robertM
  1. awesome: login screen now -> thx!!
  2. sorry for late reply. here is the output - thx armbian-config/unbekannt,unbekannt,jammy,jammy,jammy,now 25.8.0-trunk.380.0718.155006 all [installiert] armbian-firmware/jammy,jammy,jammy,now 25.5.2 all [installiert] armbian-plymouth-theme/jammy,jammy,jammy,now 25.5.2 all [installiert] armbian-zsh/jammy,jammy,jammy,now 25.5.2 all [installiert] chromium/jammy,now 9:126.0.6478.182-1~deb12u1+j1armbian1 arm64 [installiert]
  3. well I "solved" the package conflict but now on boot it shows: Welcome to 22.11.2 with Linux 6.1.115-vendor-rk35xx before it showed: Welcome to Armbian 24.5.1 Jammy everything works though - no pending updates. I guess I will leave it like this. Or any recommendations about getting it up to current version?
  4. I was able to get the conflicting versions fixed: now:
  5. I am Running Armbian 24.5.1 Jammy with Linux 6.1.115-vendor-rk35xx on Radxa Rock5b (and it works great!!) when running sudo apt dist-upgrade or sudo apt upgrade I get Die folgenden Pakete sind zurückgehalten worden: armbian-bsp-cli-rock-5b " Packages retained" apt list --installed | grep armbian-bsp-cli-rock-5b gives: armbian-bsp-cli-rock-5b-legacy/jammy,now 24.5.1 arm64 [installiert] armbian-bsp-cli-rock-5b/jammy,now 24.5.1 arm64 [Installiert,aktualisierbar auf: 25.5.1] ## installed, can be updated can/shall I force the the use of "armbian-bsp-cli-rock-5b/jammy,now 24.5.1 arm64 [Installiert,aktualisierbar auf: 25.5.1]" ? how? what is the correct procedure to update to 25.5.x? thanks
  6. Hello. I am getting similar error messages: Radxa Rock5 Armbian 24.5.1 Jammy with Linux 5.10.110-rockchip-rk3588 Es wurden 111 MB in 2 s geholt (49,2 MB/s). E: Fehlschlag beim Holen von http://apt.armbian.com/pool/main/a/armbian-firmware/armbian-firmware_25.2.1_all__1-SAe75d-B6c7f-R448a.deb Datei hat eine unerwartete Größe (91589632 != 91589640). Eventuell läuft gerade eine Spiegel-Synchronisierung? [IP: 62.133.35.14 80] E: Fehlschlag beim Holen von http://apt.armbian.com/pool/main/a/armbian-plymouth-theme/armbian-plymouth-theme_25.2.1_all__1-Bfe25-R448a.deb Datei hat eine unerwartete Größe (108120 != 108124). Eventuell läuft gerade eine Spiegel-Synchronisierung? [IP: 130.225.254.116 80] E: Fehlschlag beim Holen von http://apt.armbian.com/pool/main/a/armbian-zsh/armbian-zsh_25.2.1_all__1-SAbfee-B6e0d-R448a.deb Datei hat eine unerwartete Größe (10829720 != 10829716). Eventuell läuft gerade eine Spiegel-Synchronisierung? [IP: 130.225.254.116 80] E: Einige Archive konnten nicht herunt
