ComProf
7 -
Wifi works normaly only trought NetworkManager.
I`ll already done it. Switched to original Btt image. Understand what that board is didn`t love any sd-card. I`ll stopts on AP32GMCSH10UB-RA card. If card didn't made friends with the board it not boot,reboot`s,power off, halt`s.... IO pins i didnt use.... I`ll swithed to ch340 as uart, because it`s understand 3.3 and 5v levels. The board only 3.3 CAN i use on RP2040+can chip, what cost only 5$(in total), not 15$ for btt can. in a end of can bus i`ll use EBB42 so it`s have all i need.... It`s about I2C bus. Thats my story If u need help, free to ask. I`ll will help if i coud
Hello. BTT says what BTT Pi and CB1 is same, but realy not. Dunno why i brought what board. But now I owner of this "piece of ****" So. New board, clean install v25.11.2 for BigTreeTech CB1 running Armbian Linux 6.12.58-current-sunxi64 Packages: Debian stable (trixie) armbianEnv: overlays=gpu tft35_spi extraargs=fbcon=rotate:2 fbcon=rotate:2 for screen rotation, because armbian not from btt and didn`t have feature like param_tft35_spi_rotate Next, help me to determine how to enable UARTs and I2C From BIGTREETECH_Pi_V1.2.1 Hardware Pdf UART0: CPUX-UTX CPUX-RX UART2 (May work as i2c0; uart2-pi-pins; i2c0-pins ) Pi5 Pi6 UART3 (May work as i2c2; uart3-pi-pins; i2c2-pi-pins ) Pi9 Pi10 I2C (i2c4-ph-pins; spi1-pins): PH6 PH7 (must work, i`ll think i2c4-ph overlay present) All pins present in sun50i-h616-bigtreetech-cb1-sd, but didnt have overlays for it... I wish to stay uart0 for u-boot console first uart setup for klipper connections to mcu. any help? If I understand right PH6 is 7*32+6=230 gpioinfo output line 230: unnamed input consumer=kernel line 231: unnamed input consumer=kernel cat /sys/kernel/debug/gpio gpiochip0: GPIOs 0-287, parent: platform/300b000.pinctrl, 300b000.pinctrl: gpio-71 ( |spi0 CS1 ) out hi ACTIVE LOW gpio-74 ( |i2c-gpio ) out hi gpio-75 ( |spi0 CS0 ) out hi ACTIVE LOW gpio-76 ( |i2c-gpio ) out hi gpio-77 ( |spi0 CS2 ) out lo gpio-78 ( |dc ) out hi gpio-166 ( |:wifi_power ) out hi gpio-207 ( |:wifi_wake ) out hi gpio-210 ( |reset ) out hi ACTIVE LOW gpio-229 ( |led-0 ) out lo ACTIVE LOW
i`ll already fried that lcd. So this is the end Because short circuit is been in lcd, orange is a live for now. try to move on hdmi lcd+touch. Thanks for U`r help robertoj.
He works as ili9341 and as ili9486. I use it now as ili9486. I`ll go further to make it work as native device. DRM frambuffer its something what needs to be kernel recompiled... as i know? And if i want to use it natively, i must edit or recompile u-boot.... DRM support for ILI9486 display panels modulename: ili9486.ko configname: CONFIG_TINYDRM_ILI9486 Linux Kernel Configuration └─>Device Drivers └─>Graphics support └─>Direct Rendering Manager (XFree86 4.1.0 and higher DRI support) └─>SPI support └─>DRM support for ILI9486 display panels In linux kernel since version 4.14.326 (release Date: 2023-09-23) DRM driver for the following Ilitek ILI9486 panels: * PISCREEN 3.5" 320x480 TFT (Ozzmaker 3.5") * RPILCD 3.5" 320x480 TFT (Waveshare 3.5") If M is selected the module will be called ili9486. I will use it for KlipperScreen 😆 But as i se how hard is working that orangePi PC,i`ll doubt if i need this... Any way i`ll try )) Yes. But HDMI not connected. On OrangePiOne image its switching. If HDMI is connected its use it with no output to SPI. But if no HDMI present its use SPI as basic overlay On the same board. Because OPiOne had only 1 usb, OPiPC work only 1 usb ))) if whey work all 3, i`ll didnt open up a topic 😑 ili9486.dts
I`ll think its china lcd, it`s been presented many ears ago by someone to me. Thanks to your sugestions. I read it before topic up. As U can read, it working now, with touch The last question is how to output to it when system boots... Something like auto switch from HDMI to SPI LCD. Or just SPI LCD output after U-Boot loading. rc.local with con2fbmap 1 1 in it is not an good thing. Any Advice?
Hello, I`ll try to hook up display to OpangePi PC, But have no output. My English is not native so i`ll try to write in simlpe way. image Armbian_23.8.1_Orangepipc_jammy_current_6.1.47_minimal.img.xz my dts: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&spi0>; __overlay__ { status = "okay"; // cs-gpios = <&pio 0 9 0>,<&pio 0 8 0>; /* PA9=CS0 for LCD, PA8=CS1 for touch */ display: display@0 { compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <20000000>; txbuflen = <65536>; rotate = <270>; bgr = <0>; fps = <30>; buswidth = <8>; regwidth = <16>; height = <480>; width = <320>; reset-gpios = <&pio 0 2 1>; /* PA20 */ dc-gpios = <&pio 0 71 0>; /* PA10 */ debug = <0>; init = <0x10000b0 0x00 // Interface Mode Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x10000C0 0x0D 0x0D // Power Control 1 0x10000C1 0x43 // Power Control 2 0x10000C5 0x00 0x48 0x80 // VCOM Control 1 0x10000C7 0x00 // VCOM Control 2 0x1000036 0x28 // Memory Access Control (Rotacao) 0x100003A 0x55 // Pixel Format Set (16bit) 0x10000B1 0xB0 0x11 // Frame Rate Control 0x10000F0 0x01 // Enable Extended Comand Set 0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control 0x1000026 0x01 // Gamma Set 0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00 // Positive Gamma Correction 0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F // Negative Gamma Correction 0x10000B6 0x02 0x02 0x3B // Display Function Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x1000029>; // Display ON }; // xpt2046: xpt2046@1 { // compatible = "ti,ads7846"; // reg = <1>; // spi-max-frequency = <2000000>; // interrupts = <0 7 2>; /* high-to-low edge triggered */ // interrupt-parent = <&pio>; // pendown-gpio = <&pio 0 7 0>; // ti,keep-vref-on = <1>; // ti,x-min = /bits/ 16 <200>; // ti,x-max = /bits/ 16 <3900>; // ti,y-min = /bits/ 16 <200>; // ti,y-max = /bits/ 16 <3900>; // ti,x-plate-ohms = /bits/ 16 <60>; // ti,pressure-max = /bits/ 16 <255>; // ti,swap-xy = <1>; // }; }; }; }; when board boots, display switch from white to black. Without console output. gpio readall - looks good. all pins present. when I try Armbian_25.8.1_Orangepione_noble_current_6.12.43.img.xz board boots. add overlay to it, by armbian-add-overlays remove HDMI cable. (Really good first-config over ssh, why not to add this to other boards, like mine?) reboot Display works(Ony if HDMI is unpluged), with output of boot Armbian. I`ll think this something wrong with output on spi LCD over OrangePi PC Armbian build, or sometning like that way.... Any advise? UPD: Ok. I get it to work.(Armbian_23.8.1_Orangepipc_jammy_current_6.1.47_minimal.img.xz) ili9341 may be changed to ili9486. Didn`t matter...why? dmesg | grep graphics [ 9.406143] graphics fb1: fb_ili9486 frame buffer, 480x320, 300 KiB video memory, 64 KiB buffer memory, fps=31, spi0.0 at 16 MHz con2fbmap 1 1 and it works.... UPD 2: ili9486.dtbo With touch working, tested trought evtest
