konsD
  1. Is the topic still relevant? I'm also trying to connect ST7735S + OPI Z3. But my screen doesn't even light up. I checked the screen on the ESP - it's working. There is no clear description anywhere of what packages need to be installed on the system. I would like to display information about the system on the screen
  2. Hi. Do you see it when connected via ssh?
  3. Thank you! This is what I needed. Easy to set up.
  4. I understand that. It can probably be done with /lib/systemd/system/docker.service? I used to install the nextcloud manually, but it was very tedious. I don't know docker at all, so I have difficulties with it Where can I see the error logs?
  5. It may be possible to change the mount parameters of an already installed docker container. Is it possible to add mount options?
  6. Hello. I am a new user of the armbian. I installed nextcloud from armbian-config. Need docker to have access to the file system. I want to place the nextcloud files in the home directory, which is mounted on another partition. I don't understand how to give docker access to my file system. I didn't find the necessary setting in armbian-config. I'm stuck on initial setup
