Everything come from a try to create a docker compose project. Armbian 24.8.4 bookworm on OrangePI zero 2 - Network forwarding doesn't work:
version: '3.6'
services:
db:
image: mariadb:10.3
environment:
MYSQL_ROOT_PASSWORD: secret
phpmyadmin:
image: phpmyadmin
restart: always
ports:
- 8080:80
environment:
- PMA_HOSTS=db
=> FROM test-db-1 => test-db-1 3306
docker exec -ti test-db-1 bash -c 'timeout 0.5 echo -n 2>/dev/null < /dev/tcp/test-db-1/3306 && echo "open" || echo "closed"'
open
=> FROM test-phpmyadmin-1 => test-db-1 3306
docker exec -ti test-phpmyadmin-1 bash -c 'timeout 0.5 echo -n 2>/dev/null < /dev/tcp/test-db-1/3306 && echo "open" || echo "closed"'
closed
lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Armbian 24.8.4 bookworm
Release: 12
Codename: bookworm
uname -a
Linux xxxxxx-pre 6.6.44-current-sunxi64 #1 SMP Sat Aug 3 06:54:42 UTC 2024 aarch64 GNU/Linux
OrangePI Zero v2
### How to reproduce?
ip -4 addr show scope global
2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
inet 192.168.1.135/24 metric 100 brd 192.168.1.255 scope global dynamic end0
valid_lft 587718sec preferred_lft 587718sec
cat /proc/sys/net/ipv4/ip_forward
1
iptables -A PREROUTING -t nat -i lo -p udp --dport 2222 -j DNAT --to 127.0.0.1:22
iptables -A PREROUTING -t nat -i lo -p tcp --dport 2222 -j DNAT --to 127.0.0.1:22
iptables -A FORWARD -p tcp -d 127.0.0.1 --dport 2222 -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
iptables -A FORWARD -m limit --limit 3/minute --limit-burst 3 -j LOG --log-prefix "IPT FORWARD packet"
iptables -A POSTROUTING -t nat -j MASQUERADE -o lo
iptables -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
iptables -A INPUT -j ACCEPT
iptables -A OUTPUT -j ACCEPT
iptables -A FORWARD -j ACCEPT
ssh -l root -p 22 localhost => OK
ssh -l root -p 2222 localhost => KO
iptables -A PREROUTING -t nat -i end0 -p udp --dport 2222 -j DNAT --to 192.168.1.135:22
iptables -A PREROUTING -t nat -i end0 -p tcp --dport 2222 -j DNAT --to 192.168.1.135:22
iptables -A FORWARD -p tcp -d 192.168.1.135 --dport 2222 -m state --state NEW,ESTABLISHED,RELATED -j ACCEPT
iptables -A POSTROUTING -t nat -j MASQUERADE -o end0
ssh -l root -p 22 192.168.1.135 => OK
ssh -l root -p 2222 192.168.1.135 => KO
### Branch
main (main development branch)
### On which host OS are you running the build script and observing this problem?
Ubuntu 24.04 Noble
### Are you building on Windows WSL2?
- [ ] Yes, my Ubuntu/Debian/OtherOS is running on WSL2
### Relevant log URL
_No response_
### Code of Conduct
- [X] I agree to follow this project's Code of Conduct
