rk32
  1. I once got the TVBOX to boot into recovery by flashing the raw mmc image directly to a sdcard and then powering on the tvbox with the sdcard
  2. You can backup the mmc using multitool script and on a pc or phone extract the resulting gz file. Then from this raw disk image you need to get the offset and size of the system partition and then use dd to get the system partition out. After that you can make changes to files in the raw partition image and write the whole image back to the same offset. Never tried something like this but if it is possible to get into recovery mode and try if adb over usb is available then editing the system partition would be easier. The first method might worsen things so having the gz file saved at a safe place will be better
  3. Also, mmcblk2boot0 and mmcblk2boot1 should either have the bootloader or in my case were filled with null bytes. mmcblk2rpmb probably has something to do with TEE OS. Having a backup of mmcblk2 is what that matters
  4. If the internal storage has android installed then it doesn't needs to have a partition table. Multiple partitions show up in android because the partition offset and size is passed with kernel commandline, you can just backup the mmc as a raw image and restore it as it is anytime later. Multitool or Armbian can't recognize the partitions of Android in this tvbox as they need a partition table to be present in the initial bytes else they treat the whole mmc as raw data.
  5. Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ?
  6. I solved the issue ! I flashed the latest armbian release raw image to the sdcard and plugged it in the TV box. It magically booted from the SDCard and now I have mmcblk2 as a block device. Now I can run armbian-install command to get everything going correctly.
  7. Just to add, Armbian boots upto systemd and then gets stuck at loading some scripts. This image gives some additional information.
  8. Hi, So, Previously this massage (No emmc) appeared if the preinstalled Android was able to boot up completely and then restarted by repowering while the sdcard was inserted or the tvbox was rebooted while the sdcard was in the slot, however this got fixed if the device was powered off during the android bootanimation but after accidentally installing an incomplete image of latest armbian release I am no longer able to get the emmc working even after trying restarting at various boot levels. I have found others experiencing the same issue in this post but according to the circumstances I am in I think my issue might have a different solution. Any way through which this issue can be solved ? This might help : root@multitool:~# dmesg -T | grep mmc2 [Tue Jan 6 21:06:28 2026] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3) [Tue Jan 6 21:06:28 2026] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [Tue Jan 6 21:06:28 2026] mmc2: Card stuck in programming state! __mmc_switch [Tue Jan 6 21:06:28 2026] mmc2: error -110 whilst initialising MMC card I have also attached the whole dmesg log and lsblk output if needed. multitool-ssh-output.txt
  9. I have a RK3228A TV Box which is able to properly boot armbian when flashed to its eMMC (no rknand) . However I don't use Armbian much often, probably a maximum of two to three times a month. I want to keep stock Android on eMMC, for video playback on the YouTube app is much faster compared to in firefox and Android has proper remote support which Armbian lacks. I tried flashing the armbian community image on the sdcard but the device didn't boot from sdcard unless the eMMC was wiped. I found that multitool is able to always boot from sdcard irrespective of whatever is in the emmc. After doing some research on the multitool build process, I think I need a properly configured idbloader, uboot and tee binary and then place them at proper offsets in the image, however the Armbian image already contains different data at those offsets. So, how can I build an Armbian image that can be booted from sdcard without wiping the eMMC ?
