Two days ago I upgraded the kernel to 25.5.1 (6.12.30-current-sunxi) from 25.2.3 (6.12.20-current-sunxi). Since then I have no longer been able to play a certain title (FLAC file) in mocp. In case it's relevant, the title is: "Malukah - Awake (The Dragonborn Comes)".
Symptoms:
dmesg starts showing kernel trace output at 1:43 of the song
mocp finally stalls at 1:52 and it's impossible to interact with it from that point on
Is there anyone here who would be able to provide pointers on how to debug this? I am a developer and I have done some work with Yocto/OE before and wouldn't be afraid to get at this with a debugger. Since it's nicely reproducible, I could switch between those package versions to investigate.
From the trace output it looks as if this is in exfat code. Makes sense, since the song is getting played from a USB key that is exfat-formatted.
Here's the dmesg output with the two traces towards the end. I decided to include a few messages up to the point where systemd starts:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 6.12.30-current-sunxi (build@armbian) (arm-linux-gnueabihf-gcc (Ubuntu 13.2.0-23ubuntu4) 13.2.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Thu May 22 12:29:54 UTC 2025
[ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Cubietech Cubietruck
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x4a000000..0x4fffffff (98304 KiB) map reusable default-pool
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff]
[ 0.000000] HighMem [mem 0x0000000070000000-0x00000000bfcfffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000bfcfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfcfffff]
[ 0.000000] On node 0, zone HighMem: 768 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] percpu: Embedded 19 pages/cpu s48588 r8192 d21044 u77824
[ 0.000000] pcpu-alloc: s48588 r8192 d21044 u77824 alloc=19*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Kernel command line: root=UUID=ad99c006-e2fa-4070-8fbe-9e08f643dd62 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=5b507211-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[ 0.000000] Unknown kernel command line parameters "ubootpart=5b507211-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 523520
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] allocated 2097152 bytes of page_ext
[ 0.000000] ftrace: allocating 47264 entries in 139 pages
[ 0.000000] ftrace: allocated 139 pages with 4 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[ 0.000000] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000435] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.001281] Console: colour dummy device 80x30
[ 0.001311] printk: legacy console [tty1] enabled
[ 0.001505] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.001530] CPU: Testing write buffer coherency: ok
[ 0.001607] pid_max: default: 32768 minimum: 301
[ 0.010543] LSM: initializing lsm=capability,yama,apparmor
[ 0.013707] Yama: becoming mindful.
[ 0.014095] AppArmor: AppArmor initialized
[ 0.015557] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.015592] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.021695] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.044852] Setting up static identity map for 0x40100000 - 0x40100054
[ 0.048263] rcu: Hierarchical SRCU implementation.
[ 0.048283] rcu: Max phase no-delay instances is 1000.
[ 0.048858] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.054065] smp: Bringing up secondary CPUs ...
[ 0.071012] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.071303] smp: Brought up 1 node, 2 CPUs
[ 0.071330] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.071345] CPU: All CPU(s) started in HYP mode.
[ 0.071352] CPU: Virtualization extensions available.
[ 0.071568] Memory: 1933492K/2094080K available (10240K kernel code, 1685K rwdata, 9100K rodata, 1024K init, 409K bss, 57468K reserved, 98304K cma-reserved, 1307648K highmem)
[ 0.073644] devtmpfs: initialized
[ 0.086909] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[ 0.087516] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.087579] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.096245] pinctrl core: initialized pinctrl subsystem
[ 0.099654] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.107107] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.108097] audit: initializing netlink subsys (disabled)
[ 0.108752] audit: type=2000 audit(0.100:1): state=initialized audit_enabled=0 res=1
[ 0.109807] thermal_sys: Registered thermal governor 'fair_share'
[ 0.109827] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.109838] thermal_sys: Registered thermal governor 'step_wise'
[ 0.110006] cpuidle: using governor ladder
[ 0.110071] cpuidle: using governor menu
[ 0.110879] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.110905] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.121698] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.121833] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.121937] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.122055] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.122158] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.122261] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.122578] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0d000
[ 0.122732] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[ 0.123085] /soc/interrupt-controller@1c81000: Fixed dependency cycle(s) with /soc/interrupt-controller@1c81000
[ 0.123248] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.123439] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.123615] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.123773] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.123862] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0d000
[ 0.123940] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[ 0.124009] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/display-frontend@1e20000
[ 0.124077] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/display-frontend@1e00000
[ 0.124170] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0d000
[ 0.124249] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[ 0.124317] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/display-frontend@1e20000
[ 0.124386] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/display-frontend@1e00000
[ 0.125215] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.125339] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.125455] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.125804] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.125918] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.126030] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.128237] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.128436] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.128705] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0d000
[ 0.128943] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[ 0.131769] /soc/pinctrl@1c20800: Fixed dependency cycle(s) with /soc/pinctrl@1c20800/clk-out-a-pin
[ 0.136344] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.136455] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.136830] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.136924] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.137304] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.137470] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.137604] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.137736] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/display-backend@1e40000
[ 0.137883] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0d000
[ 0.138028] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[ 0.138142] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/display-frontend@1e20000
[ 0.138279] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc/display-frontend@1e00000
[ 0.138694] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.138884] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.139055] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.139186] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/display-backend@1e60000
[ 0.139302] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0d000
[ 0.139477] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[ 0.139661] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/display-frontend@1e20000
[ 0.139780] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc/display-frontend@1e00000
[ 0.142414] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /hdmi-connector
[ 0.142644] /hdmi-connector: Fixed dependency cycle(s) with /soc/hdmi@1c16000
[ 0.154682] cryptd: max_cpu_qlen set to 1000
[ 0.232124] raid6: neonx8 gen() 582 MB/s
[ 0.300278] raid6: neonx4 gen() 822 MB/s
[ 0.368453] raid6: neonx2 gen() 825 MB/s
[ 0.436671] raid6: neonx1 gen() 677 MB/s
[ 0.504833] raid6: int32x8 gen() 252 MB/s
[ 0.572914] raid6: int32x4 gen() 289 MB/s
[ 0.641009] raid6: int32x2 gen() 365 MB/s
[ 0.709128] raid6: int32x1 gen() 337 MB/s
[ 0.709142] raid6: using algorithm neonx2 gen() 825 MB/s
[ 0.777211] raid6: .... xor() 614 MB/s, rmw enabled
[ 0.777223] raid6: using neon recovery algorithm
[ 0.779037] iommu: Default domain type: Translated
[ 0.779063] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.780359] SCSI subsystem initialized
[ 0.780941] libata version 3.00 loaded.
[ 0.781297] usbcore: registered new interface driver usbfs
[ 0.781366] usbcore: registered new interface driver hub
[ 0.781432] usbcore: registered new device driver usb
[ 0.781783] pps_core: LinuxPPS API ver. 1 registered
[ 0.781798] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.781825] PTP clock support registered
[ 0.782595] Advanced Linux Sound Architecture Driver Initialized.
[ 0.784208] NetLabel: Initializing
[ 0.784231] NetLabel: domain hash size = 128
[ 0.784242] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.784360] NetLabel: unlabeled traffic allowed by default
[ 0.785656] clocksource: Switched to clocksource arch_sys_counter
[ 0.798624] VFS: Disk quotas dquot_6.6.0
[ 0.798981] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.799863] AppArmor: AppArmor Filesystem Enabled
[ 0.816412] NET: Registered PF_INET protocol family
[ 0.816787] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.903926] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.904136] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.904189] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.904385] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.904778] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.905038] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.905134] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.906025] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.906649] Trying to unpack rootfs image as initramfs...
[ 0.910989] Initialise system trusted keyrings
[ 0.911155] Key type blacklist registered
[ 0.912237] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.912442] zbud: loaded
[ 0.915119] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.926275] fuse: init (API version 7.41)
[ 0.942065] integrity: Platform Keyring initialized
[ 0.942166] xor: measuring software checksum speed
[ 0.945010] arm4regs : 1159 MB/sec
[ 0.950057] 8regs : 656 MB/sec
[ 0.954923] 32regs : 680 MB/sec
[ 0.957769] neon : 1170 MB/sec
[ 0.957807] xor: using function: neon (1170 MB/sec)
[ 0.957845] Key type asymmetric registered
[ 0.957862] Asymmetric key parser 'x509' registered
[ 0.958690] bounce: pool size: 64 pages
[ 0.959359] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.960113] io scheduler mq-deadline registered
[ 0.960146] io scheduler kyber registered
[ 0.960735] io scheduler bfq registered
[ 0.977058] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.995929] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.014369] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0bb0c8c)
[ 1.014715] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0bb0c8c)
[ 1.015235] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0bb03f8)
[ 1.015729] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0bb03f8)
[ 1.016653] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[ 1.016699] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0bae8e8)
[ 1.017975] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[ 1.018031] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0bae8e8)
[ 1.020256] sun4i-drm display-engine: bound 1c16000.hdmi (ops 0xc0bb1688)
[ 1.022796] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0
[ 1.022975] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[ 1.032968] brd: module loaded
[ 1.039581] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[ 1.047130] loop: module loaded
[ 1.055585] usbcore: registered new interface driver usb-storage
[ 1.057950] sunxi-rtc 1c20d00.rtc: registered as rtc0
[ 1.058027] sunxi-rtc 1c20d00.rtc: setting system clock to 2025-07-02T08:56:46 UTC (1751446606)
[ 1.058332] i2c_dev: i2c /dev entries driver
[ 1.062076] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.064151] sun4i-ss 1c15000.crypto-engine: no reset control found
[ 1.064308] sun4i-ss 1c15000.crypto-engine: Die ID 0
[ 1.066426] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
[ 1.066943] hid: raw HID events driver (C) Jiri Kosina
[ 1.067216] usbcore: registered new interface driver usbhid
[ 1.067237] usbhid: USB HID core driver
[ 1.067954] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[ 1.071446] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 (8000000f) counters available
[ 1.095873] NET: Registered PF_INET6 protocol family
[ 2.127070] Freeing initrd memory: 13656K
[ 2.182392] Segment Routing with IPv6
[ 2.182617] In-situ OAM (IOAM) with IPv6
[ 2.182903] NET: Registered PF_PACKET protocol family
[ 2.182935] NET: Registered PF_KEY protocol family
[ 2.182985] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.183410] Key type dns_resolver registered
[ 2.184170] Registering SWP/SWPB emulation handler
[ 2.196828] registered taskstats version 1
[ 2.197160] Loading compiled-in X.509 certificates
[ 2.214355] zswap: loaded using pool zstd/zbud
[ 2.215911] Key type .fscrypt registered
[ 2.215942] Key type fscrypt-provisioning registered
[ 2.226935] Btrfs loaded, zoned=no, fsverity=yes
[ 2.307518] Key type encrypted registered
[ 2.307567] AppArmor: AppArmor sha256 policy hashing enabled
[ 2.328245] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator
[ 2.328719] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.331261] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 2.332777] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
[ 2.336072] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
[ 2.337794] printk: legacy console [ttyS0] disabled
[ 2.338531] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 71, base_baud = 1500000) is a 16550A
[ 2.338635] printk: legacy console [ttyS0] enabled
[ 2.343112] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 72, base_baud = 1500000) is a 16550A
[ 2.343750] serial serial0: tty port ttyS2 registered
[ 2.345203] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[ 2.345901] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found
[ 2.345938] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found
[ 2.345954] sun7i-dwmac 1c50000.ethernet: IRQ sfty not found
[ 2.346126] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[ 2.346202] sun7i-dwmac 1c50000.ethernet: no regulator found
[ 2.346880] sun7i-dwmac 1c50000.ethernet: Version ID not available
[ 2.346924] sun7i-dwmac 1c50000.ethernet: DWMAC1000
[ 2.346940] sun7i-dwmac 1c50000.ethernet: No HW DMA feature register supported
[ 2.346954] sun7i-dwmac 1c50000.ethernet: TX Checksum insertion supported
[ 2.346969] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[ 2.346982] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[ 2.378420] axp20x-i2c 1-0034: AXP20x variant AXP209 found
[ 2.394479] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0
[ 2.400618] axp20x-i2c 1-0034: Backup (RTC) battery charging is disabled
[ 2.400815] axp20x-i2c 1-0034: AXP20X driver loaded
[ 2.406857] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[ 2.413840] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[ 2.418221] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
[ 2.418494] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
[ 2.438244] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 2.465843] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[ 2.465933] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
[ 2.465982] ahci-sunxi 1c18000.sata: AHCI vers 0001.0100, 32 command slots, 3 Gbps, platform mode
[ 2.466005] ahci-sunxi 1c18000.sata: 1/1 ports implemented (port mask 0x1)
[ 2.466021] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
[ 2.468318] scsi host0: ahci-sunxi
[ 2.469308] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 119 lpm-pol 0
[ 2.474777] of_cfs_init
[ 2.474978] of_cfs_init: OK
[ 2.478704] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.480932] mmc0: new high speed SDHC card at address b368
[ 2.484061] mmcblk0: mmc0:b368 NCard 3.70 GiB
[ 2.713012] clk: Disabling unused clocks
[ 2.713235] PM: genpd: Disabling unused power domains
[ 2.713266] ALSA device list:
[ 2.713278] #0: sun4i-codec
[ 2.713992] mmcblk0: p1
[ 2.780858] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.782832] ata1.00: Model 'Samsung SSD 840 EVO 500GB', rev 'EXT0CB6Q', applying quirks: noncqtrim zeroaftertrim nodmalog
[ 2.782904] ata1.00: supports DRM functions and may not be fully accessible
[ 2.782919] ata1.00: ATA-9: Samsung SSD 840 EVO 500GB, EXT0CB6Q, max UDMA/133
[ 2.782939] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32)
[ 2.783422] ata1.00: Features: Trust
[ 2.783673] ata1.00: supports DRM functions and may not be fully accessible
[ 2.784145] ata1.00: configured for UDMA/133
[ 2.785048] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 840 CB6Q PQ: 0 ANSI: 5
[ 2.787212] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.787270] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.787381] sd 0:0:0:0: [sda] Write Protect is off
[ 2.787406] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.787559] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.787919] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 2.806306] sda: sda1 sda2 sda3
[ 2.807527] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.816074] Freeing unused kernel image (initmem) memory: 1024K
[ 2.816726] Run /init as init process
[ 2.816754] with arguments:
[ 2.816773] /init
[ 2.816784] with environment:
[ 2.816794] HOME=/
[ 2.816805] TERM=linux
[ 2.816815] ubootpart=5b507211-01
[ 2.816826] ubootsource=mmc
[ 2.816837] sunxi_ve_mem_reserve=0
[ 2.816847] sunxi_g2d_mem_reserve=0
[ 2.816858] sunxi_fb_mem_reserve=16
[ 2.816869] cgroup_enable=memory
[ 3.909998] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq
[ 3.933806] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB
[ 4.061411] mmc1: new high speed SDIO card at address 0001
[ 4.211031] sun5i-a13-gpadc-iio: Failed to locate of_node [id: 0]
[ 4.283436] sun7i-dwmac 1c50000.ethernet end0: renamed from eth0
[ 4.301983] axp20x-gpio axp20x-gpio: DMA mask not set
[ 4.327476] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
[ 4.355581] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[ 4.371464] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[ 5.873099] EXT4-fs (sda1): mounted filesystem ad99c006-e2fa-4070-8fbe-9e08f643dd62 ro with ordered data mode. Quota mode: none.
[ 14.571324] platform sound: deferred probe pending: asoc-simple-card: parse error
[ 14.571365] platform 1c13400.phy: deferred probe pending: platform: supplier axp20x-usb-power-supply not ready
[ 14.571381] platform 1c13000.usb: deferred probe pending: platform: supplier 1c13400.phy not ready
[ 14.571395] platform 1c14000.usb: deferred probe pending: platform: supplier 1c13400.phy not ready
[ 14.571409] platform 1c1c000.usb: deferred probe pending: platform: supplier 1c13400.phy not ready
[ 14.571422] platform 1c14400.usb: deferred probe pending: platform: supplier 1c13400.phy not ready
[ 14.571436] platform 1c1c400.usb: deferred probe pending: platform: supplier 1c13400.phy not ready
[ 14.571449] platform axp20x-battery-power-supply: deferred probe pending: (reason unknown)
[ 14.571462] platform axp20x-usb-power-supply: deferred probe pending: (reason unknown)
[ 17.843978] systemd[1]: Inserted module 'autofs4'
[ 18.117493] systemd[1]: systemd 255.4-1ubuntu8.8 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 18.117576] systemd[1]: Detected architecture arm.
... SNIP ...
[90829.705266] 8<--- cut here ---
[90829.708505] Unable to handle kernel NULL pointer dereference at virtual address 00000255 when write
[90829.717695] [00000255] *pgd=00000000
[90829.721519] Internal error: Oops: 805 [#1] SMP THUMB2
[90829.726679] Modules linked in: nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 netfs exfat snd_usb_audio snd_hwdep binfmt_misc snd_seq_dummy snd_usbmidi_lib snd_seq_oss snd_seq_midi snd_seq_midi_event snd_seq snd_rawmidi snd_seq_device uas lima gpu_sched drm_shmem_helper axp20x_adc sunxi_cedrus(C) sun4i_gpadc_iio v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 sunxi_cir videobuf2_common videodev mc display_connector cpufreq_dt evdev brcmfmac_wcc sch_fq_codel bonding brcmfmac brcmutil cfg80211 rfkill dm_mod autofs4 ext4 mbcache jbd2 axp20x_usb_power axp20x_battery industrialio pinctrl_axp209 sun4i_gpadc pwm_sun4i sunxi phy_generic uio_pdrv_genirq pwrseq_simple uio realtek
[90829.788428] CPU: 1 UID: 1000 PID: 14406 Comm: mocp Tainted: G C 6.12.30-current-sunxi #1
[90829.797976] Tainted: [C]=CRAP
[90829.800979] Hardware name: Allwinner sun7i (A20) Family
[90829.806223] PC is at mmioset+0x90/0xa4
[90829.810015] LR is at exfat_get_block+0x58b/0x638 [exfat]
[90829.815374] pc : [<c0ab76b0>] lr : [<bfbdf847>] psr: 8003b833
[90829.821651] sp : f2559b48 ip : 00000255 fp : 00000000
[90829.826890] r10: 00004931 r9 : 00926255 r8 : c5a21400
[90829.832128] r7 : d09bc5c0 r6 : 00000000 r5 : 00000200 r4 : 00000055
[90829.838668] r3 : 00000001 r2 : 000001a7 r1 : 00000000 r0 : 00000255
[90829.845209] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none
[90829.852537] Control: 50c5387d Table: 536e006a DAC: 00000051
[90829.858294] Register r0 information: non-paged memory
[90829.863367] Register r1 information: NULL pointer
[90829.868089] Register r2 information: non-paged memory
[90829.873156] Register r3 information: non-paged memory
[90829.878221] Register r4 information: non-paged memory
[90829.883286] Register r5 information: non-paged memory
[90829.888356] Register r6 information: NULL pointer
[90829.893082] Register r7 information: slab buffer_head start d09bc5c0 pointer offset 0 size 64
[90829.901656] Register r8 information: slab kmalloc-1k start c5a21400 pointer offset 0 size 1024
[90829.910306] Register r9 information: non-paged memory
[90829.915380] Register r10 information: non-paged memory
[90829.920533] Register r11 information: NULL pointer
[90829.925338] Register r12 information: non-paged memory
[90829.930495] Process mocp (pid: 14406, stack limit = 0xfea269c0)
[90829.936437] Stack: (0xf2559b48 to 0xf255a000)
[90829.940814] 9b40: d09bc240 2e2746cd 00000001 d09bc5c0 00000000 c597c86c
[90829.949011] 9b60: 00000001 00000024 c5a21400 00000000 c597c800 d09bc240 00000000 0012aace
[90829.957211] 9b80: 0012aacd 00000000 00000000 00000000 00000000 2e2746cd 00000000 00004931
[90829.965406] 9ba0: d09bc5c0 00000000 00000001 00000200 e1bc1760 d09bc240 00000200 c032a52f
[90829.973601] 9bc0: d09bc5c0 00000000 00000000 00004932 00000000 ef5b9864 bfbdf2bd 00000000
[90829.981796] 9be0: e5afa800 00000000 00000054 d09bc240 00000000 00000000 00000000 00000000
[90829.989993] 9c00: 00000000 00000000 00000000 2e2746cd 00afa800 e22e4a80 00000001 00000000
[90829.998200] 9c20: f2559c98 c2840400 00000008 00000008 00004932 c032c541 f2559cb0 00000000
[90830.006409] 9c40: 255febb0 00000009 00000000 00000000 ef5b9864 f2559cb0 e1bc1760 c2840400
[90830.014612] 9c60: 00000000 00000001 00012cc0 00080000 00260000 f2559dd4 ef5b9864 00000001
[90830.022812] 9c80: 00000001 0000000b 00112cca e1bc186c 0000091c c032cfb1 00000000 ef5b9864
[90830.031006] 9ca0: 00000001 00000001 255febaf 00000000 00000000 00000000 ef5b9864 00000000
[90830.039202] 9cc0: 255febb1 00000000 00000200 00000000 c2840400 00000000 00000000 00000000
[90830.047396] 9ce0: 00000000 00000000 00000000 00000000 000048e0 bfbdf2bd 00260000 2e2746cd
[90830.055591] 9d00: bfb86090 f2559dd4 f2559dd4 c0286967 00000000 ef5b9864 00000000 00000000
[90830.063788] 9d20: 00000000 00000000 00000000 00000000 00000001 00000100 f2559d38 f2559d38
[90830.071985] 9d40: 00000000 2e2746cd 0000000a 0000000b e5afa800 f2559dd4 e1bc1878 c0286bc3
[90830.080182] 9d60: e5afa800 e1bc1868 ffffffeb 00400040 e1bc1878 e5afa800 e1bc1868 8c140000
[90830.088384] 9d80: f2559e4c e1bc1868 ef80aae4 e5afa800 000008fc f2559f28 000008fa c027dd25
[90830.096580] 9da0: e5afae4c ede0f780 ede0f7e8 000008fd f2559dec c15adf00 00000000 00000000
[90830.104777] 9dc0: 00001fa0 e5afa800 e5afa800 2e2746cd 00000000 ede0f780 e1bc1868 ede0f7e8
[90830.112973] 9de0: 00000926 00000001 00000001 00000000 00000000 2e2746cd 00000002 00926255
[90830.121170] 9e00: 00000004 008fabe0 00000000 e1bc1760 b117bb9c 00000001 f2559f28 c027dfc5
[90830.129370] 9e20: f2559f10 c0ae793f c250c988 00000000 e5afa800 c01b36e1 e5afa800 c01b3b53
[90830.137568] 9e40: e1bc1868 ede0f780 e5afa800 00000003 ef5b8cb8 ef80ab74 ef80aae4 00000000
[90830.145762] 9e60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[90830.153960] 9e80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[90830.162153] 9ea0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[90830.170347] 9ec0: 00000000 00000000 00000000 2e2746cd e5afa800 bfbe6225 ede0f780 e5afa800
[90830.178542] 9ee0: 00001fa0 f2559f80 b117bb9c 00000001 bfb87c80 c02f0a13 00000000 00000002
[90830.186737] 9f00: 00000001 f2559f00 c265aa00 00000000 00000000 00000000 b117bb9c 00001fa0
[90830.194933] 9f20: 00000001 00000000 ede0f780 00000000 008fabe0 00000000 00000000 00000000
[90830.203129] 9f40: 00000000 00004004 00000000 00000000 b12007d4 2e2746cd b12007d4 ede0f783
[90830.211332] 9f60: ede0f780 008fabe0 00000000 c01002a0 e5afa800 00000003 b120076c c02f114b
[90830.219536] 9f80: 008fabe0 00000000 c0102455 2e2746cd 00000001 00001fa0 b117bb9c 00000004
[90830.227731] 9fa0: 00000003 c0100061 00001fa0 b117bb9c 00000004 b117bb9c 00001fa0 00000000
[90830.235929] 9fc0: 00001fa0 b117bb9c 00000004 00000003 00001fa0 00001fa0 b12007f0 b120076c
[90830.244122] 9fe0: 00000003 b117bad0 b6ac36d1 b6a396c6 80030030 00000004 00000000 00000000
[90830.252311] Call trace:
[90830.252331] mmioset from exfat_get_block+0x58b/0x638 [exfat]
[90830.260706] exfat_get_block [exfat] from block_read_full_folio+0xf7/0x2b0
[90830.267634] block_read_full_folio from do_mpage_readpage+0x71/0x498
[90830.274031] do_mpage_readpage from mpage_readahead+0x8d/0xe4
[90830.279818] mpage_readahead from read_pages+0x4b/0x1e8
[90830.285078] read_pages from page_cache_ra_unbounded+0xbf/0x12c
[90830.291027] page_cache_ra_unbounded from filemap_get_pages+0x385/0x554
[90830.297674] filemap_get_pages from filemap_read+0xd1/0x34c
[90830.303276] filemap_read from vfs_read+0x1b3/0x228
[90830.308191] vfs_read from ksys_read+0x53/0xa8
[90830.312668] ksys_read from ret_fast_syscall+0x1/0x5c
[90830.317751] Exception stack(0xf2559fa8 to 0xf2559ff0)
[90830.322822] 9fa0: 00001fa0 b117bb9c 00000004 b117bb9c 00001fa0 00000000
[90830.331019] 9fc0: 00001fa0 b117bb9c 00000004 00000003 00001fa0 00001fa0 b12007f0 b120076c
[90830.339214] 9fe0: 00000003 b117bad0 b6ac36d1 b6a396c6
[90830.344288] Code: 3a04 dbf0 2b02 bfb8 (f80c) 1b01
[90830.349338] ---[ end trace 0000000000000000 ]---
[90830.354108] ------------[ cut here ]------------
[90830.358863] WARNING: CPU: 1 PID: 14406 at kernel/exit.c:886 do_exit+0x62d/0x744
[90830.366383] Modules linked in: nls_utf8 cifs cifs_arc4 nls_ucs2_utils cifs_md4 netfs exfat snd_usb_audio snd_hwdep binfmt_misc snd_seq_dummy snd_usbmidi_lib snd_seq_oss snd_seq_midi snd_seq_midi_event snd_seq snd_rawmidi snd_seq_device uas lima gpu_sched drm_shmem_helper axp20x_adc sunxi_cedrus(C) sun4i_gpadc_iio v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 sunxi_cir videobuf2_common videodev mc display_connector cpufreq_dt evdev brcmfmac_wcc sch_fq_codel bonding brcmfmac brcmutil cfg80211 rfkill dm_mod autofs4 ext4 mbcache jbd2 axp20x_usb_power axp20x_battery industrialio pinctrl_axp209 sun4i_gpadc pwm_sun4i sunxi phy_generic uio_pdrv_genirq pwrseq_simple uio realtek
[90830.427987] CPU: 1 UID: 1000 PID: 14406 Comm: mocp Tainted: G D C 6.12.30-current-sunxi #1
[90830.428023] Tainted: [D]=DIE, [C]=CRAP
[90830.428029] Hardware name: Allwinner sun7i (A20) Family
[90830.428036] Call trace:
[90830.428050] unwind_backtrace from show_stack+0x11/0x14
[90830.428091] show_stack from dump_stack_lvl+0x37/0x42
[90830.428114] dump_stack_lvl from __warn+0xbf/0xe8
[90830.428138] __warn from warn_slowpath_fmt+0x113/0x118
[90830.428161] warn_slowpath_fmt from do_exit+0x62d/0x744
[90830.428186] do_exit from make_task_dead+0x77/0x11c
[90830.428214] make_task_dead from die+0x2a5/0x364
[90830.428235] die from die_kernel_fault+0x6f/0x84
[90830.428258] die_kernel_fault from do_translation_fault+0x1/0x88
[90830.428283] do_translation_fault from 0xc160323c
[90830.428338] ---[ end trace 0000000000000000 ]---
The issue is easy enough to work around, simply downgrade to the working version:
# apt install linux-image-current-sunxi=25.2.3 armbian-firmware=25.2.3 linux-dtb-current-sunxi=25.2.3
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages will be DOWNGRADED:
armbian-firmware linux-dtb-current-sunxi linux-image-current-sunxi
0 upgraded, 0 newly installed, 3 downgraded, 0 to remove and 0 not upgraded.
Need to get 136 MB of archives.
After this operation, 3,704 kB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://fi.mirror.armbian.de/apt noble/main armhf armbian-firmware all 25.2.3 [94.1 MB]
Get:2 http://fi.mirror.armbian.de/apt noble/main armhf linux-dtb-current-sunxi armhf 25.2.3 [211 kB]
Get:3 http://fi.mirror.armbian.de/apt noble/main armhf linux-image-current-sunxi armhf 25.2.3 [41.5 MB]
Fetched 103 MB in 19s (5,509 kB/s)
dpkg: warning: downgrading armbian-firmware from 25.5.1 to 25.2.3
(Reading database ... 49560 files and directories currently installed.)
Preparing to unpack .../armbian-firmware_25.2.3_all.deb ...
Unpacking armbian-firmware (25.2.3) over (25.5.1) ...
dpkg: warning: downgrading linux-dtb-current-sunxi from 25.5.1 to 25.2.3
Preparing to unpack .../linux-dtb-current-sunxi_25.2.3_armhf.deb ...
Armbian 'linux-dtb-current-sunxi' for '6.12.20-current-sunxi': 'preinst' starting.
Armbian 'linux-dtb-current-sunxi' for '6.12.20-current-sunxi': 'preinst' finishing.
Unpacking linux-dtb-current-sunxi (25.2.3) over (25.5.1) ...
dpkg: warning: downgrading linux-image-current-sunxi from 25.5.1 to 25.2.3
Preparing to unpack .../linux-image-current-sunxi_25.2.3_armhf.deb ...
Armbian 'linux-image-current-sunxi' for '6.12.30-current-sunxi': 'prerm' starting.
Armbian 'linux-image-current-sunxi' for '6.12.30-current-sunxi': 'prerm' finishing.
Armbian 'linux-image-current-sunxi' for '6.12.20-current-sunxi': 'preinst' starting.
ls: cannot access '/var/lib/initramfs-tools': No such file or directory
Armbian 'linux-image-current-sunxi' for '6.12.20-current-sunxi': 'preinst' finishing.
Unpacking linux-image-current-sunxi (25.2.3) over (25.5.1) ...
Armbian 'linux-image-current-sunxi' for '6.12.30-current-sunxi': 'postrm' starting.
Armbian 'linux-image-current-sunxi' for '6.12.30-current-sunxi': 'postrm' finishing.
Setting up linux-image-current-sunxi (25.2.3) ...
Armbian 'linux-image-current-sunxi' for '6.12.20-current-sunxi': 'postinst' starting.
update-initramfs: Generating /boot/initrd.img-6.12.20-current-sunxi
I: The initramfs will attempt to resume from /dev/sda3
I: (UUID=ae1efffa-3fde-41fc-ab76-99e60ecca21c)
I: Set the RESUME variable to override this.
update-initramfs: Converting to u-boot format
Armbian: update last-installed kernel symlink to 'zImage'...
'/boot/zImage' -> 'vmlinuz-6.12.20-current-sunxi'
Armbian: Debian compat: linux-update-symlinks install 6.12.20-current-sunxi boot/vmlinuz-6.12.20-current-sunxi
I: /boot/vmlinuz.old is now a symlink to vmlinuz-6.12.20-current-sunxi
I: /boot/initrd.img.old is now a symlink to initrd.img-6.12.20-current-sunxi
I: /boot/vmlinuz is now a symlink to vmlinuz-6.12.20-current-sunxi
I: /boot/initrd.img is now a symlink to initrd.img-6.12.20-current-sunxi
Armbian 'linux-image-current-sunxi' for '6.12.20-current-sunxi': 'postinst' finishing.
Setting up linux-dtb-current-sunxi (25.2.3) ...
Armbian 'linux-dtb-current-sunxi' for '6.12.20-current-sunxi': 'postinst' starting.
Armbian: DTB: symlinking /boot/dtb to /boot/dtb-6.12.20-current-sunxi...
'dtb' -> 'dtb-6.12.20-current-sunxi'
Armbian 'linux-dtb-current-sunxi' for '6.12.20-current-sunxi': 'postinst' finishing.
Setting up armbian-firmware (25.2.3) ...
# apt-mark hold linux-image-current-sunxi armbian-firmware linux-dtb-current-sunxi
linux-image-current-sunxi set on hold.
armbian-firmware set on hold.
linux-dtb-current-sunxi set on hold.
