Joda
11 -
ok it's working I make a diff between pine64 and pine64+ root@domotique:~# diff pine64.txt pine64+.txt 5c5 < model = "Pine64"; --- > model = "Pine64+"; 9c9 < compatible = "pine64,pine64\0allwinner,sun50i-a64"; --- > compatible = "pine64,pine64-plus\0allwinner,sun50i-a64"; 202c202 < phandle = <0x40>; --- > phandle = <0x7b>; 261c261 < phandle = <0x7b>; --- > phandle = <0x40>; 282c282 < phandle = <0xb2>; --- > phandle = <0x37>; 303,308d302 < uart2-rts-cts-pins { < function = "uart2"; < pins = "PB2\0PB3"; < phandle = <0xb3>; < }; < 1102a1097 > regulator-enable-ramp-delay = <0x186a0>; 1365c1360 < pinctrl-0 = <0xb2>; --- > pinctrl-0 = <0x37>; 1371c1366 < status = "okay"; --- > status = "disabled"; 1848d1842 < uart2_rts_cts_pins = "/soc/pinctrl@1c20800/uart2-rts-cts-pins"; I think we just need to add uart2-rts-cts-pins { function = "uart2"; pins = "PB2\0PB3"; phandle = <0xb3>; }; uart2_rts_cts_pins = "/soc/pinctrl@1c20800/uart2-rts-cts-pins"; @Werner do you think it's possible to add this to the uart2 overlay ? cordially
ok so when execute this command dtc -I fs /sys/firmware/devicetree/base/ I can see model = "Pine64+"; serial-number = "92c000bac9dd6a14"; #size-cells = <0x01>; interrupt-parent = <0x01>; compatible = "pine64,pine64-plus\0allwinner,sun50i-a64"; so I think I can update sun50i-a64-pine64.dtb with the ethernet configuration from Pine64+
hello, I try to remove the bluetooth and recreate the dtb but I still have the error on ttyS2 I also try to add fdtfile=sun50i-a64-pine64.dtb on /boot/armbianEnv.txt. With this new configuration /dev/ttyS2 work but a lost end0 ..... cordially
root@domotique:/boot/dtb/allwinner/overlay# ls -al total 392 drwxr-xr-x 2 root root 12288 Mar 1 14:37 . drwxr-xr-x 3 root root 4096 Mar 3 17:16 .. -rw-r--r-- 1 root root 3998 Feb 26 21:14 README.sun50i-a64-overlays -rw-r--r-- 1 root root 4737 Feb 26 21:14 README.sun50i-h5-overlays -rw-r--r-- 1 root root 3821 Feb 26 21:14 sun50i-a64-fixup.scr -rw-r--r-- 1 root root 794 Feb 26 21:14 sun50i-a64-i2c0.dtbo -rw-r--r-- 1 root root 496 Feb 26 21:14 sun50i-a64-i2c1.dtbo -rw-r--r-- 1 root root 2364 Feb 26 21:14 sun50i-a64-pine64-7inch-lcd.dtbo -rw-r--r-- 1 root root 778 Feb 26 21:14 sun50i-a64-pps-gpio.dtbo -rw-r--r-- 1 root root 1173 Feb 26 21:14 sun50i-a64-spi-add-cs1.dtbo -rw-r--r-- 1 root root 668 Feb 26 21:14 sun50i-a64-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 808 Feb 26 21:14 sun50i-a64-spi-spidev.dtbo -rw-r--r-- 1 root root 506 Feb 26 21:14 sun50i-a64-uart1.dtbo -rw-r--r-- 1 root root 963 Feb 26 21:14 sun50i-a64-uart2.dtbo -rw-r--r-- 1 root root 804 Feb 26 21:14 sun50i-a64-uart3.dtbo -rw-r--r-- 1 root root 963 Feb 26 21:14 sun50i-a64-uart4.dtbo -rw-r--r-- 1 root root 777 Feb 26 21:14 sun50i-a64-w1-gpio.dtbo -rw-r--r-- 1 root root 339 Feb 26 21:14 sun50i-h5-analog-codec.dtbo -rw-r--r-- 1 root root 384 Feb 26 21:14 sun50i-h5-cir.dtbo -rw-r--r-- 1 root root 477 Feb 26 21:14 sun50i-h5-cpu-clock-1.0GHz-1.1v.dtbo -rw-r--r-- 1 root root 477 Feb 26 21:14 sun50i-h5-cpu-clock-1.2GHz-1.3v.dtbo -rw-r--r-- 1 root root 897 Feb 26 21:14 sun50i-h5-cpu-clock-1.3GHz-1.3v.dtbo -rw-r--r-- 1 root root 4191 Feb 26 21:14 sun50i-h5-fixup.scr -rw-r--r-- 1 root root 1020 Feb 26 21:14 sun50i-h5-gpio-regulator-1.3v.dtbo -rw-r--r-- 1 root root 374 Feb 26 21:14 sun50i-h5-i2c0.dtbo -rw-r--r-- 1 root root 374 Feb 26 21:14 sun50i-h5-i2c1.dtbo -rw-r--r-- 1 root root 374 Feb 26 21:14 sun50i-h5-i2c2.dtbo -rw-r--r-- 1 root root 778 Feb 26 21:14 sun50i-h5-pps-gpio.dtbo -rw-r--r-- 1 root root 862 Feb 26 21:14 sun50i-h5-pwm.dtbo -rw-r--r-- 1 root root 1040 Feb 26 21:14 sun50i-h5-spdif-out.dtbo -rw-r--r-- 1 root root 1177 Feb 26 21:14 sun50i-h5-spi-add-cs1.dtbo -rw-r--r-- 1 root root 804 Feb 26 21:14 sun50i-h5-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 804 Feb 26 21:14 sun50i-h5-spi-spidev.dtbo -rw-r--r-- 1 root root 502 Feb 26 21:14 sun50i-h5-uart1.dtbo -rw-r--r-- 1 root root 794 Feb 26 21:14 sun50i-h5-uart2.dtbo -rw-r--r-- 1 root root 798 Feb 26 21:14 sun50i-h5-uart3.dtbo -rw-r--r-- 1 root root 504 Feb 26 21:14 sun50i-h5-usbhost0.dtbo -rw-r--r-- 1 root root 504 Feb 26 21:14 sun50i-h5-usbhost1.dtbo -rw-r--r-- 1 root root 504 Feb 26 21:14 sun50i-h5-usbhost2.dtbo -rw-r--r-- 1 root root 504 Feb 26 21:14 sun50i-h5-usbhost3.dtbo -rw-r--r-- 1 root root 777 Feb 26 21:14 sun50i-h5-w1-gpio.dtbo -rw-r--r-- 1 root root 314 Feb 26 21:14 sun50i-h616-bananapi-m4-pg-15-16-i2c4.dtbo -rw-r--r-- 1 root root 314 Feb 26 21:14 sun50i-h616-bananapi-m4-pg-17-18-i2c3.dtbo -rw-r--r-- 1 root root 315 Feb 26 21:14 sun50i-h616-bananapi-m4-pg-6-7-uart1.dtbo -rw-r--r-- 1 root root 533 Feb 26 21:14 sun50i-h616-bananapi-m4-pg-8-9-rts-cts-uart1.dtbo -rw-r--r-- 1 root root 315 Feb 26 21:14 sun50i-h616-bananapi-m4-ph-2-3-uart5.dtbo -rw-r--r-- 1 root root 315 Feb 26 21:14 sun50i-h616-bananapi-m4-pi-13-14-uart4.dtbo -rw-r--r-- 1 root root 539 Feb 26 21:14 sun50i-h616-bananapi-m4-pi-15-16-rts-cts-uart4.dtbo -rw-r--r-- 1 root root 314 Feb 26 21:14 sun50i-h616-bananapi-m4-pi-5-6-i2c0.dtbo -rw-r--r-- 1 root root 314 Feb 26 21:14 sun50i-h616-bananapi-m4-pi-7-8-i2c1.dtbo -rw-r--r-- 1 root root 1358 Feb 26 21:14 sun50i-h616-bananapi-m4-sdio-wifi-bt.dtbo -rw-r--r-- 1 root root 843 Feb 26 21:14 sun50i-h616-bananapi-m4-spi1-cs0-cs1-spidev.dtbo -rw-r--r-- 1 root root 678 Feb 26 21:14 sun50i-h616-bananapi-m4-spi1-cs0-spidev.dtbo -rw-r--r-- 1 root root 314 Feb 26 21:14 sun50i-h616-bananapi-m4-spi1-cs1-spidev.dtbo -rw-r--r-- 1 root root 4203 Feb 26 21:14 sun50i-h616-fixup.scr -rw-r--r-- 1 root root 269 Feb 26 21:14 sun50i-h616-gpu.dtbo -rw-r--r-- 1 root root 513 Feb 26 21:14 sun50i-h616-i2c0-pi.dtbo -rw-r--r-- 1 root root 391 Feb 26 21:14 sun50i-h616-i2c1-pi.dtbo -rw-r--r-- 1 root root 344 Feb 26 21:14 sun50i-h616-i2c2-ph.dtbo -rw-r--r-- 1 root root 513 Feb 26 21:14 sun50i-h616-i2c2-pi.dtbo -rw-r--r-- 1 root root 344 Feb 26 21:14 sun50i-h616-i2c3-pg.dtbo -rw-r--r-- 1 root root 344 Feb 26 21:14 sun50i-h616-i2c3-ph.dtbo -rw-r--r-- 1 root root 344 Feb 26 21:14 sun50i-h616-i2c4-pg.dtbo -rw-r--r-- 1 root root 344 Feb 26 21:14 sun50i-h616-i2c4-ph.dtbo -rw-r--r-- 1 root root 268 Feb 26 21:14 sun50i-h616-ir.dtbo -rw-r--r-- 1 root root 396 Feb 26 21:14 sun50i-h616-light.dtbo -rw-r--r-- 1 root root 339 Feb 26 21:14 sun50i-h616-mcp2515.dtbo -rw-r--r-- 1 root root 661 Feb 26 21:14 sun50i-h616-spidev0_0.dtbo -rw-r--r-- 1 root root 661 Feb 26 21:14 sun50i-h616-spidev1_0.dtbo -rw-r--r-- 1 root root 661 Feb 26 21:14 sun50i-h616-spidev1_1.dtbo -rw-r--r-- 1 root root 661 Feb 26 21:14 sun50i-h616-spidev1_2.dtbo -rw-r--r-- 1 root root 808 Feb 26 21:14 sun50i-h616-spi-spidev.dtbo -rw-r--r-- 1 root root 616 Feb 26 21:14 sun50i-h616-tft35_spi.dtbo -rw-r--r-- 1 root root 413 Feb 26 21:14 sun50i-h616-uart2-pg.dtbo -rw-r--r-- 1 root root 487 Feb 26 21:14 sun50i-h616-uart2-pg-rts-cts.dtbo -rw-r--r-- 1 root root 413 Feb 26 21:14 sun50i-h616-uart2-ph.dtbo -rw-r--r-- 1 root root 487 Feb 26 21:14 sun50i-h616-uart2-ph-rts-cts.dtbo -rw-r--r-- 1 root root 410 Feb 26 21:14 sun50i-h616-uart5.dtbo -rw-r--r-- 1 root root 272 Feb 26 21:14 sun50i-h616-ws2812.dtbo -rw-r--r-- 1 root root 3844 Feb 26 21:14 sun50i-h6-fixup.scr -rw-r--r-- 1 root root 374 Feb 26 21:14 sun50i-h6-i2c0.dtbo -rw-r--r-- 1 root root 374 Feb 26 21:14 sun50i-h6-i2c1.dtbo -rw-r--r-- 1 root root 374 Feb 26 21:14 sun50i-h6-i2c2.dtbo -rw-r--r-- 1 root root 671 Feb 26 21:14 sun50i-h6-pwm.dtbo -rw-r--r-- 1 root root 268 Feb 26 21:14 sun50i-h6-ruart.dtbo -rw-r--r-- 1 root root 1177 Feb 26 21:14 sun50i-h6-spi-add-cs1.dtbo -rw-r--r-- 1 root root 804 Feb 26 21:14 sun50i-h6-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 657 Feb 26 21:14 sun50i-h6-spi-spidev1.dtbo -rw-r--r-- 1 root root 808 Feb 26 21:14 sun50i-h6-spi-spidev.dtbo -rw-r--r-- 1 root root 502 Feb 26 21:14 sun50i-h6-uart1.dtbo -rw-r--r-- 1 root root 798 Feb 26 21:14 sun50i-h6-uart2.dtbo -rw-r--r-- 1 root root 798 Feb 26 21:14 sun50i-h6-uart3.dtbo -rw-r--r-- 1 root root 773 Feb 26 21:14 sun50i-h6-w1-gpio.dtbo
Hello, for the ttyS1 ==> I don't have overlay folder on /boot/dtb I have only allwinner: root@domotique:~# ls -al /boot/dtb/allwinner/ total 2888 drwxr-xr-x 3 root root 4096 Mar 1 14:37 . drwxr-xr-x 3 root root 4096 Mar 1 14:37 .. drwxr-xr-x 2 root root 12288 Mar 1 14:37 overlay -rw-r--r-- 1 root root 14088 Feb 26 21:14 sun50i-a100-allwinner-perf1.dtb -rw-r--r-- 1 root root 41557 Feb 26 21:14 sun50i-a64-amarula-relic.dtb -rw-r--r-- 1 root root 41882 Feb 26 21:14 sun50i-a64-bananapi-m64.dtb -rw-r--r-- 1 root root 40750 Feb 26 21:14 sun50i-a64-nanopi-a64.dtb -rw-r--r-- 1 root root 40197 Feb 26 21:14 sun50i-a64-oceanic-5205-5inmfd.dtb -rw-r--r-- 1 root root 40744 Feb 26 21:14 sun50i-a64-olinuxino-1G.dtb -rw-r--r-- 1 root root 42171 Feb 26 21:14 sun50i-a64-olinuxino-1Ge16GW.dtb -rw-r--r-- 1 root root 42137 Feb 26 21:14 sun50i-a64-olinuxino-1Ge4GW.dtb -rw-r--r-- 1 root root 40954 Feb 26 21:14 sun50i-a64-olinuxino-1Gs16M.dtb -rw-r--r-- 1 root root 40900 Feb 26 21:14 sun50i-a64-olinuxino-2Ge8G.dtb -rw-r--r-- 1 root root 42041 Feb 26 21:14 sun50i-a64-olinuxino.dtb -rw-r--r-- 1 root root 42455 Feb 26 21:14 sun50i-a64-olinuxino-emmc.dtb -rw-r--r-- 1 root root 42575 Feb 26 21:14 sun50i-a64-orangepi-win.dtb -rw-r--r-- 1 root root 41503 Feb 26 21:14 sun50i-a64-pine64.dtb -rw-r--r-- 1 root root 41553 Feb 26 21:14 sun50i-a64-pine64-lts.dtb -rw-r--r-- 1 root root 41629 Feb 26 21:14 sun50i-a64-pine64-plus.dtb -rw-r--r-- 1 root root 43455 Feb 26 21:14 sun50i-a64-pinebook.dtb -rw-r--r-- 1 root root 54389 Feb 26 21:14 sun50i-a64-pinephone-1.0.dtb -rw-r--r-- 1 root root 54416 Feb 26 21:14 sun50i-a64-pinephone-1.1.dtb -rw-r--r-- 1 root root 54715 Feb 26 21:14 sun50i-a64-pinephone-1.2b.dtb -rw-r--r-- 1 root root 54427 Feb 26 21:14 sun50i-a64-pinephone-1.2.dtb -rw-r--r-- 1 root root 44752 Feb 26 21:14 sun50i-a64-pinetab.dtb -rw-r--r-- 1 root root 44784 Feb 26 21:14 sun50i-a64-pinetab-early-adopter.dtb -rw-r--r-- 1 root root 41433 Feb 26 21:14 sun50i-a64-sopine-baseboard.dtb -rw-r--r-- 1 root root 42618 Feb 26 21:14 sun50i-a64-teres-i.dtb -rw-r--r-- 1 root root 37413 Feb 26 21:14 sun50i-h313-tanix-tx1.dtb -rw-r--r-- 1 root root 40110 Feb 26 21:14 sun50i-h313-x96q-lpddr3.dtb -rw-r--r-- 1 root root 33770 Feb 26 21:14 sun50i-h5-bananapi-m2-plus.dtb -rw-r--r-- 1 root root 34211 Feb 26 21:14 sun50i-h5-bananapi-m2-plus-v1.2.dtb -rw-r--r-- 1 root root 32413 Feb 26 21:14 sun50i-h5-emlid-neutis-n5-devboard.dtb -rw-r--r-- 1 root root 32650 Feb 26 21:14 sun50i-h5-libretech-all-h3-cc.dtb -rw-r--r-- 1 root root 31308 Feb 26 21:14 sun50i-h5-libretech-all-h3-it.dtb -rw-r--r-- 1 root root 33245 Feb 26 21:14 sun50i-h5-libretech-all-h5-cc.dtb -rw-r--r-- 1 root root 34882 Feb 26 21:14 sun50i-h5-nanopi-k1-plus.dtb -rw-r--r-- 1 root root 32150 Feb 26 21:14 sun50i-h5-nanopi-m1-plus2.dtb -rw-r--r-- 1 root root 31847 Feb 26 21:14 sun50i-h5-nanopi-neo2.dtb -rw-r--r-- 1 root root 31839 Feb 26 21:14 sun50i-h5-nanopi-neo2-v1.1.dtb -rw-r--r-- 1 root root 32090 Feb 26 21:14 sun50i-h5-nanopi-neo-core2.dtb -rw-r--r-- 1 root root 32669 Feb 26 21:14 sun50i-h5-nanopi-neo-plus2.dtb -rw-r--r-- 1 root root 32987 Feb 26 21:14 sun50i-h5-nanopi-r1s-h5.dtb -rw-r--r-- 1 root root 32687 Feb 26 21:14 sun50i-h5-orangepi-pc2.dtb -rw-r--r-- 1 root root 32710 Feb 26 21:14 sun50i-h5-orangepi-prime.dtb -rw-r--r-- 1 root root 30401 Feb 26 21:14 sun50i-h5-orangepi-zero-plus2.dtb -rw-r--r-- 1 root root 31940 Feb 26 21:14 sun50i-h5-orangepi-zero-plus.dtb -rw-r--r-- 1 root root 42648 Feb 26 21:14 sun50i-h616-bigtreetech-cb1-emmc.dtb -rw-r--r-- 1 root root 42395 Feb 26 21:14 sun50i-h616-bigtreetech-cb1-manta.dtb -rw-r--r-- 1 root root 42587 Feb 26 21:14 sun50i-h616-bigtreetech-cb1-sd.dtb -rw-r--r-- 1 root root 42371 Feb 26 21:14 sun50i-h616-bigtreetech-pi.dtb -rw-r--r-- 1 root root 41523 Feb 26 21:14 sun50i-h616-orangepi-zero2.dtb -rw-r--r-- 1 root root 40136 Feb 26 21:14 sun50i-h616-x96-mate.dtb -rw-r--r-- 1 root root 43383 Feb 26 21:14 sun50i-h618-bananapi-m4-berry.dtb -rw-r--r-- 1 root root 41208 Feb 26 21:14 sun50i-h618-bananapi-m4-zero.dtb -rw-r--r-- 1 root root 39526 Feb 26 21:14 sun50i-h618-longanpi-3h.dtb -rw-r--r-- 1 root root 43298 Feb 26 21:14 sun50i-h618-orangepi-zero2w.dtb -rw-r--r-- 1 root root 40929 Feb 26 21:14 sun50i-h618-orangepi-zero3.dtb -rw-r--r-- 1 root root 39205 Feb 26 21:14 sun50i-h618-transpeed-8k618-t.dtb -rw-r--r-- 1 root root 41675 Feb 26 21:14 sun50i-h64-remix-mini-pc.dtb -rw-r--r-- 1 root root 39303 Feb 26 21:14 sun50i-h6-beelink-gs1.dtb -rw-r--r-- 1 root root 36421 Feb 26 21:14 sun50i-h6-inovato-quadra.dtb -rw-r--r-- 1 root root 38912 Feb 26 21:14 sun50i-h6-orangepi-3.dtb -rw-r--r-- 1 root root 39056 Feb 26 21:14 sun50i-h6-orangepi-3-lts.dtb -rw-r--r-- 1 root root 38643 Feb 26 21:14 sun50i-h6-orangepi-lite2.dtb -rw-r--r-- 1 root root 38172 Feb 26 21:14 sun50i-h6-orangepi-one-plus.dtb -rw-r--r-- 1 root root 39055 Feb 26 21:14 sun50i-h6-pine-h64.dtb -rw-r--r-- 1 root root 39082 Feb 26 21:14 sun50i-h6-pine-h64-model-b.dtb -rw-r--r-- 1 root root 36193 Feb 26 21:14 sun50i-h6-tanix-tx6.dtb -rw-r--r-- 1 root root 35970 Feb 26 21:14 sun50i-h6-tanix-tx6-mini.dtb -rw-r--r-- 1 root root 42815 Feb 26 21:14 sun50i-h700-anbernic-rg35xx-2024.dtb -rw-r--r-- 1 root root 45114 Feb 26 21:14 sun50i-h700-anbernic-rg35xx-h.dtb -rw-r--r-- 1 root root 43609 Feb 26 21:14 sun50i-h700-anbernic-rg35xx-plus.dtb -rw-r--r-- 1 root root 43965 Feb 26 21:14 sun50i-h700-anbernic-rg35xx-sp.dtb
hello, I check last weekend the ttyS1 but I don't see it root@domotique:~# ls -al /dev/ttyS* crw-rw---- 1 root dialout 4, 64 Mar 1 14:39 /dev/ttyS0 crw-rw---- 1 root dialout 4, 66 Mar 1 14:38 /dev/ttyS2 crw-rw---- 1 root dialout 4, 67 Mar 1 14:38 /dev/ttyS3 crw-rw---- 1 root dialout 4, 68 Mar 1 14:38 /dev/ttyS4 crw-rw---- 1 root dialout 4, 69 Mar 1 14:38 /dev/ttyS5 I check on the documentation and what I understand is ttys1 is reserve for bluetooth
Hello @Werner do you see any issue on my kern.log ? cordially
yes this is my kern.log ==> https://paste.armbian.de/fexawefitu.yaml
this is my armbianEnv verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-a64 rootdev=UUID=0d77ff8b-5921-4750-b8d9-0f342603cf32 rootfstype=ext4 extraargs=systemd.unified_cgroup_hierarchy=0 apparmor=1 security=apparmor overlays=uart1 uart2 uart3 uart4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
hello this is the link for armbianmonitor ==> https://paste.armbian.de/uhebiwesem cordially
Hello, I have an A64 2GB ( kickstarter ) with the zwave module in Uart on which I installed the latest version of armbian ( Armbian 24.11.1 Bookworm Minimal ) kernel 6.6.62-current-sunxi64 I have activated the Uart2 via armbian-config but I still can not connect via stty or MinOZW sudo MinOZW /dev/ttyS2 ERROR: Failed to set serial port parameters ERROR: Failed to open serial port /dev/ttyS2 sudo stty -F /dev/ttyS2 115200 Input/output error can you help me ?
