chaoschris
5 -
[partly solved] OrangePi Zero2 freezes or looses WiFi connection
chaoschris replied to chaoschris's topic in Orange Pi Zero 2
Hi guys, it looks like my issue is solved now after entering a specific BSSID in my network connection. Or to be more precise, the issue is solved for me now, but for sure the issue still exists when you have a meshed network. The connection is rock solid now once it is pinned to an specific access point in my mesh network. Without the entry for a specific BSSID it disconnects after some time. To analyze this a bit further it would be necessary to have a LAN connection or at least a screen and a keyboard. But unfortunately i have neither and the location of the device is a bit odd (it hangs in several meters height ๐ ). If somebody is interested in solving this issue i can provide log files on request. I have mounted a remote switchable power supply, so it would be no problem for me to reproduce the issue again without the need to climb up again and again to reset the device..... Thanks to all for the help. Best regards, Chris -
>>have you tried rolling back the kernel? not yet. At the moment I am testing it with a sticked mac address to a specific access point -
I pinned the wifi connection now to one specific mac address and give it a try...... root@orangepizero2:/# nmcli dev wifi list IN-USE BSSID SSID MODE CHAN RATE SIGNAL BARS SECURITY * 34:81:C4:11:14:EA KNAECKEBROED Infra 11 405 Mbit/s 100 โโโโ WPA2 5C:49:79:83:C0:F6 KNAECKEBROED Infra 11 405 Mbit/s 95 โโโโ WPA2 C4:3A:35:B3:B7:5E Hi-A095344 Infra 3 65 Mbit/s 69 โโโ_ -- C8:0E:14:01:96:C7 Puff5 Infra 52 405 Mbit/s 42 โโ__ WPA2 -
possibly the same issue like here? https://forum.armbian.com/topic/37689-unisoc_wifi-disconnections-on-orangepi-zero-3/#elShareItem_791442255_menu I have a mesh, could this cause this issue? But why does it occur now and not in the last years? Cell 02 - Address: 34:81:C4:11:14:EA Channel:11 Frequency:2.462 GHz (Channel 11) Quality=70/70 Signal level=-32 dBm Encryption key:on ESSID:"KNAECKEBROED" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=000000030cd2d358 Extra: Last beacon: 140ms ago IE: Unknown: 000C4B4E4145434B4542524F4544 IE: Unknown: 010882848B968C129824 IE: Unknown: 03010B IE: Unknown: 050400010000 IE: Unknown: 0706444520010D14 IE: Unknown: 2A0100 IE: Unknown: 3204B048606C IE: Unknown: 0B0505000A0000 IE: Unknown: 460573D000000C IE: Unknown: 2D1AEF111BFFFFFF00000000000000000001000000000406E6470D00 IE: Unknown: 3D160B0F0600000000000000000000000000000000000000 IE: Unknown: 4A0E14000A002C01C800140005001900 IE: Unknown: 7F0805000F0000000040 IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: DD0900037F01010000FF7F IE: Unknown: DD088CFDF00101020100 IE: Unknown: DD168CFDF004000049000003020972018C160000CDAB0000 IE: Unknown: DD0C00040E010102010000000000 IE: Unknown: DD1D0050F204104A0001101044000102103C0001011049000600372A000120 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD1F8CFDF00000010100000101000000000000FFFF0000000000003481C41114EA Cell 03 - Address: 5C:49:79:83:C0:F6 Channel:11 Frequency:2.462 GHz (Channel 11) Quality=67/70 Signal level=-43 dBm Encryption key:on ESSID:"KNAECKEBROED" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=000000030cbcca49 Extra: Last beacon: 1584ms ago IE: Unknown: 000C4B4E4145434B4542524F4544 IE: Unknown: 010882848B968C129824 IE: Unknown: 03010B IE: Unknown: 0706444520010D14 IE: Unknown: 2A0100 IE: Unknown: 3204B048606C IE: Unknown: 0B0502000E0000 IE: Unknown: 460573D000000C IE: Unknown: 2D1AEF111BFFFFFF00000000000000000001000000000406E6470D00 IE: Unknown: 3D160B0F0600000000000000000000000000000000000000 IE: Unknown: 4A0E14000A002C01C800140005001900 IE: Unknown: 7F0805000F0000000040 IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00 IE: Unknown: DD0900037F01010000FF7F IE: Unknown: DD0C00040E010102010000000000 IE: Unknown: DD168CFDF004000049000003020972018C160000CDAB0000 IE: Unknown: DD6F0050F204104A0001101044000102103B00010310470010946CD798D7A5C92D4B7B5C497983C0F61021000341564D1023000446426F78102400043030303010420004303030301054000800060050F20400011011000446426F78100800022388103C0001011049000600372A000120 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD088CFDF00101020100 -
Hi everybody, Since some time i have a problem with my OrangePi Zero2. Not sure about when it started exactly, but possibly it came with the latest kernel upgrade. Until then the device was working without any problems and absolutely stable. Unfortunately i have no connection by cable, only with Wifi and possibly it is only the Wifi connection which isn't working anymore? I found the following entries in /var/log/kern (which are the latest entries until the device restarts): 2025-02-10T19:54:40.037397+01:00 orangepizero2 kernel: [86427.304061] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection sm_state (5), status: (2)! 2025-02-10T19:54:40.037459+01:00 orangepizero2 kernel: [86427.304105] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection KNAECKEBROED failed status code:1! 2025-02-10T19:54:40.365435+01:00 orangepizero2 kernel: [86427.632069] sprdwl:sprdwl_fc_add_share_credit, 536, mode:1 closed, index:0, share it 2025-02-10T19:54:55.573468+01:00 orangepizero2 kernel: [86442.837864] warning: `iwconfig' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211 is this a common issue with one of the latest updates or kernel? Here the link to the actual armbianmonitor -u from this device: https://paste.next.armbian.com/runuloneco Best regards, Chris
