Frank White
  1. Any tip to getting HDMI audio to work on version 5.1 of the board?
  2. Off topic question but I don't suppose you could point me in the right direction to get openwrt installed on my device?
  3. Everything seemed to work except sound. Thanks for your help. My first impression is that while super cool, the hardware isn't up to the task of running a desktop OS. I'm going to try out the server version and see how that does.
  4. Not sure I did this correctly but here's what I got. dtb.0.dts
  5. Here's my board. I will get dmesg in a bit. I guess it's the XR819 chip.
  6. Hi Nick, I was able to burn the following image to my SD card and it booted up perfectly. I have version 5.1 of the board. The only problem I noticed is neither the wifi nor ethernet port were working. Any tips? Armbian-unofficial_25.05.0-trunk_X96q-ddr3-v5-1_noble_edge_6.12.11_xfce_desktop.img.xz
  7. I would like to try this. How should I format and write the image the SD card? Can I just use Raspberry Pi imager? I want to make sure I'm doing it right before I crack open the case to look at the chipset.
