Hi @ all,
long time reader, but never managed to register.
Now it is time... as I'm not able to solve this myself, kindly asking for help.
I'm stuck, my Orangepi 5 plus stops boot at this:
Loading, please wait...
Starting systemd-udevd version 252.36-1~deb12u1
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... (initramfs)
What happened before?
Last year I bought the Orangepi 5 plus (8GB) and went ahead, testing everything out - having incredible fun with this little box.
But with a way to old/slow sd card which finally failed two or three months ago.
I went ahead and wrote the Armbian based Cinnamon (Kernel 6.1 incl. MESA/VPU) to a new SD Card.
Everything was working flawless, but still ... SD Card.
Therefore I bought a 1TB nvme, installed it and used armbian-install to
install the bootloader on MTD Flash. Afterwards I got everything working from nvme.
Amazing results, it just worked after armbian-install was finished.
I shut down the system, removed SD card and used the nvme install from now on for weeks on a daily basis.
Several apt-get dist-upgrades no problem at all.
The last one done Sunday, if I remember correctly.
Until today.
I had some spare time and decided to apt-get update and apt-get dist-upgrade again.
The commands finished without any error and new updates were done.
But now -I wanted to reboot the device- reboot stalled.
I see a black screen with above mentioned white text.
So, something must have gone wrong I think.
The Orangepi boots fine when I insert the SD Card again, also the nvme is there and can be mounted.
Seemingly all data is still there.
But how to proceed? I'm at a loss.
Can anything be done on my side to solve this? Or is a reinstall to be done?
The apt history logfile on the nvme (/var/logs/apt/history.log) contains both upgrades I mentioned and reads:
Start-Date: 2025-04-01 16:15:10
Commandline: apt-get dist-upgrade
Requested-By: edited (1000)
Upgrade: armbian-config:arm64 (25.5.0-trunk.286.0324.065110, 25.5.0-trunk.325.0401.114753), tzdata:arm64 (2025a-0+deb12u1, 2025b-0+deb12u1), firefox-nightly:arm64 (138.0a1~20250324091950, 139.0a1~20250401094015), ghostscript-x:arm64 (10.0.0~dfsg-11+deb12u6, 10.0.0~dfsg-11+deb12u7), libgs10-common:arm64 (10.0.0~dfsg-11+deb12u6, 10.0.0~dfsg-11+deb12u7), libgs10:arm64 (10.0.0~dfsg-11+deb12u6, 10.0.0~dfsg-11+deb12u7), ghostscript:arm64 (10.0.0~dfsg-11+deb12u6, 10.0.0~dfsg-11+deb12u7), linux-headers-vendor-rk35xx:arm64 (25.2.3, 25.2.3), libgs-common:arm64 (10.0.0~dfsg-11+deb12u6, 10.0.0~dfsg-11+deb12u7)
End-Date: 2025-04-01 16:15:46
Start-Date: 2025-04-02 09:42:43
Upgrade: linux-image-vendor-rk35xx:arm64 (25.2.3, 25.2.3), firefox-nightly:arm64 (139.0a1~20250401094015, 139.0a1~20250401212749), linux-headers-vendor-rk35xx:arm64 (25.2.3, 25.2.3), armbian-bsp-cli-orangepi5-plus-vendor:arm64 (25.2.2, 25.2.3)
End-Date: 2025-04-02 09:44:34
term.log in this directory shows nothing unusual, too. As far as my limited knowledge reaches ofc:
Log started: 2025-04-01 16:15:10
(Reading database ... 218528 files and directories currently installed.)
Preparing to unpack .../0-tzdata_2025b-0+deb12u1_all.deb ...
Unpacking tzdata (2025b-0+deb12u1) over (2025a-0+deb12u1) ...
Preparing to unpack .../1-armbian-config_25.5.0-trunk.325.0401.114753_all.deb ...
Unpacking armbian-config (25.5.0-trunk.325.0401.114753) over (25.5.0-trunk.286.0324.065110) ...
Preparing to unpack .../2-firefox-nightly_139.0a1~20250401094015_arm64.deb ...
Unpacking firefox-nightly (139.0a1~20250401094015) over (138.0a1~20250324091950) ...
Preparing to unpack .../3-ghostscript-x_10.0.0~dfsg-11+deb12u7_arm64.deb ...
Unpacking ghostscript-x:arm64 (10.0.0~dfsg-11+deb12u7) over (10.0.0~dfsg-11+deb12u6) ...
Preparing to unpack .../4-ghostscript_10.0.0~dfsg-11+deb12u7_arm64.deb ...
Unpacking ghostscript (10.0.0~dfsg-11+deb12u7) over (10.0.0~dfsg-11+deb12u6) ...
Preparing to unpack .../5-libgs10_10.0.0~dfsg-11+deb12u7_arm64.deb ...
Unpacking libgs10:arm64 (10.0.0~dfsg-11+deb12u7) over (10.0.0~dfsg-11+deb12u6) ...
Preparing to unpack .../6-libgs10-common_10.0.0~dfsg-11+deb12u7_all.deb ...
Unpacking libgs10-common (10.0.0~dfsg-11+deb12u7) over (10.0.0~dfsg-11+deb12u6) ...
Preparing to unpack .../7-libgs-common_10.0.0~dfsg-11+deb12u7_all.deb ...
Unpacking libgs-common (10.0.0~dfsg-11+deb12u7) over (10.0.0~dfsg-11+deb12u6) ...
Preparing to unpack .../8-linux-headers-vendor-rk35xx_25.2.3_arm64.deb ...
Armbian 'linux-headers-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'prerm' starting.
Cleaning directory /usr/src/linux-headers-6.1.99-vendor-rk35xx ...
Armbian 'linux-headers-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'prerm' finishing.
Armbian 'linux-headers-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'preinst' starting.
Armbian 'linux-headers-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'preinst' finishing.
Unpacking linux-headers-vendor-rk35xx (25.2.3) over (25.2.3) ...
Setting up libgs-common (10.0.0~dfsg-11+deb12u7) ...
Setting up linux-headers-vendor-rk35xx (25.2.3) ...
Armbian 'linux-headers-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'postinst' starting.
Configuring kernel-headers (6.1.99-vendor-rk35xx) - please wait ...
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
YACC scripts/kconfig/parser.tab.[ch]
HOSTCC scripts/kconfig/lexer.lex.o
HOSTCC scripts/kconfig/menu.o
HOSTCC scripts/kconfig/parser.tab.o
HOSTCC scripts/kconfig/preprocess.o
HOSTCC scripts/kconfig/symbol.o
HOSTCC scripts/kconfig/util.o
HOSTLD scripts/kconfig/conf
# configuration written to .config
Compiling kernel-headers scripts (6.1.99-vendor-rk35xx) using 8 CPUs - please wait ...
SYNC include/config/auto.conf.cmd
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
LEX scripts/dtc/dtc-lexer.lex.c
YACC scripts/dtc/dtc-parser.tab.[ch]
HOSTCC scripts/dtc/libfdt/fdt.o
HOSTCC scripts/dtc/libfdt/fdt_ro.o
HOSTCC scripts/dtc/libfdt/fdt_wip.o
HOSTCC scripts/dtc/libfdt/fdt_sw.o
HOSTCC scripts/dtc/libfdt/fdt_rw.o
HOSTCC scripts/dtc/libfdt/fdt_strerror.o
HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o
HOSTCC scripts/dtc/libfdt/fdt_addresses.o
HOSTCC scripts/dtc/libfdt/fdt_overlay.o
HOSTCC scripts/dtc/fdtoverlay.o
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/fdtoverlay
HOSTLD scripts/dtc/dtc
HOSTCC scripts/kallsyms
HOSTCC scripts/sorttable
HOSTCC scripts/resource_tool
HOSTCC scripts/asn1_compiler
HOSTCC scripts/genksyms/genksyms.o
YACC scripts/genksyms/parse.tab.[ch]
HOSTCC scripts/selinux/mdp/mdp
HOSTCC scripts/selinux/genheaders/genheaders
LEX scripts/genksyms/lex.lex.c
HOSTCC scripts/genksyms/parse.tab.o
HOSTCC scripts/genksyms/lex.lex.o
HOSTLD scripts/genksyms/genksyms
Compiling kernel-headers scripts/mod (6.1.99-vendor-rk35xx) using 8 CPUs - please wait ...
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
CC scripts/mod/devicetable-offsets.s
UPD scripts/mod/devicetable-offsets.h
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/modpost.o
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
MODPOST scripts/mod/Module.symvers
Done compiling kernel-headers (6.1.99-vendor-rk35xx).
Done compiling kernel-headers tools (6.1.99-vendor-rk35xx).
Armbian 'linux-headers-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'postinst' finishing.
Setting up tzdata (2025b-0+deb12u1) ...
Current default time zone: 'Europe/Berlin'
Local time is now: Tue Apr 1 16:15:44 CEST 2025.
Universal Time is now: Tue Apr 1 14:15:44 UTC 2025.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up armbian-config (25.5.0-trunk.325.0401.114753) ...
Setting up firefox-nightly (139.0a1~20250401094015) ...
Setting up libgs10-common (10.0.0~dfsg-11+deb12u7) ...
Setting up libgs10:arm64 (10.0.0~dfsg-11+deb12u7) ...
Setting up ghostscript (10.0.0~dfsg-11+deb12u7) ...
Setting up ghostscript-x:arm64 (10.0.0~dfsg-11+deb12u7) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.36-9+deb12u10) ...
Processing triggers for man-db (2.11.2-2) ...
Log ended: 2025-04-01 16:15:46
Log started: 2025-04-02 09:42:43
(Reading database ... 218527 files and directories currently installed.)
Preparing to unpack .../armbian-bsp-cli-orangepi5-plus-vendor_25.2.3_arm64.deb ...
Armbian 'armbian-bsp-cli-orangepi5-plus-vendor' for '1-PCe1b9-V4064-H2670-B1e5d-R756d': 'preinst' starting.
Armbian 'armbian-bsp-cli-orangepi5-plus-vendor' for '1-PCe1b9-V4064-H2670-B1e5d-R756d': 'preinst' finishing.
Unpacking armbian-bsp-cli-orangepi5-plus-vendor (25.2.3) over (25.2.2) ...
Armbian 'armbian-bsp-cli-orangepi5-plus-vendor' for '1-PC7d0b-Vcff1-H2670-B6e44-R89c9': 'postrm' starting.
Armbian 'armbian-bsp-cli-orangepi5-plus-vendor' for '1-PC7d0b-Vcff1-H2670-B6e44-R89c9': 'postrm' finishing.
Preparing to unpack .../firefox-nightly_139.0a1~20250401212749_arm64.deb ...
Unpacking firefox-nightly (139.0a1~20250401212749) over (139.0a1~20250401094015) ...
Preparing to unpack .../linux-headers-vendor-rk35xx_25.2.3_arm64.deb ...
Preparing to unpack .../linux-image-vendor-rk35xx_25.2.3_arm64.deb ...
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'prerm' starting.
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'prerm' finishing.
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'preinst' starting.
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'preinst' finishing.
Unpacking linux-image-vendor-rk35xx (25.2.3) over (25.2.3) ...
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'postrm' starting.
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'postrm' finishing.
Setting up linux-image-vendor-rk35xx (25.2.3) ...
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'postinst' starting.
dkms: running auto installation service for kernel 6.1.99-vendor-rk35xx.
dkms: autoinstall for kernel: 6.1.99-vendor-rk35xx.
update-initramfs: Generating /boot/initrd.img-6.1.99-vendor-rk35xx
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.1.99-vendor-rk35xx
Image Name: uInitrd
Created: Wed Apr 2 09:43:11 2025
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 17096044 Bytes = 16695.36 KiB = 16.30 MiB
Load Address: 00000000
Entry Point: 00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.1.99-vendor-rk35xx to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.1.99-vendor-rk35xx'
update-initramfs: Armbian: done.
Armbian: update last-installed kernel symlink to 'Image'...
'/boot/Image' -> 'vmlinuz-6.1.99-vendor-rk35xx'
Armbian: Debian compat: linux-update-symlinks install 6.1.99-vendor-rk35xx boot/vmlinuz-6.1.99-vendor-rk35xx
Armbian 'linux-image-vendor-rk35xx' for '6.1.99-vendor-rk35xx': 'postinst' finishing.
Setting up armbian-bsp-cli-orangepi5-plus-vendor (25.2.3) ...
Armbian 'armbian-bsp-cli-orangepi5-plus-vendor' for '1-PCe1b9-V4064-H2670-B1e5d-R756d': 'postinst' starting.
Armbian 'armbian-bsp-cli-orangepi5-plus-vendor' for '1-PCe1b9-V4064-H2670-B1e5d-R756d': 'postinst' finishing.
Setting up firefox-nightly (139.0a1~20250401212749) ...
Processing triggers for initramfs-tools (0.142+deb12u1) ...
update-initramfs: Generating /boot/initrd.img-6.12.12+bpo-arm64-16k
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8126a-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8126a-2.fw for module r8169
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.12.12+bpo-arm64-16k
Image Name: uInitrd
Created: Wed Apr 2 09:44:31 2025
Data Size: 57076607 Bytes = 55738.87 KiB = 54.43 MiB
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.12.12+bpo-arm64-16k to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.12.12+bpo-arm64-16k'
Log ended: 2025-04-02 09:44:34
Any tips how to resolve this and boot from the nvme again?
I know initramfs exists and I can wrap my mind arround it what it does, but in the last years never had to solve anything regarding it.
I do not know where to look or start debugging
