Lucas Vasconcelos
  1. I'm experiencing the same issue on my Orange Pi 5 running Armbian 25.11.2 noble (Ubuntu 24.04). Error: E: The repository 'http://apt.armbian.com noble Release' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. What I've tried: Downloaded and installed the armbian.key multiple times: wget https://apt.armbian.com/armbian.key gpg --dearmor < armbian.key sudo tee /usr/share/keyrings/armbian.gpg > /dev/null sudo chmod go+r /usr/share/keyrings/armbian.gpg Copied the key to both locations: sudo cp /usr/share/keyrings/armbian.gpg /etc/apt/trusted.gpg.d/armbian.gpg Configured the repository using both .list and .sources formats The problem: The repository keeps redirecting to different mirrors (armbian.atomonetworks.com, armbian.lv.auroradev.org, etc.) and none of them have valid InRelease or Release.gpg files: $ curl -I https://armbian.atomonetworks.com/apt/dists/noble/InRelease HTTP/2 404 Workaround: The github.armbian.com/configng repository works fine, but the main apt.armbian.com repository appears to have infrastructure issues with signature files missing on all mirrors. Is this a known issue? System info: Distribution: Armbian 25.11.2 noble Ubuntu version: 24.04 LTS Architecture: arm64 Device: Orange Pi 5
  2. Unfortunately I couldn't find a solution for the WiFi issue. It really doesn't work 😢
  3. Guys, I'm back to give my feedback on how I managed to solve the problem. First, I couldn't solve it using the official Armbian images, I used an alternative image from the "amlogic-s9xxx-armbian" project maintained by ophub on GitHub. In this project I used the version for the SOC s905l3a, more specifically the image "amlogic_s905l3a.img". After using this specific image, I created the bootable SDCard, and then I inserted it into the box and used the remote control to be able to boot, you need to click the right arrow button while the box starts. After that I was able to use the system directly from the SDCard, most things worked well, I just couldn't install the system on the internal memory, I had to continue using it directly from the SDCard. From my research, this box is nothing more than a modified Chinese router, the router would be the e900v22c. It was by researching it that I was able to understand the procedure to install Armibian.
  4. Do you have any other suggestions for methods I could try?
  5. Let me explain why I took this approach. On my board, I couldn’t find any reset button, either near the AV port or in any small hole. The only button my TV Box has is the power button (on/off). So, I saw the option to use the su reboot reset command in a YouTube video. I also couldn’t use the update option through the Android app because the boot partition of the USB drive or SSD doesn’t show up in Android. After researching a bit more, I believe my TV Box is very similar to the E900V22D-2. I think it has an S905L3A chip, with 2GB of RAM and 8GB of storage.
  6. Hello everyone, good morning! I own a Super Console X2 Pro (https://a.aliexpress.com/_mNgWh7z) and I am trying to install Armbian on it to use it as a server. I followed the tutorial from the forum, but I can't get it to boot into Armbian: To attempt the boot, I am using an Android terminal app with the command: su reboot update But it always goes to the recovery screen. I also tried through the update app, but the USB drives or SD cards I used do not appear in the Android TV Box, even though their folders show up in the recovery menu. I am attaching screenshots of all the information I found relevant to solving the problem, and I am willing to provide more if needed. One note is that the chip is labeled S905L, even though the advertisement claims it's an S905X2, and the hardware verification app also indicates S905X2. I tried using the Server images with Armbian Linux v6.6 for Ubuntu. I am eager to make this work, and I appreciate any help from you all.
