wite_k
  1. Great news, thanks! I wasn't able to download u-boot from the links that you provided so I build it myself and "dd" it to sdcard. For some reason that particular kernel that caused this problem isn't available in apt repository, but that doesn't matter for now. At least I know that during next upgrade it'll work.
  2. Hello, After upgrading helios4 I encountered this problem after rebooting: U-Boot SPL 2019.04-armbian (Jul 03 2024 - 12:20:37 +0000) High speed PHY - Version: 2.0 Detected Device ID 6828 board SerDes lanes topology details: | Lane # | Speed | Type | -------------------------------- | 0 | 6 | SATA0 | | 1 | 5 | USB3 HOST0 | | 2 | 6 | SATA1 | | 3 | 6 | SATA3 | | 4 | 6 | SATA2 | | 5 | 5 | USB3 HOST1 | -------------------------------- High speed PHY - Ended Successfully mv_ddr: mv_ddr-armada-18.09.2 DDR3 Training Sequence - Switching XBAR Window to FastPath Window DDR Training Sequence - Start scrubbing DDR3 Training Sequence - End scrubbing mv_ddr: completed successfully Trying to boot from MMC1 U-Boot 2019.04-armbian (Jul 03 2024 - 12:20:37 +0000) SoC: MV88F6828-A0 at 1600 MHz DRAM: 2 GiB (800 MHz, 32-bit, ECC enabled) MMC: mv_sdh: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** Model: Helios4 Board: Helios4 SCSI: MVEBU SATA INIT Target spinup took 0 ms. SATA link 1 timeout. AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode flags: 64bit ncq led only pmp fbss pio slum part sxs Net: Warning: ethernet@70000 (eth1) using random MAC address - e2:6d:a3:83:7f:e1 eth1: ethernet@70000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2996 bytes read in 381 ms (6.8 KiB/s) ## Executing script at 03000000 Boot script loaded from mmc 158 bytes read in 369 ms (0 Bytes/s) 28834 bytes read in 691 ms (40 KiB/s) 11165487 bytes read in 2303 ms (4.6 MiB/s) 8551104 bytes read in 1847 ms (4.4 MiB/s) Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... starting USB... USB0: MVEBU XHCI INIT controller @ 0xf10f4000 Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: MVEBU XHCI INIT controller @ 0xf10fc000 Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: device type unknown ... is now current device I guess the most important part is this: Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... This happened when linux-image was upgraded from 24.11.0-trunk.403 to 25.2.0-trunk.316 (25.2.0-trunk.343 doesn't work either). To get it working again I unpacked previous kernel and I'm back to 24.11.0-trunk.403. I noticed that this topic has similar problem. I still got some ideas about how to debug this but I before that I wanted to ask if anyone has encountered this on this board? Did the initrd changed format during upgrade and I have to upgrade uboot (I noticed that FORCE_UBOOT_UPDATE is set to null so I guess installing linux-u-boot-helios4-current_25.2.0-trunk.316_armhf.deb doesn't dd bootloader onto sdcard. Thanks in advance!
