Core Problem: Drives Stuck in PS0 at Idle
drives remain in Power State (PS): 0 (4.5W consumption) and get burning hot in idle. While copying 500gb of video files over wifi, under low load, temps settled at 35-37C.
All three of your NVMe drives (nvme0, nvme1, nvme2) are detected by the kernel.
They are identified as Viper VP4300L 4TB drives.
They are correctly initialized and made operational within your md0 RAID array.
The output parm: default_ps_max_latency_us:max power saving latency for new devices; use PM QOS to change per device (ulong) confirms that the nvme_core module recognizes this parameter.
However, this modinfo command only tells us about the parameter itself (its description and type), not the value that is currently active in your running kernel. We already confirmed that active value is 100000 from your previous cat /sys/module/nvme_core/parameters/default_ps_max_latency_us command.
So, the situation remains: Your NVMe drives are staying in Power State 0 (consuming 4.5W each) and getting burning hot, even though the kernel is telling them "No Workload" and the default_ps_max_latency_us parameter is set generously high (100000 µs), which should allow them to enter deep sleep states.
This strongly suggests that something is actively preventing them from entering sleep states, despite the ideal configuration.
In the span of a few seconds:
pi@omv:~$ sudo nvme get-feature /dev/nvme0n1 -f 0x02 -H
get-feature:0x02 (Power Management), Current value:0x00000004
Workload Hint (WH): 0 - No Workload
Power State (PS): 4
pi@omv:~$ sudo nvme get-feature /dev/nvme1n1 -f 0x02 -H
get-feature:0x02 (Power Management), Current value:0x00000003
Power State (PS): 3
pi@omv:~$ sudo nvme get-feature /dev/nvme2n1 -f 0x02 -H
Power State (PS): 4
Power State (PS): 4
get-feature:0x02 (Power Management), Current value:00000000
Power State (PS): 0
Power State (PS): 0
Power State (PS): 4
sudo nvme id-ctrl /dev/nvme0n1 -H | less
ps 0 : mp:4.5000W operational enlat:0 exlat:0 rrt:0 rrl:0
rwt:0 rwl:0 idle_power:- active_power:-
active_power_workload:-
ps 1 : mp:2.4000W operational enlat:0 exlat:0 rrt:1 rrl:1
rwt:1 rwl:1 idle_power:- active_power:-
ps 2 : mp:0.6000W operational enlat:0 exlat:0 rrt:2 rrl:2
rwt:2 rwl:2 idle_power:- active_power:-
ps 3 : mp:0.0250W non-operational enlat:5000 exlat:5000 rrt:3 rrl:3
rwt:3 rwl:3 idle_power:- active_power:-
ps 4 : mp:0.0040W non-operational enlat:5000 exlat:25000 rrt:4 rrl:4
rwt:4 rwl:4 idle_power:- active_power:-
