ga6
  1. It's easy to enable For example, in the r2s options, the “current” option means installing the 6.12 kernel. And according to the content of `config/boards/nanopi-r2s.csc` file, the dts file is `rk3328-nanopi-r2-rev00.dts`. Then go to `patch/kernel/archive/rockchip64-6.12/dt/` and modify the file `rk3328-nanopi-r2-rev00.dts`. // If you want to enable eMMC, find the following &emmc { status = "disabled"; }; // Modified to &emmc { status = "okey"; }; By the way If you want to enable sdio wifi, follow these // find the following &sdmmc_ext { status = "disabled"; }; &sdio_pwrseq { status = "disabled"; }; // Modified to &sdmmc_ext { vmmc-supply = <&vcc_io>; vqmmc-supply = <&vcc_18>; max-frequency = <150000000>; sd-uhs-sdr104; status = "okay"; /delete-node/ bcrmf@1; rtl8822cs@1 { reg = <1>; compatible = "realtek,rtl8822cs"; }; }; &sdmmc0ext_clk { rockchip,pins = <3 RK_PA2 3 &pcfg_pull_none_8ma>; }; &sdmmc0ext_cmd { rockchip,pins = <3 RK_PA0 3 &pcfg_pull_up_8ma>; }; &sdmmc0ext_bus4 { rockchip,pins = <3 RK_PA4 3 &pcfg_pull_up_8ma>, <3 RK_PA5 3 &pcfg_pull_up_8ma>, <3 RK_PA6 3 &pcfg_pull_up_8ma>, <3 RK_PA7 3 &pcfg_pull_up_8ma>; }; &sdio_pwrseq { status = "okay"; }; Finally, just recompile.
