Hello, I tried Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img on my TV box x96q2 H313 2/16 board v4.0 ram k4b2g0446c hyh9, axp305. And I get the message:
[60]HELLO! BOOT0 is starting May 13 2020 14:05:42!
[65]BOOT0 commit : 593cf83
[68]set pll start
[70]periph0 has been enabled
[73]set pll end
[75]unknow PMU
[77]PMU: AXP806
[84]vaild para:8 select dram para0
[87]board init ok
[89]DRAM BOOT DRIVE INFO: V0.52
[92]the chip id is 0x5c00
[95]chip id check OK
[97]DRAM_VCC set to 1500 mv
[100]DRAM CLK =600 MHZ
[102]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[108]Actual DRAM SIZE =2048 M
[111]DRAM SIZE =2048 MBytes, para1 = 30fb, para2 = 8000000, dram_tpr13 = 6041
[124]DRAM simple test OK.
[127]rtc standby flag is 0x0, super standby flag is 0x0
[132]dram size =2048
[134]*****dram handle ok****
[138]card no is 2
[140]sdcard 2 line count 8
[142][mmc]: mmc driver ver 2019-12-19 10:41
[147][mmc]: set f_max to 50M, set f_max_ddr to 50M
[152][mmc]: mmc 2 bias 4
[160][mmc]: ***Try MMC card 2***
[191][mmc]: MMC 5.0
[193][mmc]: HSDDR52/DDR50 8 bit
[196][mmc]: 50000000 Hz
[198][mmc]: 15028 MB
[200][mmc]: ***SD/MMC 2 init OK!!!***
[267]Loading boot-pkg Succeed(index=0).
[271]Entry_name = u-boot
[280]Entry_name = monitor
[284]Entry_name = dtb
[288]tunning data addr:0x4a0003e8
[291]Jump to second Boot.
NOTICE: BL3-1: v1.0(debug):9fecd83
NOTICE: BL3-1: Built : 17:08:29, 2020-05-28
NOTICE: BL3-1 commit: 8
ERROR: Error initializing runtime service tspd_fast
NOTICE: BL3-1: Preparing for EL3 exit to normal world
NOTICE: BL3-1: Next image address = 0x4a000000
NOTICE: BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-00003-gb6e8ff6-dirty (Jul 21 2020 - 10:23:22 +0800) Allwinner Technology
[00.370]CPU: Allwinner Family
[00.373]Model: sun50iw9
I2C: ready
[00.378]DRAM: 2 GiB
[00.381]Relocation Offset is: 75ec5000
[00.423]secure enable bit: 0
[00.425]pmu_axp152_probe pmic_bus_read fail
[00.429]PMU: AXP806
[00.433]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.441]drv_disp_init
[00.472]__clk_enable: clk is null.
[00.478]drv_disp_init finish
[00.480]gic: sec monitor mode
[00.510]flash init start
[00.512]workmode = 0,storage type = 2
[00.515]MMC: 2
[00.517]get mem for descripter OK !
[00.526]get sdc2 sdc_boot0_sup_1v8 fail.
[00.530]io is 1.8V
[00.574]already at HSSDR52_SDR25 mode
[00.577]sunxi flash init ok
[00.581]Loading Environment from SUNXI_FLASH... OK
[00.591]usb burn from boot
delay time 0
weak:otg_phy_config
[00.605]usb prepare ok
[01.408]overtime
[01.412]do_burn_from_boot usb : no usb exist
[01.416]boot_gui_init:start
FAT: Misaligned buffer address (bbe839d8)
34 bytes read in 4 ms (7.8 KiB/s)
[01.546]boot_gui_init:finish
3686456 bytes read in 27 ms (130.2 MiB/s)
[01.590]hsddr 2-50000000
[01.592]hs200 5-200000000
[01.594]hs400 4-150000000
[01.596]get max-frequency ok 100000000 Hz
[01.600]0 0 0: 0 0 0
[01.605]update dts
** Unrecognized filesystem type **
[01.614]load file(ULI/factory/rootwait init.txt) error.
[01.626]load file(ULI/factory/snum.txt) error.
[01.630]name in map mac
[01.640]load file(ULI/factory/wifi_mac.txt) error.
[01.652]load file(ULI/factory/bt_mac.txt) error.
[01.663]load file(ULI/factory/selinux.txt) error.
[01.675]load file(ULI/factory/specialstr.txt) error.
[01.685]update part info
[boot efex] set misc : boot efex
[01.742]mmc exit start
[01.800]mmc 2 exit ok
[61]HELLO! BOOT0 is starting May 13 2020 14:05:42!
[66]BOOT0 commit : 593cf83
[69]set pll start
[72]periph0 has been enabled
[75]set pll end
[76]unknow PMU
[78]PMU: AXP806
[85]vaild para:8 select dram para0
[88]board init ok
[90]rtc[2] value = 0x5aa5a55a
[93]eraly jump fel
If i try MiniArch-20240715-6.16.0-board-h313.x96_q-SD-Image.img or MiniMyth2-armv8-master-14.3.0.r502-board-h313.x96_q-SD-Image.img, any version, nothing happens or I get the message "DRAM: DRAM setup is currently not supported". I need SD-card version. But at this point any option will do. Maybe someone has encountered such problems? What are the options for solving the problems of the sicxnull version or miniarch/minimyth2 version?
UPD1:
When boot android get this message:
[00.374]CPU: Allwinner Family
[00.377]Model: sun50iw9
I2C: ready
[00.381]DRAM: 2 GiB
[00.384]Relocation Offset is: 75ec5000
[00.426]secure enable bit: 0
[00.428]pmu_axp152_probe pmic_bus_read fail
[00.433]PMU: AXP806
[00.436]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.445]drv_disp_init
[00.475]__clk_enable: clk is null.
[00.481]drv_disp_init finish
[00.484]gic: sec monitor mode
[00.514]flash init start
[00.516]workmode = 0,storage type = 2
[00.520]MMC: 2
[00.521]get mem for descripter OK !
[00.530]get sdc2 sdc_boot0_sup_1v8 fail.
[00.535]io is 1.8V
[00.578]already at HSSDR52_SDR25 mode
[00.582]sunxi flash init ok
[00.585]Loading Environment from SUNXI_FLASH... OK
[00.595]usb burn from boot
delay time 0
weak:otg_phy_config
[00.608]usb prepare ok
[01.411]overtime
[01.415]do_burn_from_boot usb : no usb exist
[01.419]boot_gui_init:start
[01.549]boot_gui_init:finish
3686456 bytes read in 26 ms (135.2 MiB/s)
[01.592]hsddr 2-50000000
[01.594]hs200 5-200000000
[01.597]hs400 4-150000000
[01.599]get max-frequency ok 100000000 Hz
[01.603]0 0 0: 0 0 0
[01.608]update dts
[01.617]load file(ULI/factory/rootwait init.txt) error.
[01.629]load file(ULI/factory/snum.txt) error.
[01.633]name in map mac
[01.643]load file(ULI/factory/wifi_mac.txt) error.
[01.654]load file(ULI/factory/bt_mac.txt) error.
[01.665]load file(ULI/factory/selinux.txt) error.
[01.677]load file(ULI/factory/specialstr.txt) error.
[01.687]update part info
[01.705]update bootcmd
[01.707]No ethernet found.
Hit any key to stop autoboot: 0
[01.912]Starting kernel ...
[01.915]mmc exit start
[01.955]mmc 2 exit ok
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.170 (yxt-rd01@yxtrd01-Super-Server) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Tue Aug 11 11:46:00 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.027881] BOOTEVENT: 27.865165: ON
[ 0.272767] sunxi_i2c_probe()2209 - [i2c3] warning: failed to get regulator id
[ 0.273865] sunxi_i2c_probe()2209 - [i2c5] warning: failed to get regulator id
[ 0.329453] acx00_i2c_probe,l:282
[ 0.329625] [ac200] pwm is NULL! Just initialize it.
[ 0.330443] [ac200] pwm enable
[ 0.330477] [ac200] pwm is initialized
[ 0.330570] acx00_init_work,l:130
[ 0.331310] acx00_init_work,l:137
[ 0.331964] sunxi_i2c_do_xfer()1935 - [i2c5] incomplete xfer (status: 0x20, dev addr: 0x10)
[ 0.337604] [ac200] get ave_regulator_name failed!
[ 0.433136] failed to get standby led pin assign
�[ 0.438711] uart uart1: get regulator failed
[ 0.472391] [NAND][NE] Not found valid nand node on dts
[ 0.481160] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
[ 0.488059] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
[ 0.628738] hci: request ohci1-controller gpio:232
[ 0.820154] axp2101_pek: axp2101-pek can not register without irq
[ 0.830567] sunxi_ir_startup: get ir protocol failed
[ 0.838951] VE: get debugfs_mpp_root is NULL, please check mpp
[ 0.838951]
[ 0.847219] VE: sunxi ve debug register driver failed!
[ 0.847219]
[ 0.863567] mmc:failed to get gpios
[ 0.941205] mmc:failed to get gpios
[ 0.977947] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 0.985169] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 0.991622] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
[ 0.999399] [audio-codec]dachpf_cfg configurations missing or invalid.
[ 1.006781] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1.012748] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1.018656] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1.024570] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1.030494] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:160, pa_ctl_level:0, gpio-spk:0
[ 1.054863] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
[ 1.061670] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
[ 1.071222] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
[ 1.106837] ERROR: pinctrl_get for HDMI2.0 DDC fail
[ 1.117004] tv_probe()1435 - of_property_read_string tv_power failed!
[ 1.125383] tv_probe()1435 - of_property_read_string tv_power failed!
[ 1.206317] cpu cpu1: opp_list_debug_create_link: Failed to create link
[ 1.213841] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.221465] cpu cpu2: opp_list_debug_create_link: Failed to create link
[ 1.228930] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.236533] cpu cpu3: opp_list_debug_create_link: Failed to create link
[ 1.243985] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.720606] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 1.720606]
[ 1.738732] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
[ 1.738732]
[ 2.612742] FAT-fs (mmcblk0p15): bogus number of reserved sectors
console:/ $ [ 3.576869] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
[ 23.395613] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR EBE !!
[ 23.402157] sunxi-mmc sdc2: send manual stop command failed
[ 23.408822] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.415284] sunxi-mmc sdc2: send manual stop command failed
[ 23.421941] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.428371] sunxi-mmc sdc2: send manual stop command failed
[ 23.434993] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.441482] sunxi-mmc sdc2: send manual stop command failed
[ 23.448162] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.454568] sunxi-mmc sdc2: send manual stop command failed
[ 23.461302] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.467781] sunxi-mmc sdc2: send manual stop command failed
[ 23.474538] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.481019] sunxi-mmc sdc2: send manual stop command failed
[ 23.487675] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.494198] sunxi-mmc sdc2: send manual stop command failed
[ 23.500841] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.507332] sunxi-mmc sdc2: send manual stop command failed
[ 23.514122] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.520545] sunxi-mmc sdc2: send manual stop command failed
[ 23.527260] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.533644] sunxi-mmc sdc2: send manual stop command failed
[ 23.540345] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.546834] sunxi-mmc sdc2: send manual stop command failed
[ 23.553468] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.559989] sunxi-mmc sdc2: send manual stop command failed
[ 23.566662] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.573213] sunxi-mmc sdc2: send manual stop command failed
[ 23.579913] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.586323] sunxi-mmc sdc2: send manual stop command failed
[ 23.593095] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.599558] sunxi-mmc sdc2: send manual stop command failed
[ 23.606250] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.612690] sunxi-mmc sdc2: send manual stop command failed
[ 23.619407] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.625931] sunxi-mmc sdc2: send manual stop command failed
[ 23.632651] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.639072] sunxi-mmc sdc2: send manual stop command failed
[ 23.645837] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.652267] sunxi-mmc sdc2: send manual stop command failed
[ 23.658998] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.665391] sunxi-mmc sdc2: send manual stop command failed
[ 23.672094] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.678624] sunxi-mmc sdc2: send manual stop command failed
[ 23.685264] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.691785] sunxi-mmc sdc2: send manual stop command failed
[ 23.698528] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.704983] sunxi-mmc sdc2: send manual stop command failed
[ 23.711782] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.718228] sunxi-mmc sdc2: send manual stop command failed
[ 23.724966] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.731523] sunxi-mmc sdc2: send manual stop command failed
[ 23.738173] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.744671] sunxi-mmc sdc2: send manual stop command failed
[ 23.751325] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.757815] sunxi-mmc sdc2: send manual stop command failed
[ 23.764544] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.770973] sunxi-mmc sdc2: send manual stop command failed
[ 23.777730] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.784162] sunxi-mmc sdc2: send manual stop command failed
[ 23.790915] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.797446] sunxi-mmc sdc2: send manual stop command failed
[ 23.804129] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.810694] sunxi-mmc sdc2: send manual stop command failed
[ 23.817380] sunxi-mmc sdc2: smc 0 p2 err, cmd 25, WR RTO !!
[ 23.823873] sunxi-mmc sdc2: send manual stop command failed
[ 23.830352] sunxi-mmc sdc2: retry:set phase failed or over retry times
[ 23.837856] sunxi-mmc sdc2: retry:give up
[ 23.842667] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RTO !!
[ 23.848689] mmcblk0: error -110 sending status command, retrying
[ 23.855588] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RTO !!
[ 23.861791] mmcblk0: error -110 sending status command, retrying
[ 23.868690] sunxi-mmc sdc2: smc 0 p2 err, cmd 13, RTO !!
[ 23.874711] mmcblk0: error -110 sending status command, aborting
[ 23.881640] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !!
[ 23.887737] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !!
[ 23.893705] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !!
[ 23.899646] sunxi-mmc sdc2: smc 0 p2 err, cmd 6, RTO !!
[ 23.905557] mmc0: cache flush error -110
[ 34.483900] binder_alloc: 2990: binder_alloc_buf, no vma
[ 38.465719] apexd: Can't open /product/apex for reading : No such file or directory
[ 40.933841] binder: unexpected work type, 4, not freed
[ 59.496340] binder: unexpected work type, 4, not freed
[ 73.682650] audit: rate limit exceeded
[ 74.543261] binder_alloc: 5395: binder_alloc_buf, no vma
[ 75.490661] binder: unexpected work type, 4, not freed
