You can see my changes in bolt
codec@05096000 {
#sound-dai-cells = <0x00>;
compatible = "allwinner,sun50i-h616-codec";
reg = <0x5096000 0x31c>;
interrupts = <0x00 0x3a 0x04>;
clocks = <0x02 0x5d 0x02 0x5b 0x02 0x5c>;
clock-names = "apb\0audio-codec-1x\0audio-codec-4x";
resets = <0x02 0x24>;
dmas = <0x0d 0x06>;
dma-names = "tx";
status = "okay";
phandle = <0x50>;
ahub_dam_plat@5097000 {
compatible = "allwinner,sunxi-snd-plat-ahub_dam";
reg = <0x5097000 0x1000>;
resets = <0x02 0x25>;
clocks = <0x02 0x5b 0x02 0x5c 0x02 0x5e 0x02 0x5f>;
clock-names = "clk_pll_audio\0clk_pll_audio_4x\0clk_audio_hub\0clk_bus_audio_hub";
status = "okay";
phandle = <0x51>;
ahub1_plat {
compatible = "allwinner,sunxi-snd-plat-ahub";
apb_num = <0x01>;
dmas = <0x0d 0x04 0x0d 0x04>;
dma-names = "tx\0rx";
playback_cma = <0x80>;
capture_cma = <0x80>;
tx_fifo_size = <0x80>;
rx_fifo_size = <0x80>;
tdm_num = <0x01>;
tx_pin = <0x00>;
rx_pin = <0x00>;
status = "okay";
phandle = <0x0f>;
ahub1_mach {
compatible = "allwinner,sunxi-snd-mach";
soundcard-mach,name = "HDMI";
soundcard-mach,format = "i2s";
soundcard-mach,frame-master = <0x0e>;
soundcard-mach,bitclock-master = <0x0e>;
soundcard-mach,slot-num = <0x02>;
soundcard-mach,slot-width = <0x20>;
status = "okay";
phandle = <0x52>;
soundcard-mach,cpu {
sound-dai = <0x0f>;
soundcard-mach,pll-fs = <0x04>;
soundcard-mach,mclk-fs = <0x00>;
phandle = <0x0e>;
soundcard-mach,codec {
sound-dai = <0x10>;
phandle = <0x53>;
gpu@1800000 {
compatible = "allwinner,sun50i-h616-mali\0arm,mali-bifrost";
reg = <0x1800000 0x40000>;
interrupts = <0x00 0x5f 0x04 0x00 0x60 0x04 0x00 0x61 0x04>;
interrupt-names = "job\0mmu\0gpu";
clocks = <0x02 0x23 0x02 0x24>;
clock-names = "core\0bus";
resets = <0x02 0x03>;
status = "okay";
mali-supply = <0x11>;
phandle = <0x54>;
