Popolon
14 -
Works just fine on last version. Thanks a lot !!! <pre> $ zcat /proc/config.gz | grep DP| grep ROCK CONFIG_ROCKCHIP_ANALOGIX_DP=y CONFIG_ROCKCHIP_CDN_DP=y CONFIG_ROCKCHIP_DW_DP=y CONFIG_PHY_ROCKCHIP_DP=y CONFIG_PHY_ROCKCHIP_DPHY_RX0=m CONFIG_PHY_ROCKCHIP_INNO_CSIDPHY=m CONFIG_PHY_ROCKCHIP_INNO_DSIDPHY=m CONFIG_PHY_ROCKCHIP_SAMSUNG_HDPTX=m CONFIG_PHY_ROCKCHIP_USBDP=m CONFIG_PHY_ROCKCHIP_DP=y </pre>
Armbian doesnt seem to see sata harddrives.
Popolon replied to DontMindMe's topic in Radxa Rock 5 ITX
SCSI works fine with linux Mainline at least (6.16, 6.17 & 6.18) since few month now. -
Getting vlc to play nice with pulseaudio
Popolon replied to Reluctant Linux User's topic in Radxa Rock 5 ITX
I'm not sure vulkan is the best solution, RK3588, as most ARM SoCs has a dedicated video engine, vulkan is mainly needed on hardware without dedicated engine, using graphic card to decode, as it's often the case in x86_64 worlld. You can then including it's decoding in vulkan if you want. Don't know wich version of kernel/mesa/video decoder you use. The best, is to remove all dedicated package, and use system one, today, everything work fine with standard linux kernel, as armbian one, standard video tools, rockchip specific libs/video tools was used with rockchip made tools, until everything was mainlined. I don' use VLC, that needs specific libs, but mpv, or several other video players (including firefox one), and everything plays fine. -
The HDMI0(Port next to Headphone Jack) is driven by DP1 on rk3588 via RA620(a dp2hdmi converter). https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/arch/arm64/boot/dts/rockchip?h=v6.18&id=07c53a9e970712b1a479dd0ec4adfe184482c22f ROCKCHIP_DW_DP is needed in order to have working 2nd HDMI port. In menuconfig : Device Drivers ---> Direct Rendering Manager (XFree86 4.Graphics support ---> 1.0 and higher DRI support) ---> Rockchip specific extensions for Synopsys DW DP <pre> │ CONFIG_ROCKCHIP_DW_DP: │ │ │ │ This selects support for Rockchip SoC specific extensions │ │ to enable Synopsys DesignWare Cores based DisplayPort transmit │ │ controller support on Rockchip SoC, If you want to enable DP on │ │ rk3588 based SoC, you should select this option. │ │ │ │ Symbol: ROCKCHIP_DW_DP [=n] │ </pre> https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/arch/arm64/boot/dts/rockchip/rk3588-extra.dtsi?h=v6.18&id=64566e35757faded57a65d65e84b5ca95974ee19
Sorry that was resolved 2 days ago, but I don't see and never seen this long list. Only 3 options vendor 6.1, 6.12 and edge (6.16), This morning I also seen the u-boot wasn't the good one. I downloaded for rock5-itx, but had linux-u-boot-cyber-aib-rk3588-edge instead of linux-u-boot-rock-5-itx-edge, changed it, rebooted (on 6.16) worked, tried again 6.12, still no display. I needed to arch-chroot on the armbian to take a screenshot (but I've the same dispay on armbian itself): I seen 6.16.4 is now available and work, after /boot/config-6.16.4-edge-rockchip64, gcc 13.3.0 is now again used instead of old 11.x :). Debian Trixie has GCC 14.2.0 CONFIG_CC_VERSION_TEXT="aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0" And after changelog on kernel.org, patch for AV1 acceleration had been applied on this version: https://cdn.kernel.org/pub/linux/kernel/v6.x/ChangeLog-6.16.4 Fixes: 003afda97c65 ("media: verisilicon: Enable AV1 decoder on rk3588") Sorry I maybe mix too much subjects in the same post, but: I also seen a minimal IoT version of Trixie for Rock5-itx. Can I made safely a debian os upgrade from apt? Or is it better to wait release for desktop version ? Another point. On armbian, only LLVMpipe is used, I compiled last mesa git on arch, will try to do this for debian too. and some application that need to use EGL+dri (wings3D, blender, obs) report broken DRI2 access. I'm not sure if it's due to some kernel patchs (I reuse the armbian 6.16 kernel on arch), or to the current state of mesa-git. They all works with llvmpipe. Othere applications like PPSSPPSDL work fine without it. Ex, with wings3d + forced zink: MESA_LOADER_DRIVER_OVERRIDE=zink GALLIUM_DRIVER=zink wings3d WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance libEGL warning: egl: failed to create dri2 screen WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance -
Today armbian-config doesn't show other kernels, it's impossible to switch. * Show only mainstream kernels on the list? => no * No other kernels available! => ok -
Last try of 6.12 1 or 2 weeks ago, was still with display failure. 6.1 works fine, now, with both HDMI out and I believe SATA working at each boot. I believe than since your last change SATA works far better with 6.1 vendor kernel. I'm mainly using the 6.16rc7 armbian kernel on archlinux now where I compile time to time last mesa git, to take benefits of more GL features, Vulkan 1.4 support + zink, however some softwares like obs studio, blender, wings3D, GTK4-demos fails with zink, due to problems with broken DRI. X11 have some slowdown too, but Wayland is perfectly smooth with mainline kernel + mesa drivers. noticed that 6.16.0 was compiled with GCC11, where 6.16rc7 was compiled with GCC13.3, there is a lot of optimizations in perfs between the two GCC releases, and Debian13 is now shiped with GCC 14.2. kernel 6.17rc1 bring AV1 accelerated video on RK3588. and rc2 is now released, I don't know if there are projects to upgrade mainline kernel and/or Debian version? Debian is sadely shipped with Mesa 25.1.0. Vulkan 1.4 support was reached with Mesa 25.2. It is however maybe more stable, I didn't tried 25.1.0 stable? -
Tried again kernel 6.12, still no display, and it looks, like SATA instability depend on kernel version for 6.1 and have to stop/start several time the power to have it work on recent one. A bit tired of this too. It will probably not be good for the hardware to start/shutdown several time the power. After SATA disks are up they work parfectly. Looks like a power management bug, but not sure? -
Here is the dmesg log in this case armbian-6.1-416.all_ok.txt -
With armbian kernel 6.1, version 25.5.0-trunk.416, I've again both SATA, 2 HDMI output ports, and best currently available GL acceleration. -
I both cases I copied the dmesg file: * 6.1_noSATA.txt (both hdmi, no sata) (400/401, no more SATA), was the best 2 days ago (~390 good GL accelaration, sata+2 HDMI out + HDMI in) * 6.12_noHDMI.txt (no hdmi, sata) * 6.15_noHDMI.txt (hdmi only left port, sata) 6.15 booting, when wire was connected on right port: [ 2.383100] rockchip-drm display-subsystem: bound fdd90000.vop (ops rockchip_drm_fini [rockchipdrm]) [ 2.397151] dwhdmiqp-rockchip fdea0000.hdmi: registered DesignWare HDMI QP I2C bus driver [ 2.397431] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops rockchip_drm_fini [rockchipdrm]) [ 2.403676] usb 1-1.4: new low-speed USB device number 3 using ehci-platform [ 2.411243] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 1 [ 2.411291] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 2.411330] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes grep -i hdmi 6.12_noHDMI.txt => nothing grep -i hdmi 6.1_noSATA.txt [ 8.759715] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fdea0000 [ 8.759747] platform fdea0000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 9.889229] phy phy-fed60000.hdmiphy.9: Looking up phy-supply from device tree [ 9.889236] phy phy-fed60000.hdmiphy.9: Looking up phy-supply property in node /hdmiphy@fed60000 failed [ 9.890012] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 9.890208] phy phy-fed70000.hdmiphy.10: Looking up phy-supply from device tree [ 9.890215] phy phy-fed70000.hdmiphy.10: Looking up phy-supply property in node /hdmiphy@fed70000 failed [ 9.890965] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success [ 9.954935] dwhdmi-rockchip fdea0000.hdmi: Looking up avdd-0v9-supply from device tree [ 9.954945] dwhdmi-rockchip fdea0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fdea0000 failed [ 9.954957] dwhdmi-rockchip fdea0000.hdmi: Looking up avdd-1v8-supply from device tree [ 9.954965] dwhdmi-rockchip fdea0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fdea0000 failed [ 9.955465] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver [ 9.956114] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffff8000093b2958) [ 10.324345] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.2.auto: dw_hdcp_qp_hdcp_probe success [ 10.325032] rc rc0: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc0 [ 10.325144] input: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc0/input0 [ 10.419959] rk_hdmirx fdee0000.hdmirx-controller: No reserved memory for HDMIRX, use default CMA [ 10.419979] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_get_phy_cpuid_func: mpidr: 0x0000000500, phy_cpuid:0x5 [ 10.419994] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_probe: cpu_aff:0x500, Bound_cpu:5, wdt_cfg_bound_cpu:2, phy_cpuid:5 [ 10.421528] rk_hdmirx fdee0000.hdmirx-controller: rk_hdmirx_hdcp_register success [ 10.421554] rk_hdmirx fdee0000.hdmirx-controller: fdee0000.hdmirx-controller driver probe ok! [ 10.499993] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card0/input1 [ 10.500682] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/dp0-sound/sound/card1/input2 [ 10.501573] input: rockchip-hdmi2 rockchip-hdmi2 as /devices/platform/dp1-sound/sound/card2/input3 [ 10.514194] input: rockchip-hdmiin rockchip-hdmiin as /devices/platform/hdmiin-sound/sound/card3/input4 [ 10.674959] rockchip-dmc dmc: hdmirx_rate = 2400000000 [ 10.765472] #0: rockchip-hdmi1 [ 10.765482] #1: rockchip-hdmi0 [ 10.765490] #2: rockchip-hdmi2 [ 10.765498] #3: rockchip-hdmiin [ 12.561199] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add grep -i sata 6.1 => nothing grep -i sata 6.12/6.15, give the same lines: [ 4.181816] ahci 0001:11:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode [ 4.206376] ata1: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282100 irq 160 lpm-pol 0 [ 4.206388] ata2: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282180 irq 160 lpm-pol 0 [ 4.206398] ata3: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282200 irq 160 lpm-pol 0 [ 4.206407] ata4: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282280 irq 160 lpm-pol 0 [ 4.206437] ata9: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282500 irq 160 lpm-pol 0 [ 4.206445] ata10: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282580 irq 160 lpm-pol 0 [ 4.206453] ata11: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282600 irq 160 lpm-pol 0 [ 4.206462] ata12: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282680 irq 160 lpm-pol 0 [ 4.206470] ata13: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282700 irq 160 lpm-pol 0 [ 4.206479] ata14: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282780 irq 160 lpm-pol 0 [ 4.206487] ata15: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282800 irq 160 lpm-pol 0 [ 4.206495] ata16: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282880 irq 160 lpm-pol 0 [ 4.206504] ata17: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282900 irq 160 lpm-pol 0 [ 4.206512] ata18: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282980 irq 160 lpm-pol 0 [ 4.206520] ata19: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282a00 irq 160 lpm-pol 0 [ 4.206528] ata20: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282a80 irq 160 lpm-pol 0 [ 4.206537] ata21: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282b00 irq 160 lpm-pol 0 [ 4.206545] ata22: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282b80 irq 160 lpm-pol 0 [ 4.206553] ata23: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282c00 irq 160 lpm-pol 0 [ 4.206561] ata24: SATA max UDMA/133 abar m8192@0xf1282000 port 0xf1282c80 irq 160 lpm-pol 0 [ 10.059389] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 10.374890] ata2: SATA link down (SStatus 0 SControl 300) [ 10.686794] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 11.002741] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 11.319039] ata9: SATA link down (SStatus 0 SControl 300) [ 11.631097] ata10: SATA link down (SStatus 0 SControl 300) [ 11.943048] ata11: SATA link down (SStatus 0 SControl 300) [ 12.255094] ata12: SATA link down (SStatus 0 SControl 300) [ 12.567104] ata13: SATA link down (SStatus 0 SControl 300) [ 12.878769] ata14: SATA link down (SStatus 0 SControl 300) [ 13.190881] ata15: SATA link down (SStatus 0 SControl 300) [ 13.502881] ata16: SATA link down (SStatus 0 SControl 300) [ 13.814880] ata17: SATA link down (SStatus 0 SControl 300) [ 14.126879] ata18: SATA link down (SStatus 0 SControl 300) [ 14.438881] ata19: SATA link down (SStatus 0 SControl 300) [ 14.750834] ata20: SATA link down (SStatus 0 SControl 300) [ 15.062884] ata21: SATA link down (SStatus 0 SControl 300) [ 15.375003] ata22: SATA link down (SStatus 0 SControl 300) [ 15.687007] ata23: SATA link down (SStatus 0 SControl 300) [ 15.999009] ata24: SATA link down (SStatus 0 SControl 300) 6.1_noSATA.txt 6.12_noHDMI.txt 6.15_noHDMI.txt -
So display didn't work, on both 6.12 and 6.15, but in both case, I had SATA (connecter via ssh from another local network host). I , so rebooted on 6.1 and then : * I had a 640*480 display, when I would like to change the resolution, with xfce4-display-settings, It shown only a display port (edp), ant was able only choice in menu to resolution lower than Full HD, something like 1024×768 (didn't write it sorry). I then plugged on the other port (at left) and it worked in full HD. the right one I use usally doesn't work anymore, strangely. I tried again 6.15 kernel, and have both display and SATA on this kernel :), but the right connector doesn't display anything (don't care for now) linux-dtb-edge-rockchip64 25.5.0-trunk.401 /boot/dtb-6.15.0-rc1-edge-rockchip64 But display is a bit slower, GL output has some slow dowsn every hal seconds. -
SATA worked perfectly for me, during few days on kernel armbian unstable 25.5.0-trunk ( 6.1.99, codename "Curry Ramen" drivers), until yesterday with update 400 and 401. All other things works but Wifi. I use armbian Bookworm. I will try with 6.12 so. Have a serial wire and know how to use it. -
Hi, same problem here, however kwankiu archlinux that use the same release of the kernel has working SATA. Maybe it's patchs or options could be used as references? Didn't looked at the reboot issue. On the other side Arch for ARM is far more limited than other Arch Linux flavor I use (x86_64 and RISC-V), strangely there is not even GL acceleration (only vulkan-panfrost is compiled). Armbian as far more complete package set. I would like to have a Trixie version to cross compile some RISC-V things, as GCC12 included in Bookworm What, uname sees as kernel: Armbian (no SATA but GL acceleration): Linux rock-5-itx 6.1.99-vendor-rk35xx #1 SMP Wed Mar 19 11:16:36 UTC 2025 aarch64 GNU/Linux Archlinux (SATA, but no GL acceleration) Linux armitx 6.1.99-rockchip #1 SMP Fri Feb 28 19:07:25 HKT 2025 aarch64 GNU/Linux zgrep SATA give the same options set: <pre> $ zgrep SATA config.gz CONFIG_SATA_HOST=y CONFIG_SATA_PMP=y CONFIG_SATA_AHCI=y CONFIG_SATA_MOBILE_LPM_POLICY=0 CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set # CONFIG_SATA_SIL24 is not set $ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 1,8T 0 disk ├─sda1 8:1 0 47,7G 0 part ├─sda2 8:2 0 47,7G 0 part ├─sda3 8:3 0 1,7T 0 part └─sda4 8:4 0 6G 0 part sdb 8:16 0 2,7T 0 disk ├─sdb1 8:17 0 50G 0 part ├─sdb2 8:18 0 2,7T 0 part └─sdb3 8:19 0 2G 0 part mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 7,3G 0 disk ├─mmcblk0p1 179:1 0 16M 0 part ├─mmcblk0p2 179:2 0 300M 0 part └─mmcblk0p3 179:3 0 7G 0 part mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk mmcblk1 179:96 0 28,9G 0 disk ├─mmcblk1p1 179:97 0 16M 0 part └─mmcblk1p2 179:98 0 28,8G 0 part / nvme0n1 259:0 0 238,5G 0 disk └─nvme0n1p1 259:1 0 236,1G 0 part </pre>
