aproxityloq
4 -
Nanopi M6 DHCP is not working / Ethernet Failed to reset the dma
aproxityloq replied to aproxityloq's topic in NanoPi M6
Only with kernel versions 6.1.x am I able to apply the static network config for RTL8211F interface (but sometimes it'll fail), but with newer kernel versions (v6.6.16/v6.6.63/v6.12.22/v6.14.0-rc4/v6.15.0-rc1), trying to apply the network config with `netplan apply` always fails with `Failed to reset the dma` error. -
Can someone who has NanoPi M6 confirm this issue? I'm not sure if it's a software problem or is my NanoPi M6 has a defective hardware. -
An addition: The manual network settings are not working on boot with the same error about failed to reset the dma, but it works after restarting network using: netplan apply Manually after the boot. The log of netplan apply: Apr 21 10:08:42 nanopi-m6 systemd-timesyncd[634]: Network configuration changed, trying to establish connection. Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: NONE.ABCD.NONE Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: # Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: Will Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: never Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: match Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: with Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network:8: Not a valid hardware address, ignoring: anything Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: /etc/systemd/network/00-armbian-readme.network: No valid settings found in the [Match] section, ignoring file. To match all interfaces, add Name=* in the [Match] section. Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: lan: Reconfiguring with /run/systemd/network/10-netplan-lan.network. Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: Register MEM_TYPE_PAGE_POOL RxQ-0 Apr 21 10:08:42 nanopi-m6 kernel: phy_rtl8211f_led_fixup in Apr 21 10:08:42 nanopi-m6 kernel: phy_rtl8211f_led_fixup in val=0x0000 Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: PHY [stmmac-1:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL) Apr 21 10:08:42 nanopi-m6 kernel: dwmac4: Master AXI performs any burst length Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: No Safety Features support found Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: IEEE 1588-2008 Advanced Timestamp supported Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: registered PTP clock Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: FPE workqueue start Apr 21 10:08:42 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: configuring for phy/rgmii-rxid link mode Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: enxXXXXXXXXXXXX: Reconfiguring with /run/systemd/network/10-netplan-all-eth-interfaces.network. Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: enxXXXXXXXXXXXX: DHCP lease lost Apr 21 10:08:42 nanopi-m6 dbus-daemon[697]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.2' (uid=998 pid=442 comm="/lib/systemd/systemd-networkd") Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: enxXXXXXXXXXXXX: DHCPv6 lease lost Apr 21 10:08:42 nanopi-m6 systemd[1]: Starting systemd-hostnamed.service - Hostname Service... Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: lan: Link UP Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: lan: Configuring with /run/systemd/network/10-netplan-lan.network. Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: enxXXXXXXXXXXXX: Configuring with /run/systemd/network/10-netplan-all-eth-interfaces.network. Apr 21 10:08:42 nanopi-m6 systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl). Apr 21 10:08:42 nanopi-m6 dbus-daemon[697]: [system] Successfully activated service 'org.freedesktop.hostname1' Apr 21 10:08:42 nanopi-m6 systemd[1]: Started systemd-hostnamed.service - Hostname Service. Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: Could not set hostname: Access denied Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: enxXXXXXXXXXXXX: DHCPv4 address 10.42.0.11/24, gateway 10.42.0.1 acquired from 10.42.0.1 Apr 21 10:08:42 nanopi-m6 systemd-networkd[442]: Could not set hostname: Access denied Apr 21 10:08:44 nanopi-m6 systemd-resolved[633]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 10.42.0.1. Apr 21 10:08:46 nanopi-m6 systemd-networkd[442]: lan: Gained carrier Apr 21 10:08:46 nanopi-m6 kernel: rk_gmac-dwmac fe1c0000.ethernet lan: Link is Up - 1Gbps/Full - flow control rx/tx Apr 21 10:08:46 nanopi-m6 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): lan: link becomes ready Apr 21 10:08:47 nanopi-m6 systemd-networkd[442]: lan: Gained IPv6LL Full netplan config: root@nanopi-m6:~# netplan get network: version: 2 renderer: networkd ethernets: all-eth-interfaces: match: name: "enx*" dhcp4: true dhcp6: false ipv6-privacy: true lan: match: name: "end*" addresses: - "10.42.1.11/24" nameservers: addresses: - 10.42.1.1 dhcp4: false dhcp6: false routes: - to: "default" via: "10.42.1.1" UPD: It seems to be inconsistent. On boot, if I run netplan apply, there are 3 different results at random: - there is no error in the log and network interface is configured correctly - there is 1 error about failed dma reset, but netplan retries automatically and succeeds in network interface configuration on second attempt: rk_gmac-dwmac fe1c0000.ethernet: Failed to reset the dma rk_gmac-dwmac fe1c0000.ethernet lan: stmmac_hw_setup: DMA engine initialization failed rk_gmac-dwmac fe1c0000.ethernet lan: __stmmac_open: Hw setup failed - there are 2 errors about failed dma reset and netplan don't retry anymore If I rerun netplan apply after it fails with 2 errors, then the same 3 different results at random can repeat until it succeeds. Once network interface is configured successfully, then further netplan apply commands won't fail anymore. -
This issue is about Nanopi M6 model without LCD, but there is no tag for Nanopi M6, even though it has Platinum support, so I had to set nanopi-r6c tag. The Ethernet interface can't receive settings from DHCP with errors: [ 12.894724] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 12.894866] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 12.894876] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 12.894892] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 12.894948] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 12.894954] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 12.894959] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 12.894964] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 12.894996] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 12.895004] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 12.895009] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 12.895024] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 12.895244] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 12.895386] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 12.895394] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 12.895399] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 12.895404] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 12.895408] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 12.895412] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 12.895447] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 12.895451] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 12.895456] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 12.895461] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 12.895466] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 12.895471] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 14.079161] rk_gmac-dwmac fe1c0000.ethernet lan: renamed from eth0 [ 16.449457] rk_gmac-dwmac fe1c0000.ethernet lan: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 16.538364] rk_gmac-dwmac fe1c0000.ethernet lan: PHY [stmmac-1:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 17.538848] rk_gmac-dwmac fe1c0000.ethernet: Failed to reset the dma [ 17.538877] rk_gmac-dwmac fe1c0000.ethernet lan: stmmac_hw_setup: DMA engine initialization failed [ 17.538894] rk_gmac-dwmac fe1c0000.ethernet lan: __stmmac_open: Hw setup failed But if I set the network settings manually, then network works fine: root@nanopi-m6:~# cat /etc/netplan/11-lan.yaml network: version: 2 renderer: networkd ethernets: lan: match: name: "end*" dhcp4: false dhcp6: false addresses: - 10.42.1.11/24 routes: - to: default via: 10.42.1.1 nameservers: addresses: [10.42.1.1] I've tried different official Armbian images: Armbian_24.11.1_Nanopi-m6_bookworm_vendor_6.1.75_minimal.img Armbian_24.8.4_Nanopi-m6_bookworm_vendor_6.1.75_minimal.img Armbian_25.2.1_Nanopi-m6_bookworm_current_6.12.13_minimal.img Armbian_25.2.1_Nanopi-m6_bookworm_vendor_6.1.99_minimal.img Armbian_25.2.1_Nanopi-m6_bookworm_vendor_6.1.99_xfce_desktop.img Armbian_25.5.0-trunk.418_Nanopi-m6_plucky_vendor_6.1.115_minimal.img I've tried Armbian_25.2.1_Nanopi-m6_bookworm_vendor_6.1.99_minimal.img and Armbian_25.2.1_Nanopi-m6_bookworm_current_6.12.13_minimal.img (updated to kernel 6.12.22) with latest updates and it's not working as well. armbian-hardware-monitor.log: https://paste.armbian.com/ketawomulu.yaml
