oqewipobin
  1. Looks like installing/reinstalling the Radxa provided packages for aic8800 (https://github.com/radxa-pkg/aic8800/releases) kernel modules AFTER the kernel update makes the WiFi module work again.
  2. I'm having an issue where the prebuilt images dowloaded from https://www.armbian.com/radxa-rock-5c/ (released on Oct 12, 2024) works fine, including WiFi connectivity, even after reboots, but the moment I updgrade the packages (apt update && apt upgrade) and reboot the system, the WiFi network interface (wlan0) simply disappears and can I no longer search or connect to any wireless network.I've flashed both Bookworm Minimal/IOT and Server/CLI Bookworm, e the issue always occur after upgradin packages. the wlan0 does not appear on iwctl neither ip address commands, but the device (AIC Wlan) still appears on lsusb command: $ lsusb Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 004: ID a69c:8d80 aicsemi AIC Wlan Bus 005 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub armbianmonitor output: https://paste.armbian.com/oqewipobin I don't know if there is an issue with the newest kernel update, or if there is some overlay or kernel module for the AIC Wlan chip that is being erased/disabled during the kernel update process. Is there something I can try to reenable the wlan0 interface? or is it just a bronken update?
