Superuser
5 -
PiRogue installation for NanoPI_R4S problems
Superuser replied to Superuser's topic in Software, Applications, Userspace
Everything is good, thanks for the help and sorry for confusion, I only should to change PiRogue default interface after installation, this is PiRogue interface detection problem... -
I would like to create Lab with PiRogue and add suricata custom rules for Pegasus attack preventions: https://pts-project.org/guides/g7/ I would like to use internal PiRogue_VPN_server and add additional 3x-ui or S-ui server with xray-vless-realty as second layer because mobile operators or internet providers from specific country like RU or CN may block simple wireguard proto, this will be looks like: NanoPI_R4S with [ PiRogue(internal_wireuard) -> XRAY_server(xray-vless-realty) ] -> Android Phone with XRAY client(xray-vless-realty) and host level firewall that will be forward all mobile trafic to the VPN client NanoPI + Arambian lasted with all updates For PiRogue installation I use the instruction: https://pts-project.org/docs/pirogue/installation/ Step #1 sudo apt-get update sudo apt-get dist-upgrade Step #2 sudo apt-get install wget sudo wget -O /etc/apt/sources.list.d/pirogue.list https://pts-project.org/debian-12/pirogue.list sudo wget -O /etc/apt/trusted.gpg.d/pirogue.gpg https://pts-project.org/debian-12/pirogue.gpg sudo apt-get update sudo apt-get install pirogue-base I have PiRogue's after installation message: My currient problem is starting process of a dnsmasq.service on my NanoPI_R4S Dears @Igor @Werner could you pls help me or forward to nanopi r4s maintainer that may fix the prob I alredy describe similar problems with "systemd-networkd-wait-online.service" in my previos my topic, see link: or pirogue_log.txt
Hi Everybody, I'm trying to set up Nextcloud with Collabora Office on NanoPi R4S running Armbian, but I'm having trouble configuring the reverse proxy (nginx/Caddy) for HTTPS with local domains. Current Setup: Running via docker-compose.yml (shown below) Without HTTPS, everything works: Collabora can open documents in Nextcloud's web UI With HTTPS enabled, Collabora integration breaks Added to /etc/hosts: 127.0.0.1 nextcloud.lan collabora.nextcloud.lan What I Need: HTTPS configuration for both services Reverse proxy to local domains: Nextcloud: https://nextcloud.lan Collabora: https://collabora.nextcloud.lan My docker-compose.yml (HTTP-only version): networks: network: driver: bridge volumes: mariadb_config: mariadb_data: nextcloud_config: nextcloud_data: services: collabora: image: collabora/code restart: unless-stopped container_name: collabora hostname: collabora domainname: collabora.nextcloud.lan networks: - network ports: - "9980:9980" cap_add: - MKNOD nextcloud_db: image: linuxserver/mariadb restart: unless-stopped container_name: nextcloud_db hostname: nextcloud_db networks: - network volumes: - mariadb_config:/config - mariadb_data:/data environment: - PUID=1000 - PGID=1000 - TZ=UTC - MYSQL_ROOT_PASSWORD=nextcloud - MYSQL_DATABASE=nextcloud_db - MYSQL_USER=nextcloud - MYSQL_PASSWORD=nextcloud nextcloud: image: linuxserver/nextcloud restart: unless-stopped depends_on: - nextcloud_db - collabora container_name: nextcloud hostname: nextcloud domainname: nextcloud.lan networks: - network ports: - "8080:80" volumes: - nextcloud_config:/config - nextcloud_data:/data environment: - PUID=1000 - PGID=1000 - TZ=UTC - NEXTCLOUD_UPLOAD_LIMIT=16G - NEXTCLOUD_MAX_TIME=3600 - NEXTCLOUD_MEMORY_LIMIT=3G - SKIP_DOMAIN_VALIDATION=true - NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.lan Key Questions: How should I modify the docker-compose.yml to: Enable HTTPS for both services? Properly configure the reverse proxy for the local domains? Set up valid SSL certificates for *.lan domains? For Collabora: What extra_params or environment variables are needed for HTTPS? How to configure Nextcloud's config.php for the Collabora HTTPS endpoint? I'd prefer a solution using Caddy if possible, as it's simpler for automatic HTTPS. Any working configuration examples would be greatly appreciated! Thanks in advance for your help! Viktor Malygin WordPress Developer
Is it normal ? Because i have a some problems with custom local domain configurations... root@nanopi-r4s:~# sudo systemctl status systemd-networkd-wait-online.service × systemd-networkd-wait-online.service - Wait for Network to be Configured Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Sat 2025-03-01 23:45:33 MSK; 2min 25s ago Docs: man:systemd-networkd-wait-online.service(8) Process: 1176 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE) Main PID: 1176 (code=exited, status=1/FAILURE) CPU: 30ms мар 01 23:43:33 nanopi-r4s systemd[1]: Starting systemd-networkd-wait-online.service - Wait for Network to be Configured... мар 01 23:45:33 nanopi-r4s systemd-networkd-wait-online[1176]: Timeout occurred while waiting for network connectivity. мар 01 23:45:33 nanopi-r4s systemd[1]: systemd-networkd-wait-online.service: Main process exited, code=exited, status=1/FAILURE мар 01 23:45:33 nanopi-r4s systemd[1]: systemd-networkd-wait-online.service: Failed with result 'exit-code'. мар 01 23:45:33 nanopi-r4s systemd[1]: Failed to start systemd-networkd-wait-online.service - Wait for Network to be Configured.
Hi Arambian support team, I have a problem with "sudo apt update && apt upgrade -y" of my Nano Pi R4S 1) if i use ru_RU.UTF-8 and RU timezone than i have: W: Не удалось получить http://apt.armbian.com/dists/bookworm/InRelease 502 Bad Gateway [my_ru_ip_addres]:[Port_80] W: Некоторые индексные файлы скачать не удалось. Они были проигнорированы, или вместо них были использованы старые версии. Translations: W: Failed to get http://apt.armbian.com/dists/bookworm/InRelease 502 Bad Gateway [my_ru_ip_addres]:[Port_80] W: Some index files could not be downloaded. They were ignored or old versions were used instead. 2) if i use US locations and RU timezone than i have: Err:7 http://fastmirror.pp.ua/armbian bookworm/main arm64 armbian-bsp-cli-nanopi-r4s-current arm64 24.11.1 Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable) Could not connect to fastmirror.pp.ua:80 (93.126.105.202), connection timed out Err:9 http://fastmirror.pp.ua/armbian bookworm/main arm64 linux-dtb-current-rockchip64 arm64 25.2.1 Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable) Fetched 159 MB in 1min 58s (1,341 kB/s) E: Failed to fetch http://fastmirror.pp.ua/armbian/pool/main/a/armbian-bsp-cli-nanopi-r4s-current/armbian-bsp-cli-nanopi-r4s-current_24.11.1_arm64__1-PC980a-V0406-H3400-B6e44-R7697.deb Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable) Could not connect to fastmirror.pp.ua:80 (93.126.105.202), connection timed out E: Failed to fetch http://fastmirror.pp.ua/armbian/pool/main/l/linux-dtb-current-rockchip64/linux-dtb-current-rockchip64_25.2.1_arm64__6.12.12-Sd914-D7b0b-P083d-C67e9Heb51-HK01ba-Vc222-B8de6-R448a.deb Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable) E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? I mean connection failed As for accessibility you can use free hosting for the Arambian repository for users located in Russia. @Igor @Werner could you pls to change for RU users arambian repo, for example, it may be https://sourceforge.net/ servers by default update and upgrade, and problem with Arambian update and upgrade will be sloved for RU users I mean https://sourceforge.net/ Because they provide free hosting and free repository hosting for OpenSource projects For example, if you know VPN PassWall/PassWall2 uses https://sourceforge.net/ for repository hosting. Connection to http://apt.armbian.com/ servers is not available in Russia right now or it may be my provider problems. Connection to http://fastmirror.pp.ua/ servers is not available in Russia right now or it may be my provider problems. Connection to https://sourceforge.net/ servers is available in Russia right now. <- Or could you pls advise how i can fix the problem ?
