svvolf
  1. before: Orange Pi Zero (H+), CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB TF card is Samsung Evo Plus 64GB; After writing the TF card with Win32DiskImager, the same issue occurred: normal boot-up and shutdown, but when executing a reboot, it gets stuck at the final stage of service termination before restarting. ...... [ OK ] Reached target shutdown.target - System Shutdown. [ OK ] Deactivated swap dev-zram0.swap - /dev/zram0. [ OK ] Reached target umount.target - Unmount All Filesystems. [ OK ] Reached target final.target - Late Shutdown Services. [ OK ] Finished systemd-reboot.service - System Reboot. [ OK ] Reached target reboot.target - System Reboot. [44967.125952] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument [44967.761002] reboot: Restarting system This is where it starts to lose responsiveness! after: Following someone's guidance, I was told to install or update u-boot: run armbian-install, then selected “Install/Update the bootloader on SD card (/dev/mmcblk0)”. After the update completed, needed to shut down the system and disconnect the power (the first time I performed a reboot here, but it got stuck again at the final stage of stopping services before restarting, just like before). so I had to disconnect the power, then plug it back in for an automatic boot-up. After that, performing a reboot worked normally without getting stuck). ...... [ OK ] Reached target shutdown.target - System Shutdown. [ OK ] Deactivated swap dev-zram0.swap - /dev/zram0. [ OK ] Reached target umount.target - Unmount All Filesystems. [ OK ] Reached target final.target - Late Shutdown Services. [ OK ] Finished systemd-reboot.service - System Reboot. [ OK ] Reached target reboot.target - System Reboot. [44967.125952] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument [44967.761002] reboot: Restarting system U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-Vd711-Bb703-R448a (Aug 16 2025 - 02:09:48 +0000) DRAM: 512 MiB Trying to boot from MMC1 ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-Vd711-Bb703-R448a (Aug 16 2025 - 02:09:48 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB Core: 69 devices, 18 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial,usbkbd Out: serial Err: serial Net: eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus USB EHCI 1.00 ...... You can see that immediately after the log entry "[44967.761002] reboot: Restarting system", the system begins booting.
