Hi folks,
Very new to this community, very new to flashing Android boxes.. But I wanted to give this a shot and make use of an old TX5 Pro that I had in a drawer.
Pleased to say, boots from the SD card fine, managed to get logged in and set up... all is working, WiFi, Bluetooth etc... However, I am just not able to get this to boot from the eMMC. I got to the point where I bricked it and had to re-flash Android onto it.. just to find myself in the same loop.
I'll provide as much info as I can here, but let me know if you need something more specific. I'm no expert here, so here goes.
Booting from the SD starts like this:
When booted, all is working totally fine. However, removing the SD results in the following, where it will stay for eternity util rebooting and inserting SD:
ChatGPT led me to screw this up entirely, despite getting this far based on it's instructions, so I'm turning to you for help. I really need to have this booting from the internal storage and not from an SD card.
Here's the copy attempt:
root@aml-s9xx-box:~# ./install-aml.sh
Start script create MBR and filesystem
/dev/mmcblk1
Start backup u-boot default
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.149809 s, 28.0 MB/s
Start create MBR and partittion
Start restore u-boot
442+0 records in
442+0 records out
442 bytes copied, 0.0044687 s, 98.9 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.524224 s, 8.0 MB/s
Done
Start copy system for eMMC.
Formatting BOOT partition...mkfs.fat 4.2 (2021-01-31)
done.
mount: (hint) your fstab has been modified, but systemd still uses
the old version; use 'systemctl daemon-reload' to reload.
Copying BOOT...done.
Edit init config...done.
sed: can't read /ddbr/install/boot.ini: No such file or directory
done.
Formatting ROOT partition...
/dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC'
last mounted on /ddbr/install on Fri May 23 19:51:02 2025
e2fsck 1.47.0 (5-Feb-2023)
ROOT_EMMC: clean, 11/855120 files, 80315/3419392 blocks
done.
Copying ROOTFS.
Copy BIN
Create DEV
Copy ETC
Copy HOME
Copy LIB
Copy LIB64
tar: lib64: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
rm: cannot remove '/ddbr/install/usr/bin/ddbr': No such file or directory
Complete copy OS to eMMC
Here's some info about the setup, again, let me know if you need something extra:
_ _ _ _ _
/_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _
/ _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || |
/_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, |
|___| |__/
v25.5 rolling for aml-s9xx-box running Armbian Linux 6.12.28-current-meson64
Packages: Debian stable (bookworm)
Updates: Kernel upgrade enabled and 76 packages available for upgrade
Support: for advanced users (rolling release)
IPv4: (LAN) 10.0.1.102 (WAN) X.XXX.XXX.XXX
Performance:
Load: 32% Up time: 1 min
Memory usage: 21% of 1.87G
CPU temp: 54°C Usage of /: 20% of 29G
RX today: 64 MiB
Commands:
Configuration : armbian-config
Upgrade : armbian-upgrade
Monitoring : htop
System and Boot Logs: https://paste.armbian.com/fiqikiliju
PRETTY_NAME="Armbian_community 25.5.0-trunk.538 bookworm"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.armbian.com"
SUPPORT_URL="https://forum.armbian.com"
BUG_REPORT_URL="https://www.armbian.com/bugs"
ARMBIAN_PRETTY_NAME="Armbian_community 25.5.0-trunk.538 bookworm"
root=UUID=e969167d-e6a9-4203-896f-ced402105523 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
mmcblk0
├─mmcblk0p1 vfat FAT32 armbi_boot 479F-151E 414M 19% /boot
└─mmcblk0p2 ext4 1.0 armbi_root e969167d-e6a9-4203-896f-ced402105523 22.5G 19% /var/log.hdd
mmcblk1
├─mmcblk1p1 vfat FAT16 BOOT_EMMC 75EA-4970
└─mmcblk1p2 ext4 1.0 ROOT_EMMC d0456959-1f46-4aad-b7f0-d784208d67a8
mmcblk1boot0
mmcblk1boot1
zram0 [SWAP]
zram1 40.2M 7% /var/log
zram2
label Armbian_community
kernel /Image
initrd /uInitrd
fdt /dtb/amlogic/meson-gxl-s905x-p212.dtb
append root=UUID=e969167d-e6a9-4203-896f-ced402105523 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
Any assistance would be greatly appreciate.
