mdidis
  1. No. I have tried this one but nothing appear Tanix-tx6s-axp313_bookworm_edge_6.12.11.img.xz unfortunately
  2. Yes, followed the guide you linked on the other thread. Here is my dts. sun50iw9.dts
  3. Thanks. I have tried and compiled image, but when I boot with SD card nothing appears, and Serial interface seems that disconnects. I have tried both with "uboot" button pressed and not. These are, I think, the gpio you asked gpio_encrypt { compatible = "allwinner,gpio_encrypt"; gpio_number_sun = <0x05>; gpio1_value = <0x00>; gpio2_value = <0x01>; gpio3_value = <0x01>; gpio4_value = <0x01>; gpio5_value = <0x01>; gpio1_pin = <0x53 0x08 0x0d 0x01 0xffffffff 0xffffffff 0x00>; gpio2_pin = <0x53 0x08 0x09 0x01 0xffffffff 0xffffffff 0x00>; gpio3_pin = <0x53 0x08 0x01 0x01 0xffffffff 0xffffffff 0x00>; gpio4_pin = <0x53 0x07 0x06 0x01 0xffffffff 0xffffffff 0x00>; gpio5_pin = <0x53 0x07 0x07 0x01 0xffffffff 0xffffffff 0x00>; status = "okay"; linux,phandle = <0x17d>; phandle = <0x17d>; }; or these ones? boot_init_gpio { device_type = "boot_init_gpio"; status = "okay"; gpio0 = <0x53 0x08 0x0b 0x01 0xffffffff 0xffffffff 0x00>; gpio1 = <0x53 0x08 0x0c 0x01 0xffffffff 0xffffffff 0x01>; gpio2 = <0x53 0x08 0x0e 0x01 0xffffffff 0xffffffff 0x00>; };
  4. Thank you, will try asap. How can I do? Do you think is useful also 01_dtbdump_,sun50iw9.dtb that I have extracted through adb shell?
  5. Goodmorning, I have a Q plus TV Box with the chip Allwinner H616 v2.0 in configuration RAM: 4GB eMMC: 64GB . This is what is written on the box, but not completely trusted because was said also H6, instead of H616 that's actually is. These are some images of the pcb. I have tried to flash some random armbian, but nothing seems to work. From ttl serial this is a part of log, and I don't know why is found only 1GB of DRAM. https://i.ibb.co/1GSbZdRg/20250813-083105.jpg https://i.ibb.co/rG4zZ0s6/20250813-083122.jpg Which armbian you suggest to try out? If I start with pressing "UBOOT" button nothing appears on Serial console. Thanks in advance to all who could help me [344]DRAM BOOT DRIVE INFO: V0.645 [347]the chip id is 0x5000 [350]chip id check OK [354]DRAM_VCC set to 1500 mv [357]DRAM CLK =648 MHZ [359]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [366]Actual DRAM SIZE =1024 M [369]DRAM SIZE =1024 MBytes, para1 = 30eb, para2 = 4000000, dram_tpr13 = 6041 [378]DRAM simple test OK. [380]rtc standby flag is 0x0, super standby flag is 0x0 [386]boot0 Nand0 clk: 10MHz,PERI=600,N=4,M=15,T=10 [391]boot0 Nand Ecc clk: 20MHz,PERI=600,N=2,M=15,T=20 [396]NB0 : nand phy init ok [399]block from 4 to 11 [658]Check is correct. [660]OLD version: 0.0 [663]NEW version: 0.0 [738]load rotpk hash [801]load monitor-key hash [803]load monitor hash [1007]load boot-key hash [1009]load boot hash [1075]load vbmeta-key hash [1077]load vbmeta hash [1144]load recovery-key hash [1147]load recovery hash [1151]monitor entry=0x48000000 [1153]uboot entry=0x4a000000 [1156]optee entry=0x48600000 [1161]run out of boot0 NOTICE: BL3-1: v1.0(debug):be96482 NOTICE: BL3-1: Built : 18:32:32, 2021-04-21 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V1.0 NOTICE: secure os exist MESSAGE: [0x0] TEE-CORE: OP-TEE version: 5c40397e #1 Tue Feb 2 07:45:37 UTC 2021 arm NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.05 (Oct 25 2021 - 08:42:07 +0800) Allwinner Technology [01.251]CPU: Allwinner Family [01.253]Model: sun50iw9 I2C: ready [01.258]DRAM: 1 GiB [01.261]Relocation Offset is: 35ec5000 [01.296]secure enable bit: 1 [01.299]pmu_axp152_probe pmic_bus_read fail [01.303]PMU: AXP1530 [01.309]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
