boat
11 -
apt upgrade → Size + hash Sum mismatches → Mirror sync in progress?
boat replied to porg's topic in Odroid XU4
Thank's, did this but wasn't enough. But now I found the secret as it now installed after issuing this weird command https://unix.stackexchange.com/a/674661 -
It looks a bit better with "apt install ./filename.deb" but for whatever reason I get a permission denied error despite being root. Maybe some chroot specialty I'm not aware of? So close to get the system working again but also so far.... 😫 Also tried chmod 777 on the deb files (root is already owner) but still the permission denied error.... I'm out of clue with a big headache trying since two days getting this thing working again just hitting about every tree on the way 😣 @odroidhc2 how did you manage installing the deb files in chroot? -
Thank's Igor! I tried the docs but didn't find a hint on manual installing deb packages... with google fu I found the command "dpkg -i" that I tried but sadly failed: Forums are always great so users can help other users... specially who are in the same boat 🚣♂️ Keep up the great work with armbian! -
Thank's for your answer. If I understand correct you downloaded outside of chroot then and copied the files over? What command did you use in the terminal to install the deb packages inside chroot please? -
Could you drop a line or two on how to do this please? I can see wget is available but I don't even manage to localize the .deb packages with a IP address to download 😭 Thank's a lot! -
That did the trick indeed! Thanks a million Werner! Now I'm stuck here as well 😢 I tried running "apt update" but the problem persists. How could I solve DNS problems? I'm first time doing chroot and I actually have around 0 clue what I do... I tried nslookup in the chroot shell but that is not available... Trying ping on google does indeed indicate hostnames cant be resolved 😭 I guess quickest fix would be just to download the package files from server via IP address and install them manually? -
I used this command on a HC running OMV (armbian) which was not restarted with success! root@armbianomv:~# apt install linux-image-current-odroidxu4=24.11.1 Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be DOWNGRADED: linux-image-current-odroidxu4 0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 4 not upgraded. Need to get 30.7 MB of archives. After this operation, 14.2 MB disk space will be freed. Do you want to continue? [Y/n] Y Get:1 http://netcup.armbian.com/apt bookworm/main armhf linux-image-current-odroidxu4 armhf 24.11.1 [30.7 MB] Fetched 30.7 MB in 4s (8521 kB/s) dpkg: warning: downgrading linux-image-current-odroidxu4 from 25.2.1 to 24.11.1 (Reading database ... 34762 files and directories currently installed.) Preparing to unpack .../linux-image-current-odroidxu4_24.11.1_armhf.deb ... Armbian 'linux-image-current-odroidxu4' for '6.6.75-current-odroidxu4': 'prerm' starting. Armbian 'linux-image-current-odroidxu4' for '6.6.75-current-odroidxu4': 'prerm' finishing. Armbian 'linux-image-current-odroidxu4' for '6.6.60-current-odroidxu4': 'preinst' starting. Armbian 'linux-image-current-odroidxu4' for '6.6.60-current-odroidxu4': 'preinst' finishing. Unpacking linux-image-current-odroidxu4 (24.11.1) over (25.2.1) ... Armbian 'linux-image-current-odroidxu4' for '6.6.75-current-odroidxu4': 'postrm' starting. Armbian 'linux-image-current-odroidxu4' for '6.6.75-current-odroidxu4': 'postrm' finishing. Setting up linux-image-current-odroidxu4 (24.11.1) ... Armbian 'linux-image-current-odroidxu4' for '6.6.60-current-odroidxu4': 'postinst' starting. update-initramfs: Generating /boot/initrd.img-6.6.60-current-odroidxu4 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.60-current-odroidxu4 Image Name: uInitrd Created: Thu Feb 13 12:50:07 2025 Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 13361420 Bytes = 13048.26 KiB = 12.74 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.60-current-odroidxu4 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.60-current-odroidxu4' update-initramfs: Armbian: done. Remove unused generated file: /boot/uInitrd-6.6.75-current-odroidxu4 Remove unused generated file: /boot/initrd.img-6.6.75-current-odroidxu4 Armbian: update last-installed kernel symlink to 'zImage'... '/boot/zImage' -> 'vmlinuz-6.6.60-current-odroidxu4' Armbian: Debian compat: linux-update-symlinks install 6.6.60-current-odroidxu4 boot/vmlinuz-6.6.60-current-odroidxu4 I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.6.60-current-odroidxu4 I: /initrd.img.old is now a symlink to boot/initrd.img-6.6.60-current-odroidxu4 I: /vmlinuz is now a symlink to boot/vmlinuz-6.6.60-current-odroidxu4 I: /initrd.img is now a symlink to boot/initrd.img-6.6.60-current-odroidxu4 Armbian 'linux-image-current-odroidxu4' for '6.6.60-current-odroidxu4': 'postinst' finishing. root@armbianomv:~# -
Which host OS did you use? I struggle with a fresh debian install and passing your commands as root, I stuck with `chroot` (`bash: chroot: command not found`) -
So I just installed debian in a virtual machine on a windows host and the sd card is their. Everything until chroot command worked fine but now I'm stuck getting: bash: chroot: command not found despite having chroot (gnu coreutils) 9.1 under /usr/sbin/chroot I somewhat didn't end up with a user account (without su) in debian (used the automated install from virtual box for the first time) so I elevated to root first thing and did everything as root - maybe that's a problem? I would be grateful for any hints! -
Thank's! Just in the process installing a debian virtual machine in the present windows host to recover the system like described. I now checked the second HC and found out that the "update of death" is already installed and the system requests a reboot. Obviously I didn't do it! I just hope we don't have a power outage until a fixed update is available (so far my system can't seem to find one). -
We are in the same boat. One of our two HC's got restarted after the unattended and is now not starting anymore (probably boot-looping). I see the post from @pauet how to recover (thank's) but we don't have a (full blown) linux host on site - just a second HC's running armbian which still is alive (not rebooted). Any idea if (with the help of a windows host or the second armbian) the broken system can be recovered somehow? Thank's everyone!
