I have resolved the problem with UART communication - was soldering point between TX and capacitor on board, so after desoldering connection through UART works.
Armbian does not boot from USB via flash-drive, but when writing it to SDCard - I see start of the system, but it hungs on "Starting kernel"
Adding boot logs:
DDR V1.05 4bit PCB 2eef4a672d huan.he 23/04/14-10:58:56
LP4/4x derate disable, other dram:1x trefi
ddrconfig:15
DDR3, 324MHz
BW=32 Col=11 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 626ps, dqs1: 482ps, dqs2: 723ps, dqs3: 723ps,
change to: 324MHz
clk skew:0x64
change to: 528MHz
clk skew:0x64
change to: 666MHz
clk skew:0x64
change to: 786MHz(final freq)
clk skew:0x64
PHY drv:clk:50,ca:28,DQ:40,odt:145
vrefinner:50%, vrefout:50%
dram drv:34,odt:60
cs 0:
the read training result:
DQS0:0x5b, DQS1:0x51, DQS2:0x53, DQS3:0x53,
min : 0x6 0x13 0x10 0x10 0x10 0x2 0x1 0x6 , 0x8 0x8 0x4 0x3 0x5 0x4 0x2 0x2 ,
0x7 0x5 0x1 0x6 , 0x2 0x10 0x10 0x3 0x13 0x5 0x12 0x6 ,
mid 0x2f 0x2f 0x29 0x29 0x2b 0x2a 0x29 0x27 ,
0x2a 0x32 0x2e 0x29 0x3b 0x2c 0x39 0x2d ,
max :0x56 0x65 0x60 0x5f 0x62 0x52x50 0x50 0x4d ,
0x4d 0x5a 0x54 0x56 0x57 0x4c 0x4f 0x54 ,,
range:0x50 0x52 0x50 0x4f 0x52 0x50 0x50 0x4e ,0x4e 0x4e 0x4b0x50 0x4c 0x51 0x4f 0x47 0x4e 0x4e ,0x4c 0x4f 0x50 0x4c 0x51 0x4:
DQS0:0xa2, DQS1:0x94, DQS2:0xac, DQS3:0xac,
min :0x83 0x8ab 0x7a 0x79 0x78 0x74 0x73 0x73 0x73 0x79 ,
0x8f 0x96 0x95 0x96 0x8d 0x98 0x90 0x97 0x92 0x93 ,
mid :0x9d 0xa5 0xa2 0xax94 0x92 0x90 0x8e 0x8d 0x8c 0x95 ,
0xa8 0xaf 0xab 0xac 0xa9 0xb4 0xab 0xb1 0xad 0xb0 ,
max :0xb8 0xc1 0xbb 0xbb 0xbd 0 0xac 0xa9 0xa8 0xa6 0xb1 ,
0xc1 0xc9 0xc4 0xc7 0xc6 0xbdd0 0xc6 0xcc 0xc9 0xce ,
range:0x35 0x37 0x31 0x32 0x35 0x36 0x0x36 0x35 0x33 0x38 ,
0x32 0x33 0x31 0x36 0x32 0x2f 0x37 0x35 0x37 0x3b ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-g0fbedd0675-230404 #zyf (Apr 11 2023 - 09:25:18)
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
No misc partition
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00080000 ... sha256(2493d19c1e...) + OK
## Checking uboot 0x00200000 ... sha256(01c15fcf12...) + OK
## Checking fdt 0x00308958 ... sha256(2867f75977...) + OK
## Checking atf-2 0xfe48d000 ... sha256(8ce3689111...) + OK
## Checking atf-3 0xfe490000 ... sha256(bc35c9ef85...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00080000)
Total: 334.426 ms
INFO: Preloader serial: 0
NOTICE: BL31: v2.3():v2.3-679-geda1f5ce4:cl, fwver: v1.17
NOTICE: BL31: Built : 23:57:18, Dec 20 2023
INFO: rk_otp_init finish!
INFO: ARM GICv2 driver initialized
INFO: nonboot_cpus_off: clst_st=0xc0e, core_st=0xe1e0 boot_cpu=0
INFO: dfs].freq_mhz= 786MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MDR fsp_param[3].freq_mhz= 666MHz
INFO: idle_st=0x0, pd_st=0xask: 1
INFO: RK3528 SoC (0x101)
INFO: BL31: Initializing runtime services
WARNING: No OPTE provided by BL2 boot loader, Booting device without OPTEE init Error initializing runtime service opteed_fast
INFO: BL31: dress = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-armbian-2017.09-S3264-Pda90-H7573-V3999-Bb703-R448a (May 13 2025 - 12:27:23 +0300)
Model: Rockchip RK3528 Evaluation Board
MPIDR: 0x80000000
PreSerial: 0, raw, 0xff9f003.9 GiB
Sysmem: init
Relocation Offset: f9a58000
Relocation fdt: f79fa630 - f79fecd8
CR: M/C/I
Using default environment
DM: v2
no mmc device at slot 1
mmc@ffbf0000: 0, mmc@ffc30000: 1 (SD)
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
Failed to load DTB, ret=-19
No valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
MPIDR: 0x80000000
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 600000 KHz, init 1200000 KHz, kernel 0N/A)
apll 600000 KHz
gpll 1188000 KHz
cpll 996000 KHz
dpll 393000 KHz
ppll 10KHz
clk_100m 99600 KHz
clk_150m 148500 KHz
clk_200m 198KHz
clk_400m 396000 KHz
clk_500m 498000 KHz
clk_600m 59clk_ppll_125m 125000 KHz
No misc partition
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
Could not find misc partition
ANDROID: reboot reason: "(none)"
Not AVB images, AVB skip
android_image_load_by_partname: Can't find part: boot
Android image load failed
Android boot failed, error -1.
## Booting FITFIT: No boot partition
FIT: No fit blob
FIT: No FIT image
Unknown command 'bootrkp' - try 'help'
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
3906 bytes read in 23 ms (165 KiB/s)
## Executing script at 00c00000
Boot script loaded from mmc 1:1
176 bytes read in 18 ms (8.8 KiB/s)
6460789 bytes read in 563 ms (10.9 MiB/s)
28610568 bytes read in 2345 ms (11.6 MiB/s)
102238 bytes read in 289 ms (344.7 KiB/s)
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
No misc partition
## Loading init Ramdisk from Legacy Image at 0a200000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Imagd)
Data Size: 6460725 Bytes = 6.2 MiB
Load Address: 0OK
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
reserving fdt memory region: addr=8300000 size=7f000
Using Device Tree in place at 0000000008300000, end 0000000008381fff
WARNING: could not set reg FDT_ERR_BADOFFSET.
## reserved-memory:
ramoops@110000: addr=110000 size=e0000
Adding bank: 0x00200000 - 0xfc000000 (size: 0xfbe00000)
Total: 4660.229/5052.326 ms
Starting kernel ...
I think that MMC1 is sdcard, MMC2 is internal EMMC, so uboot is loaded from MMC1 sdcard (it has different version compared to standard boot), but the output is different compared to standard boot:
Some suspicious data in log:
MMC1: Legacy, 52Mhz PartType: EFI No misc partition
I have full access to EMMC with all partitions and initial data to extract if needed.
Will appreciate if someone could point me to custom armbian build steps for this board and suggest next steps.
(https://gist.github.com/fensoft/1ff3ef81ab2bd9ed9364a564aa2cbcd5?permalink_comment_id=5576642#file-build-sh is what I tried and it does not work)
