-- https://fi.mirror.armbian.de/.testing/rk322x-box Resolving fi.mirror.armbian.de (fi.mirror.armbian.de)... 65.21.120.247, 2a01:4f9:3b:4943::2 Connecting to fi.mirror.armbian.de (fi.mirror.armbian.de)|65.21.120.247|:443... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://fi.mirror.armbian.de/.testing/rk322x-box/ [following] --2024-10-21 19:57:50-- https://fi.mirror.armbian.de/.testing/rk322x-box/ Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box.tmp’ fi.mirror.armbian.de/.testing/rk322x-box. [ <=> ] 3.12K --.-KB/s in 0s 2024-10-21 19:57:50 (6.66 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box.tmp’ saved [3200] Loading robots.txt; please ignore errors. --2024-10-21 19:57:50-- https://fi.mirror.armbian.de/robots.txt Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 404 Not Found 2024-10-21 19:57:51 ERROR 404: Not Found. Removing fi.mirror.armbian.de/.testing/rk322x-box.tmp since it should be rejected. --2024-10-21 19:57:51-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=N&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.12K --.-KB/s in 0s 2024-10-21 19:57:51 (7.84 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp’ saved [3200] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=A.tmp since it should be rejected. --2024-10-21 19:57:51-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=N&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0.001s 2024-10-21 19:57:51 (5.13 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=N&O=D.tmp since it should be rejected. --2024-10-21 19:57:51-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=S&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0.001s 2024-10-21 19:57:52 (5.31 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=A.tmp since it should be rejected. --2024-10-21 19:57:52-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=S&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 19:57:52 (7.51 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=S&O=D.tmp since it should be rejected. --2024-10-21 19:57:52-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=M&O=A Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 19:57:52 (6.13 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=A.tmp since it should be rejected. --2024-10-21 19:57:52-- https://fi.mirror.armbian.de/.testing/rk322x-box/?C=M&O=D Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp’ fi.mirror.armbian.de/.testing/rk322x-box/ [ <=> ] 3.14K --.-KB/s in 0s 2024-10-21 19:57:53 (9.37 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp’ saved [3212] Removing fi.mirror.armbian.de/.testing/rk322x-box/index.html?C=M&O=D.tmp since it should be rejected. --2024-10-21 19:57:53-- https://fi.mirror.armbian.de/.testing/ Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: unspecified [text/html] Saving to: ‘fi.mirror.armbian.de/.testing/index.html.tmp’ fi.mirror.armbian.de/.testing/index.html. [ <=> ] 8.95K --.-KB/s in 0.001s 2024-10-21 19:57:53 (17.4 MB/s) - ‘fi.mirror.armbian.de/.testing/index.html.tmp’ saved [9168] Removing fi.mirror.armbian.de/.testing/index.html.tmp since it should be rejected. --2024-10-21 19:57:53-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 135680 (132K) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 132.50K 185KB/s in 0.7s 2024-10-21 19:57:54 (185 KB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [135680/135680] --2024-10-21 19:57:54-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 14350648 (14M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 13.69M 2.25MB/s in 10s 2024-10-21 19:58:04 (1.34 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [14350648/14350648] --2024-10-21 19:58:04-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 26321596 (25M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 25.10M 3.11MB/s in 8.7s 2024-10-21 19:58:13 (2.88 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [26321596/26321596] --2024-10-21 19:58:13-- https://fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb Reusing existing connection to fi.mirror.armbian.de:443. HTTP request sent, awaiting response... 200 OK Length: 1348720 (1.3M) [application/octet-stream] Saving to: ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ fi.mirror.armbian.de/.testing/rk322x-box/ 100%[=====================================================================================>] 1.29M 3.35MB/s in 0.4s 2024-10-21 19:58:14 (3.35 MB/s) - ‘fi.mirror.armbian.de/.testing/rk322x-box/linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb’ saved [1348720/1348720] FINISHED --2024-10-21 19:58:14-- Total wall clock time: 25s Downloaded: 12 files, 40M in 20s (2.01 MB/s) johan@rk322x-box:~$ sudo mkdir debs mkdir: cannot create directory ‘debs’: File exists johan@rk322x-box:~$ sudo mv fi.mirror.armbian.de/.testing/rk322x-box/* debs/ johan@rk322x-box:~$ sudo rm -rf fi.mirror.armbian.de johan@rk322x-box:~$ sudo ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$ sudo dpkg -i linux-headers-edge-rockchip_24.11.0-trunk_armhf __6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$ ls debs linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-headers-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H 5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb linux-libc-dev-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb johan@rk322x-box:~$ sudo dpkg -i linux-dtb-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb dpkg: error: cannot access archive 'linux-dtb-edge-rockchip_24.11.0-trunk_armhf _6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb': No such file or directory johan@rk322x-box:~$
