18 -
Radxa 5B Plus - Microphone Audio Jack support
Erez Alster replied to Erez Alster's topic in Radxa Rock 5B
Hi Any Idea how to solve it? What is the process for premium support? -
Hi All I'm trying to use a microphone using the audiojack connector but without any success. Any help around that? I tried to search in the forum but didn't find any useful information regarding Radxa 5B Plus Thanks Erez
Can you tell me how I'm able to enable PWM? I'm not able to see any of them in the armbian-config overlay management
The hdmirx is covered in different thread. I will continue there
I was able to make things work. i had bad configuration So everything is working correctly. I've another issue. I've the following errors in dmesg Something I'm able to use the HDMI input and sometimes i'm not. Any idea what can be the issue?
I'm using the gpio cli. nothing else worked for me
I'm not complaining at all.... I'm wondering how I can debug it. I'm able to use the same device tree with the official orange pi os.
yes. I copied the dtb from orange pi 5 ultra official image and copied it.
Hi I'm trying to use Armbian with Orange pi 5 Ultra. So far so good The hdmirx is working great! I'm not able to control my gpio pins with PWM in equivalent to orange pi 5 ultra image. I guess that i need to load additional overlays, Am I correct? Please review the armbian logs here: https://paste.next.armbian.com/nekodihico I also noticed that pin numbers were changed if I compare it to the Orange pi OS. Thanks in advance!
Orange Pi 5 Ultra Support
Erez Alster replied to Erez Alster's topic in Framework and userspace feature requests
My main issue with RPI5 is the lack of hardware video encoder which is extremely disappointing! Radxa team is checking the HDMI issue on their board (they are using 3588 as well) - https://forum.radxa.com/t/hdmi-input-support/25740/8 3588 should support 4k 60fps in theory but there are many complaints about using WIFI, BTH & USB in parallel that leading the losing signals when working with HDMI input. -
Can you suggest alternatives for using HDMI input? So what is the solution if i want to consume 4k 60fps video? -
I will try to join the effort too I'm not able to find the hdmirx binaries at all. I compiled armbian without any modifications. Am I missing something? -
Thank you. I see a lot of patches around this area in the build project. I will take a look. thank you! What is your recommendation about consuming video? using only CSI? -
thanks for the reply. I was able to build armbian from scretch with the new module based on orange pi max. Can you guide me how to add hdmirx to the kernel? at the moment I'm not able to use the HDMI input at all
