gpupoor
13 -
Expected default graphics acceleration for RK3588?
gpupoor replied to gpupoor's topic in Orange Pi 5 Plus
Also, interesting to see your updates. I keep seeing a lot related to GStreamer, will need to look more into that. -
Thank you for your thoughts @usual user. I'm stuck with how to use Fedora as a root filesystem with Armbian. I'm reading that it's possible to use Fedora with the SBC, and I'm understanding it will work successfully with 6.18, but I think the expectation is to start with the raw distro, not anything Armbian related. Would be happy to learn I'm missing something, but current expectation is to skip Armbian and start with Fedora and build it all from the ground up. -
@usual user I've got a good handle on your setup through random posts, but I haven't been able to figure out how you got there. Is there something Armbian available that I'm missing, or are you following the Fedora docs, or your own process? Hoping there's something published that I haven't yet found. -
Still working through things, but FYI I was able to get 6.18 going on Ubuntu with some small effort. GPU needs work but still beats CPU, NPU looks great. -
Thanks for confirming. That makes 6.18 look very compelling. I have some ideas for how I'd like to present this and I'm finding myself wanting to flesh out my overview... If anyone has preferences for a better place than my PR comment to publish please let me know. -
Making some assumptions... you're 6.18 + Mesa 25.3 + Teflon delegate for the TensorFlow Lite tests? -
Thanks @KhanhDTP, this is great. I tried to stick with approaches that have made their way into official channels, but I'm happy to include because it's very cool to have a full working path identified (B2). I think I understood your setup but please let me know if I missed anything. Again, not sure where/how the best place to keep track of this is so in the absence of anything better I'll use the PR, but happy to migrate to another location. -
Edit: I'm not sure how to format nicely here... so I updated the related PR. That said, this probably isn't the best reference location for this. In any case, posting in case helpful for anyone else. If it's useful for the project to better community (and potentially automate) some of this I'm happy to get involved, but here's what I've got for now: There are fundamentally two driver paths for RK3588: libMali path - Enables NPU for ML inference, basic GPU only Panthor path - Enables full GPU acceleration, no NPU Within each path, you can choose headless or desktop (XFCE/GNOME), but: libMali + desktop = slow rendering (software only) Panthor + desktop = smooth rendering (hardware accelerated) Key insight: The NPU and GPU hardware are separate, but the software drivers conflict. You must choose which accelerator matters more for your use case. Additional constraint: Kernel matters - NPU only works on 6.1 vendor kernel. Mainline 6.12 has no NPU support but best GPU drivers. This creates a matrix of ~6 viable configurations, each optimized for different workloads (production ML, ML development, desktop, latest kernel, etc). More detailed breakdown: https://github.com/armbian/build/pull/8979#issuecomment-3587135022 -
Thank you @KhanhDTP. I think I have a pretty good handle on how (and your post on that thread was in particular very helpful, thank you). It looks like a lot of people here are desktop optimized. My plan is headless, so expectation is 25.11.1 / 6.1 and libMali route but with RKNN (XFCE only for occasional desktop, Gnome is too hungry, XFCE + X11 + software rendering is fine on rare occasions I'd need it). I think the question I was trying to ask is more along the lines of understanding what to expect for the default, and if it made sense to enable one of the drivers by default, but I'm realizing there are proprietary dependencies and enough obscure use cases that this gets more challenging. Thanks to everyone for all of the thoughts, hard to imagine navigating all of this without your contributions. -
Digging deeper @Igor... I tried 25.11.1 Noble Gnome Vendor 6.1.115 from today, and am also seeing Mali-G610. However it's [disabled for xfce](https://github.com/armbian/build/blob/d2e208ace18b8003f926057ddfc038f8cce0bce0/extensions/mesa-vpu.sh#L19). I'm also reading some conflicting info so guessing there have been other conversations I'm not aware of. I started another post to try and better understand expectations.
I understand that panthor is not supported for wayland but in that case I would expect libmali to fill in... but I ended up with lvmpipe. The overlay along with another recent post led me to believe that panthor was the expected default and libmali was an artifact, but I'm now questioning that after finding a thread identifying use cases where libmali can be preferred and a comment suggesting panthor wouldn't be available until 6.13. As a result, I am now questioning if there is a reason that software acceleration is the default and the user is expected to determine which path they want to go? I know support for the hardware has been slow going so I understand that it's not well supported yet, but hoping to get a better handle on expectations. Is there an expected default for a Rockchip RK3588 SoC with the Mali‑G610 GPU? Does it vary between 6.1/6.12 and the desktop/server builds?
Bad News: same issue with 25.11.1 / 6.12.58, and a few others... Worse News: The issue affects all rk3588's (Orange Pi 5/5B/5+, Rock 5A/5B/5C, etc.). Good News: PR is a permanent fix for all images, and also identifies an immediate workaround that only requires a reboot (add "overlays=panthor-gpu" to /boot/armbianEnv.txt). https://github.com/armbian/build/pull/8979
