7 -
The patch doesn't build against rockchip64 6.12 -- and looking at the patch it doesn't affect the RK35XX series at all. To port it, I think I need the max_prate constants for the RK3566 (is this in clk_rk3568.c? or some other file, there isn't a clk_rk3566.c) I think the datasheet (https://www.boardcon.com/download/Rockchip_RK3566_Datasheet_V1.1.pdf) says it's 600MHz for HDMI
After testing it with verbosity=7 on both vendor and current, there's nothing suspicious in the kernel logs -- on vendor, I get: root@radxa-zero3:~# journalctl -k -b 0 | grep -iE 'hdmi|drm|gpu|edid|cec' Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 08 11:26:19 radxa-zero3 kernel: platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000 Apr 08 11:26:19 radxa-zero3 kernel: [drm] all windows should be assigned, full plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], current plane mask: [0x0 Apr 08 11:26:19 radxa-zero3 kernel: [drm] use default plane mask Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: [drm] failed to init overlay plane Cluster0-win1 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff80000939a0c0) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000093b2958) Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: failed to parse loader memory Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1280x720p60, type: 11(if:HDMI0, flag:0x0) for vp0 dclk: 74250000 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 74250000, get 74250000 Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] run display error_event monitor Apr 08 11:26:19 radxa-zero3 kernel: Registered IR keymap rc-cec Apr 08 11:26:19 radxa-zero3 kernel: rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0 Apr 08 11:26:19 radxa-zero3 kernel: input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0 Apr 08 11:26:19 radxa-zero3 kernel: input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input1 Apr 08 11:26:19 radxa-zero3 kernel: vdd_gpu: supplied by vcc_sys Apr 08 11:26:19 radxa-zero3 kernel: vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled Apr 08 11:26:19 radxa-zero3 kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Kernel DDK version g25p0-00eac0 Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: error -ENXIO: IRQ JOB not found Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: error -ENXIO: IRQ MMU not found Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: error -ENXIO: IRQ GPU not found Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Insufficient register space, will override to the required size Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Register window unavailable Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Failed to map registers Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Register map failed error = -5 Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Device initialization failed Apr 08 11:26:19 radxa-zero3 kernel: mali: probe of fde60000.gpu failed with error -5 Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: #0: rockchip-hdmi0 Apr 08 11:26:19 radxa-zero3 systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... Apr 08 11:26:19 radxa-zero3 systemd[1]: modprobe@drm.service: Deactivated successfully. Apr 08 11:26:19 radxa-zero3 systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: clock rate = 594000000 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: bus_clock rate = 500000000 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: Looking up mali-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1 Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 1 Apr 08 11:29:48 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:29:48 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid And on the failing one, just the same old: Apr 09 22:04:32 radxa-zero3 kernel: /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 09 22:04:32 radxa-zero3 kernel: /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000 Apr 09 22:04:32 radxa-zero3 kernel: /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con Apr 09 22:04:32 radxa-zero3 kernel: /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) Apr 09 22:04:32 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 09 22:04:32 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) Apr 09 22:04:32 radxa-zero3 kernel: [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes So I suspect there's some EDID problem. (I'll try forcing EDID next, but I have a few more boards ordered to see if it's a hardware problem or not (or is this a sneaky way of making me buy more CAD$60 boards...)
Here are the logs on the vendor side (grepping for drm and edid): root@radxa-zero3:~# journalctl -k -b 0 | grep -e hdmi -e drm Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 08 11:26:19 radxa-zero3 kernel: platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000 Apr 08 11:26:19 radxa-zero3 kernel: [drm] all windows should be assigned, full plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], current plane mask: [0x0 Apr 08 11:26:19 radxa-zero3 kernel: [drm] use default plane mask Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: [drm] failed to init overlay plane Cluster0-win1 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff80000939a0c0) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000093b2958) Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: failed to parse loader memory Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1280x720p60, type: 11(if:HDMI0, flag:0x0) for vp0 dclk: 74250000 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 74250000, get 74250000 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] run display error_event monitor Apr 08 11:26:19 radxa-zero3 kernel: rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0 Apr 08 11:26:19 radxa-zero3 kernel: input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0 Apr 08 11:26:19 radxa-zero3 kernel: input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input1 Apr 08 11:26:19 radxa-zero3 kernel: #0: rockchip-hdmi0 Apr 08 11:26:19 radxa-zero3 systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... Apr 08 11:26:19 radxa-zero3 systemd[1]: modprobe@drm.service: Deactivated successfully. Apr 08 11:26:19 radxa-zero3 systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 1 Apr 08 11:28:40 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid root@radxa-zero3:~# This happens on multiple monitors and cables.
I disassembled my other radxa and swapped the SD cards, and it is just something funny with this hardware. I also just realized I bought a different configuration -- the one that works with `current` is a 2GB RAM version, and the one that has no HDMI (except on `vendor`) is a 4GB RAM version. I wonder if there are hardware differences.
So I have two boards, and two images, both built with armbian-build. I built `current` on March 24th 2025 and HDMI and everything works great I built one this week and there is no HDMI output. Logs of the non-working one: Apr 07 18:36:09 radxa-zero3 kernel: mmc2: new UHS-I speed SDR104 SDIO card at address 390b Apr 07 18:36:09 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: registered as rtc0 Apr 07 18:36:09 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:00:10 UTC (1501923610) Apr 07 18:36:09 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: Adding to iommu group 0 Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) Apr 07 18:36:09 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 07 18:36:09 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) Apr 07 18:36:09 radxa-zero3 kernel: [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Logs of the working one: Mar 24 21:17:04 radxa-zero3 kernel: mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) Mar 24 21:17:04 radxa-zero3 kernel: dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 150 Mar 24 21:17:04 radxa-zero3 kernel: mmc2: new ultra high speed SDR104 SDIO card at address 390b Mar 24 21:17:04 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: Adding to iommu group 0 Mar 24 21:17:04 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: registered as rtc0 Mar 24 21:17:04 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) Mar 24 21:17:04 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:00:10 UTC (1501923610) Mar 24 21:17:04 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Mar 24 21:17:04 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Mar 24 21:17:04 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) Mar 24 21:17:04 radxa-zero3 kernel: [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 Mar 24 21:17:04 radxa-zero3 kernel: Console: switching to colour frame buffer device 240x67 Mar 24 21:17:04 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device On the non-working one, I've tried both the same kernel version (6.12.20) as well as the most recent `current` (6.12.21), and edge (6.14.1). Buildling a vendor image on bookworm works fine. Given I have two systems where one works and one doesn't, what can I check between them (deb package versions maybe? DTB files?) to help debug this?
