mm2189
  1. Hello brent, have you got a hint, on how it could be done? Best regards Manuel
  2. Hello! Is there a possibility to change the default LED0 behaviour of the RTL8201F PHY? Here is the Datasheet: https://file.elecfans.com/web1/M00/99/0F/o4YBAF0VytaAI7ezABH66fmIRIg854.pdf?filename=RTL8201F-VB-CG.pdf And this is the relevant register: It states, that "11" is the default - but I think it is changed to "00" during driver initialization - is that possible? I would like to change it to "01" - is this somehow possible without recompiling the driver? Thank you! Best regards, Manuel
  3. Hello, I can confirm, that I have the same problem as you, I am using the latest Armbian 24.11.1 and the overlay files are not applied (checked with proc/device-tree) Unfortunately I don't have any solution for that - if I've found one, I will write this into your Thread.
