I have done a flat install of "Armbian 24.11.2 Bookworm Minimal" but for some reason it keeps failing to update. I get the following output and I can ping the IP address but when I try to follow the http address it show s a 404 error in the browser.
Is there something I am missing as I have tried to fix it but not sure if its just me or everyone is getting this as the file is missing to download.
root@orangepi5-plus:~# apt update
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://deb.debian.org/debian bookworm-backports InRelease
Get:5 https://github.armbian.com/configng stable InRelease [3,264 B]
Hit:6 http://armbian.tnahosting.net/apt bookworm InRelease
Fetched 3,264 B in 1s (2,240 B/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
root@orangepi5-plus:~# apt upgrade
Calculating upgrade... Done
The following packages will be upgraded:
armbian-config
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 116 kB of archives.
After this operation, 715 kB disk space will be freed.
Do you want to continue? [Y/n] y
Err:1 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.2.0-trunk.103.1129.130128
404 Not Found [IP: 185.199.111.153 443]
E: Failed to fetch https://github.armbian.com/configng/pool/main/a/armbian-config/armbian-config_25.2.0-trunk.103.1129.130128_all.deb 404 Not Found [IP: 185.199.111.153 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
