chuanzz
  1. The official sent me the Armbian SDK, which includes kickpi-k2b-v2 and v1. I tested it and it can boot normally. Wired/wireless networks and Bluetooth all work fine, but the OTG function just won’t work no matter what I try. (g_ether and g_serial not woring) Anyway, I hope it can be merged into Armbian. I only compressed the config and patch folders, which should be sufficient. https://we.tl/t-wtmI81zB5e
  2. I’ve sent the URL and details here, hoping they can take a look
  3. https://paste.armbian.com/raw/hohumivife
  4. I’ve spent way too much time on this, my back is killing me. I’d rather just buy a more common development board. My project didn’t require me to dig into all this u-boot and DTS stuff. So, fuck you KickPi. Here are all the DTS files I extracted from https://github.com/pyavitz/debian-image-builder and the official Linux SDK. Hopefully someone else can finish this job. dts.zip
  5. Still no network. I checked the official SDK, it uses the following hardware: Wired network: Allwinner GMAC driver + external PHY; Wireless network: AIC8800 series WiFi module driver; Bluetooth: AIC8800 Bluetooth Low Energy driver; USB network: RTL8152 USB to Ethernet driver. Does this have any impact?
  6. The parameters I’m using were extracted from the official Linux SDK using GPT. At least the DRAM parameters are functional. Debian can boot and log in normally, but there’s no wired network or WiFi/Bluetooth. I’m currently investigating why this is happening.
  7. I used ur project https://github.com/pyavitz/debian-image-builder changed this file "patches\uboot\v2025.07\sun50i-h618\002-Add-board-KickPi-K2B.patch" +CONFIG_OF_UPSTREAM=y +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h618-kickpi-k2b" +CONFIG_SPL=y +CONFIG_DRAM_SUNXI_DX_ODT=0x03030303 +CONFIG_DRAM_SUNXI_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUNXI_CA_DRI=0x1f12 +CONFIG_DRAM_SUNXI_ODT_EN=0x0 +CONFIG_DRAM_SUNXI_TPR0=0xc0001002 +CONFIG_DRAM_SUNXI_TPR1=0x30fb +CONFIG_DRAM_SUNXI_TPR2=0x0000 +CONFIG_DRAM_SUNXI_TPR6=0x33808080 +CONFIG_DRAM_SUNXI_TPR10=0x2f1107 +CONFIG_DRAM_SUNXI_TPR11=0xddddcccc +CONFIG_DRAM_SUNXI_TPR12=0xeddc7665 +CONFIG_DRAM_SUNXI_TPR13=0x40 +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_DRAM_CLK=648 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_SUN8I_EMAC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_PHY_REALTEK=y +CONFIG_RTL8211F_PHY_FORCE_EEE_RXC_ON=y +CONFIG_RGMII=y +CONFIG_RMII=y +CONFIG_AXP313_POWER=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_MUSB_GADGET=y and maked a u-boot the debian was starting I was testing it
  8. verbosity was 7 already But no more log
  9. I build a u-boot with it dd latest armbian.img and this u-boot, it showed: ▒[40]HELLO! BOOT0 is starting!r = 0x1d3 [43]BOOT0 commit : 4b34f2890a [46]set pll start [48]periph0 has been enabled [51]set pll end [54]unknow PMU [56]unknow PMU [59]PMU: AXP1530 [64]vaild para:15 select dram para1 [68]board init ok [69]enable_jtag [71]DRAM BOOT DRIVE INFO: V0.651 [74]the chip id is 0x2000 [77]chip id check OK [80]DRAM_VCC set to 1500 mv [86]read_calibration error [92]read_calibration error [98]read_calibration error [104]read_calibration error [110]read_calibration error [116]read_calibration error [122]read_calibration error [128]read_calibration error [135]read_calibration error [141]read_calibration error [143]retraining final error [152][AUTO DEBUG]32bit,1 ranks training success! [164]DRAM CLK =648 MHZ [166]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [174]Actual DRAM SIZE =2048 M [177]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, dram_tpr13 = 6041 [190]DRAM simple test OK. [193]rtc standby flag is 0x0, super standby flag is 0x0 [198]dram size =2048 [201]Use rtc to store dram tuning para [205]card no is 0 [207]sdcard 0 line count 4 [209][mmc]: mmc driver ver 2021-10-12 13:56 [214][mmc]: b mmc 0 bias 4 [222][mmc]: Wrong media type 0x0 [225][mmc]: ***Try SD card 0*** [240][mmc]: HSSDR52/SDR25 4 bit [243][mmc]: 50000000 Hz [245][mmc]: 119850 MB [247][mmc]: ***SD/MMC 0 init OK!!!*** [319]Loading boot-pkg Succeed(index=0). [323][mmc]: b mmc 0 bias 4 [325]Entry_name = u-boot [332]Entry_name = monitor [336]Entry_name = dtbo [339]Entry_name = optee [343]Entry_name = dtb [346]mmc not para [347]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):54937d5 NOTICE: BL3-1: Built : 17:44:59, 2021-12-13 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V2.0 NOTICE: secure os exist MESSAGE: [0x0] TEE-CORE: OP-TEE version: 81ab7a47 #1 2020年 05月 06日 星期三 02:40:04 UTC arm NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 and I found this: [177]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, dram_tpr13 = 6041 is this para what we need?
  10. This one failed with "DRAM:This DRAM setup is currently not supported" I found something from kickpi's site:Linux_SDK_Compilation. including building u-boot https://github.com/tan-zhihao1/kickpi-book/blob/master/h618/en/04-SDK_Compilation_Guide/02-Linux_SDK_Compilation.md Its too huge so I deleted the folder "source" and "toolchains". hope it could help I tried to upload here but it shows errors. try this url: https://we.tl/t-t92S5rlCzD
  11. U-Boot SPL 2025.07 (Oct 24 2025 - 06:19:19 -0400) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.12.5(debug):lts-v2.12.5 NOTICE: BL31: Built : 06:13:32, Oct 24 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0cd800, model: KickPi K2B INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: Probing for PMIC on I2C: INFO: PMIC: found AXP313 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. U-Boot 2025.07 (Oct 24 2025 - 06:19:19 -0400) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: KickPi K2B DRAM: 2 GiB Core: 74 devices, 23 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@5020000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether starting USB... USB EHCI 1.00 USB OHCI 1.0 USB EHCI 1.00 USB OHCI 1.0 USB EHCI 1.00 USB OHCI 1.0 Bus usb@5101000: 1 USB Device(s) found Bus usb@5101400: 1 USB Device(s) found Bus usb@5200000: 1 USB Device(s) found Bus usb@5200400: 1 USB Device(s) found Bus usb@5310000: 1 USB Device(s) found Bus usb@5310400: 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 1 ms (4.4 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 181 bytes read in 1 ms (176.8 KiB/s) Load fdt: /boot/dtb/allwinner/sun50iw9-kickpi-k2b.dtb 67673 bytes read in 5 ms (12.9 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/allwinner/overlay/h618-fixup.scr' 17096334 bytes read in 704 ms (23.2 MiB/s) 37613576 bytes read in 1549 ms (23.2 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x426d0000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 17096270 Bytes = 16.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 48fb2000, end 49fffe4e ... OK Loading Device Tree to 0000000048f39000, end 0000000048fb1fff ... OK Working FDT set to 48f39000 No RNG device Starting kernel ... and stuck here. It makes differences!!
  12. From what I’ve found, the K2B has three revisions; mine is REV 2.2 (it’s printed right on the PCB). Looks like they swapped the RAM from DDR4L to DDR3—mine has DDR3 chips on board—so that might be why it’s acting up. Kickpi’s site barely loads from China; I really dislike that company, the documentation is almost non-existent. I found some here: https://github.com/tan-zhihao1/kickpi-book/tree/master/h618/en Still, I want to crack the problem. With the current sale the 2 GB + 0 GB version is only 78 CNY (about 11 USD), which is hard to pass up. Thanks for getting back to me. K2B.zip
  13. I dd the armbian.img > emmc. and remove my sd card still the same output
  14. I dont think so. I can boot the official system “kickpi-k2b-ubuntu-jammy-desktop-xfce-linux-5.4.125-20250901.img” using this SD card
  15. I am using this version "Armbian_community_25.11.0-trunk.334_Kickpik2b_trixie_current_6.12.47_minimal.img". It shows U-Boot SPL 2025.07 (Oct 20 2025 - 18:19:29 +0800) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.07 (Oct 20 2025 - 18:19:29 +0800) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.07 (Oct 20 2025 - 18:19:29 +0800) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.07 (Oct 20 2025 - 18:19:29 +0800) DRAM:This DRAM setup is currently not supported. resetting ... U-Boot SPL 2025.07 (Oct 20 2025 - 18:19:29 +0800) DRAM:This DRAM setup is currently not supported. The system just loops this message and never proceeds. Has anyone encountered this issue before? Any suggestions or solutions would be greatly appreciated. Thanks in advance!
