Hi,
	When I tried to compile the image I got this error
[๐ฑ] Starting single build process [ x96q-tvbox ]
[๐ฑ] Checking [ basic host setup ]
[๐ฑ] Build host OS release [ jammy ]
[๐ฑ] Build host architecture [ amd64 ]
[๐ฅ] error! [ No such BOARD 'x96q-tvbox'; no board config file found.  ]
[๐ฅ] Exiting with error 43 [ at /content/armbian-build/lib/functions/logging/traps.sh:1
                exit_with_error() --> lib/functions/logging/traps.sh:1
       config_source_board_file() --> lib/functions/main/config-prepare.sh:130
                do_with_logging() --> lib/functions/logging/section-logging.sh:81
    do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111
    prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:23
         cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22
        armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136
                 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176
                           main() --> ./armbian-build/compile.sh:50
[๐ฅ] Cleaning up [ please wait for cleanups to finish ]
[๐ฟ] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-no-uuidgen-yet-26314-4689.log.ans ]
[๐ฟ] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-no-uuidgen-yet-26314-4689.log.ans https://paste.armbian.com/log ]
	P.S
	oh i just noticed the 2nd post, problem solved
