Void Spirit
  1. @Александр Соколов I installed different versions of Android. Successfully installed LibreELEC. But couldn't handle Armbian. I struggled with it for 3 weeks. I'm tired already. The only thing I didn't try was installing from USB. I installed everything from SD, from different SD cards. Can you please tell me, did you always have an image through HDMI when installing Armbian?
  2. @Александр Соколов Please look at the previous page. There is also a photo without a radiator. I connected it to the router. I accepted the IP address. I tried to connect via the windows command prompt, then through the Putty application. As a result, I scanned the network and found no open ports. I can capture the process on video. Главное шьётся на другие андроиды и на LibreELEC а мультитул никак не реагирует.
  3. Hello. I will respond to everyone with one message. @RaptorSDS Yes, the last link from this site. IP android tv 192.160.1.80 MAC ......79.81 From the SD card multitool IP 192.168.1.43 MAC ........fe:9b but when scanning ports, there are no free ones. Connection through Putty failed. @Alexander Sokolov Thank you for the links. I tried. But unfortunately, they didn't work either. Did you install it via a multitool or directly onto an SD card using balenaEtcher or Rufus? @jock Communicating through a translator. Incorrect translations of my text are possible. This is a board that indicates 2/16 S905W but in fact it is 1/8 RK322x. On the previous page, I sent screenshots. Screenshot number 8 aida64 with the original factory firmware. This is one tv box. Maybe I should have reverted to the factory firmware after LibreELEC but I don't have a dump.
  4. I tried to connect via ssh. the box provided the ip and mac address. I connected it like this: 1) lan option: PC -(lan)- router -(lan)- TV box. no connect. 2) Wi-Fi option: PC -(wifi)- router -(LAN)- TV box. no connect. Through the mobile application, Fing saw that the multitool did not have an open port. Although there are different IP and Mac addresses in multitool mode and Android mode. The multitool was downloaded from a link on this website
  5. Unfortunately, the indicator was always red. No flickering. The color changed only when the system was started (android). Is it possible to install Armbian via a USB cable?
  6. Hello everyone. I really need help. I've been trying to install Armbian for two weeks. I have an X96 Mini TV box (2/16 fake) and a real 1/8. I've installed several different versions of Android (7.1, 8.1, 10). I tried to install various multitools, but every time I get a black screen. I recorded the images using balenaEtcher. Then I successfully installed LibreELEC. It's possible that I was using incompatible Armbian images, but why can't I run the multitools?
  7. Hello. "rkdeveloptool wl 0x2000 u-boot-main.img" this line must be entered in the file itself "uboot.img" in the folder "bsp? Or just rename the file. please tell me more precisely. I don't understand at all. I've tried all kinds of multitool. Always a black screen
