danfoxley
  1. Correction to original post, I have typo and did not put in "plug" for plughw. aplay /usr/share/sounds/alsa/Side_Right.wav -D plughw:CARD=Audio,DEV=2
  2. Thanks! That was the issue. alsamixer > F4: Volume was low/off and Capture was not enabled (SPACEBar). Hitting the spacebar with the channel selected put the red text "CAPTURE".
  3. Can anyone point me in the right direction for an Armbian image that would allow audio recording over the 3.5mm jack? I'm trying to record audio over the 3.5mm jack. This works on a previous installation, but I'm trying to update to a curreent Armbian. Running Tinkerboard S R2.0 and this image: Armbian_25.2.1_Tinkerboard_noble_current_6.12.13_xfce_desktop.img Playback works record does not. Works: aplay /usr/share/sounds/alsa/Side_Right.wav -D hw:CARD=Audio,DEV=2 None of the following arecord commands work: arecord --vumeter=mono -D hw:CARD=Audio,DEV=0 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D hw:CARD=Audio,DEV=1 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D plughw:CARD=Audio,DEV=0 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D plughw:CARD=Audio,DEV=1 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D default:CARD=Audio -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D sysdefault:CARD=Audio -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D front:CARD=Audio,DEV=0 -f S16_LE -c 2 -d 5 /tmp/t.wav
