Malay
17 -
Thank you for such a detailed answer! I'll try to explain a little why I need this. I use OpiRV2 not only as a server for my applications (and, in a sense, for testing some add-ons for automating my home), but also to use OpiRV2 to install Kodi for viewing my home server tvheadend (as they say, to use 2 in 1 to the fullest). But this is impossible without hardware video decoding. I use Kodi without running the Mate and XFCE desktops - because from experience, to use hardware video decoding, you need to run Kodi with the /usr/bin/kodi-standalone --windowing=gbm parameter on single-board motherboards. This works fine on OpiZero3, etc., but here it's a pain in the ass 🙂 Even SD video is completely slow because software codecs are used. I understand that you don't need this and are not interested in it, so I'll just say - thank you for the great work you've done. PS: Regarding Ubuntu-Noble, which can be downloaded from Xunlong - which image are you talking about? If it's from here - http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-Pi-RV2.html , then it's terrible - nothing works there, including HDMI audio.
Hello @sven-ola ! It's sad. I had a small hope 🙂 But still, thank you very, very much for your work on the firmware! After removing sudo rm -r cache/ output/ -f and adding the command SKIP_ARMBIAN_REPO=yes - WiFi now works
I confirm that when building an image with the Edge 6.18 kernel, WiFi does not work. Also, when building an image with the Xfce desktop, the image is approximately 3 GB (it should be more than 4 GB), but it is not there, only the command line works.
Hello, sven-ola! First of all, thank you very much for your work! HDMI audio now works well on the Edge. Secondly, I'm not particularly knowledgeable about this, so please forgive me in advance for this possibly stupid question 🙂 It's impossible to implement video hardware acceleration support in the firmware, from here - https://sdk.spacemit.com/en/faqs/ ? If I understand correctly, patched versions of FFmpeg and GStreamer are needed, and they should also be integrated in firmware into the k1x-vpu-firmware and mpp . Is this possible? When playing any video (even at very low resolution), there is terrible lag. The board should easily support 4K HEVC, but it can't play 720p video properly. At the same time, the Banana Pi BPI-F3 board with similar technical characteristics copes with video 4K HEVC https://docs.banana-pi.org/en/BPI-F3/BananaPi_BPI-F3.
Hello @sven-ola! Yesterday, everything built fine for me using your git orangepi-rv2 branch with the EDGE kernel. After making the changes, Today, when applying the latest fixes I got an error while compiling the image. I used this build config ./compile.sh CPUTHREADS=$(nproc) BOARD=orangepirv2 BRANCH=edge RELEASE=trixie KERNEL_CONFIGURE=no BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT_CONFIG_NAME=config BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=xfce KERNEL_GIT=shallow The error log is like this [🌱] SHA1 of commit bfeeda1491b5366aa5798a86cf6f3621536b171c [ 'bfeeda1491b5366aa5798a86cf6f3621536b171c' ] [🌱] Reversioning package [ re-version 'armbian-zsh(deb)::1-SAbfee-B07a9-R448a' to '26.02.0-trunk' ] [🌱] artifact [ armbian-plymouth-theme :: armbian-plymouth-theme() ] [🌱] Reversioning package [ re-version 'armbian-plymouth-theme(deb)::1-B5bd9-R448a' to '26.02.0-trunk' ] [🌱] artifact [ armbian-bsp-cli :: armbian-bsp-cli() ] [🌱] Using extlinux, regular bootscripts ignored [ SRC_EXTLINUX=yes ] [🌱] Reversioning package [ re-version 'armbian-bsp-cli-orangepirv2-edge(deb-tar)::1-PC0cac-Vfcc4-Hba69-B8122-R756d' to '26.02.0-trunk' ] [🌱] artifact [ armbian-desktop :: armbian-desktop() ] [🌱] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a ] Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a": ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a: not found [🌱] Artifact is not available in remote cache [ ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a ] /root/orangepi-rv2/lib/functions/compilation/packages/armbian-desktop-deb.sh: line 25: AGGREGATED_PACKAGES_DESKTOP_COMMA: AGGREGATED_PACKAGES_DESKTOP_COMMA is not set [💥] Exiting with error 1 [ at /root/orangepi-rv2/lib/functions/compilation/packages/armbian-desktop-deb.sh:1 compile_armbian-desktop() --> lib/functions/compilation/packages/armbian-desktop-deb.sh:1 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_armbian-desktop_build_from_sources() --> lib/functions/artifacts/artifact-armbian-desktop.sh:71 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:102 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208 main() --> ./compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [✨] Repeat Build Options [ ./compile.sh BOARD=orangepirv2 BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no CPUTHREADS=8 DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=trixie ] [🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-436f72e6-3064-4b72-8a4a-64d579c2ea1f.log.ans ] Do I need to clear all previous build data? Or how can I fix this error? Thank you.
Unfortunately, English is not my native language, and you may have misunderstood me. I apologize. I didn't mean to do anything like that. And I am grateful for your work! So, following your suggestion, I compiled the versions from your other git branch - git clone https://github.com/sven-ola/armbian-build.git --branch orangepi-rv2-ky ./orangepi-rv2-ky I first tried building an image with Orangepirv2_noble_current_6.6.99_xfce_desktop. The network worked, and booting from the rear m.2 2280 also worked, but unfortunately, there was no HDMI video, just a black screen. Then I tried building a different build with Orangepirv2_trixie_current_6.6.63_xfce_desktop, and lo and behold, almost everything worked – the network worked, there was HDMI sound, HDMI output worked, Bluetooth worked, and the built-in WiFi worked. I just have one question: is video really that bad on RISCV? It's impossible to watch anything, it's incredibly slow. I assume they're using software video decoding?
Hello. Thank you for your work on orangepirv2. I have a board with 2 Gb of RAM. I compiled it on your git https://github.com/sven-ola/armbian-build/tree/orangepi-rv2 Armbian-unofficial_26.02.0-trunk_Orangepirv2_noble_current_6.6.99_xfce_desktop.img and Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_xfce_desktop.img Booting was done from the rear M.2 2280 1TB Armbian-unofficial_26.02.0-trunk_Orangepirv2_noble_current_6.6.99_xfce_desktop.img The download went fine. The network is working, HDMI video is working. is HDMI audio not working (I was upset by this fact) Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_xfce_desktop.img It won't load, the network isn't working, and there's no HDMI output. I tried your image and the same behavior - It won't load, the network isn't working, and there's no HDMI output. Your image is not working with the rear M.2?
For anyone experiencing similar issues with the Luckfox Lyra Ultra W and installing the Armbian firmware, I compiled Ubuntu 24.04.3 from this repository - https://github.com/markbirss/rk3506-ubuntu Initially, it lacked kernel-level support for many programs. I rebuilt the kernel with this support, and now Docker works perfectly. The firmware is good, and I think it will help many at this stage. For now, I really hope the Armbian firmware developer fixes the broken firmware (although I'm not sure, as they're unfortunately almost unresponsive to my messages). Download Ubuntu 24.04.3 with Docker support for the Luckfox Lyra Ultra W - https://disk.yandex.ru/d/PlIW_k9Ma3i5aA Username: root Password: root sudo apt update passwd sudo adduser ++++ sudo usermod -aG sudo ++++ sudo apt install apt-utils iptables bluez cifs-utils wget curl dbus mc git curl curl -fsSL get.docker.com | sh Setting up WiFi via USB connection of the board to the computer and launching the adb server - https://wiki.luckfox.com/Luckfox-Lyra/Login adb shell "cd /home/lyra/aic800/ && make install; reboot" #test adb shell nmcli dev wifi list #connect nmtui Good luck!
Thank you! Unfortunately, this didn't help. The device won't boot at all and immediately goes into MASKROM after rebooting. I just built Ubuntu 24.04.3 from here - https://github.com/markbirss/rk3506-ubuntu and it booted perfectly without any problems. I'm testing it now.
Unfortunately, my knowledge is completely lacking in this. I don't even know how to do it ( If you have some free time, could you please help me create a firmware with a patched U-Boot? I know it's a lot to ask. Forgive me. But I don't know what to do anymore. The manufacturer's Ubuntu 22 is a pain in the ass; I can't even run Docker on it, and so on. I can upload the manufacturer's U-Boot (Ubuntu 22), but if you need anything else, I'll share everything I have without any problems. uboot_22_ubuntu.7z
When I flash the Ubuntu 22.04 firmware from the board's developers - https://wiki.luckfox.com/Luckfox-Lyra/Image-flashing everything works fine. I flash it using the same methods as Armbian. If I flash the Armbian image, the device doesn't work. Therefore, I conclude that the quote "Random behavior is mostly due to hardware issues. So, powersupply is not OK, or bad storage, or the flashing introduces corrupt data blocks on the storage, a bad cable, or bad Windows computer/software." has absolutely nothing to do with it. Log 2 is immediately after rebooting after flashing. Log 1 is after the second reboot; this happens (not always). I tried flashing the firmware both through Linux and the rkdeveloptool program. Board into Maskrom mode rkdeveloptool ld rkdeveloptool ef sudo rkdeveloptool wl 0 Armbian-unofficial_26.02.0-trunk_Luckfox-lyra-ultra-w_trixie_vendor_6.1.115_minimal.img sudo rkdeveloptool rd The firmware update worked perfectly, without any errors. But after rebooting, the device was inaccessible. I flashed the image at address 0x0 using the RKDevTool_Release_v3.31 program in Windows - the result is the same. I compiled the firmware myself with these parameters ./compile.sh BOARD=luckfox-lyra-ultra-w BRANCH=vendor KERNEL_CONFIGURE=no DEB_COMPRESS=xz KERNEL_BTF=yes INSTALL_ARMBIAN_FIRMWARE=no BUILD_DESKTOP=no BUILD_MINIMAL=yes RELEASE=trixie The firmware was flashed perfectly without errors - after rebooting the device is inaccessible. I downloaded the firmware from Luckfox Lyra Ultra W here - https://github.com/armbian/community/releases since the first release (tried everything) The firmware was flashed perfectly without errors - after rebooting the device is inaccessible. I think the hardware problem is not in my device (since everything works on other firmware), but the problem is in the armbian firmware itself. I'm really hoping that at least one person who has this board will come along and try installing this firmware. I'm curious to see if it works for them. 🙂
So, after 10 days of struggling with flashing the device and hundreds of flashing methods, I think the Armbian firmware for the Luckfox Lyra Ultra W DOESN'T WORK. Unfortunately, the firmware developer responded once here and hasn't responded since. I don't know if he has this board or not. After flashing the device in various ways, I only have two different boot logs (I captured the logs using TTL-USB since the network doesn't work on the device). LOG1 ▒DDR d27ac532c4 typ 25/03/11-14:46:28,fwver: v1.06 tREFI:4x, sr_idle:93, pd_idle:13 PHY drv:clk:40,ca:48,DQ:40,odt:240 vrefinner:50%, vrefout:50% dram drv:40,odt:120 sr_dq:0, sr_ca:0, sr_clk:0 rg:0x6-0x1-0x2, 0x3e-0x0-0x2,status:a007 rdtrn:0x11-0x2e-0x4b(0x3a) wrtrn:0x3-0x21-0x3f(0x3c) DDR3, 750MHz BW=16 Col=10 Bk=8 CS0 Row=15 CS=1 Size=512MB out U-Boot SPL 2025.10-rc4_armbian-2025.10-rc4-S0b8e-P474e-H4702-V3bf2-Bbf55-R448a (Dec 04 2025 - 04:42:05 +0000) Trying to boot from MMC1 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image op-tee ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK I/TC: I/TC: OP-TEE version: 3.13.0-958-g46dcf51e88a #chenjh (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Thu Mar 6 10:17:27 CST 2025 arm, fwver: v2.10 I/TC: Status: cluster=0xc00, core=0xe100, bootcpu=0 I/TC: Next entry point address: 0x00100000 I/TC: OP-TEE memory size: TEEOS 0x5e000 TA 0x1000 SHM 0x1000 I/TC: Primary CPU initializing I/TC: Primary CPU switching to normal world boot ns16550_serial serial@ff0a0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.10-rc4_armbian-2025.10-rc4-S0b8e-P474e-H4702-V3bf2-Bbf55-R448a (Dec 04 2025 - 04:42:05 +0000) Model: Luckfox Lyra Ultra SoC: RK3506B DRAM: 512 MiB (total 511 MiB) Core: 85 devices, 30 uclasses, devicetree: separate MMC: mmc@ff480000: 0 Loading Environment from nowhere... OK In: serial@ff0a0000 Out: serial@ff0a0000 Err: serial@ff0a0000 rockchip_dnl_key_pressed: no saradc device found Net: eth0: ethernet@ff4d0000 Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Cannot persist EFI variables without system partition 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'mmc 0' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@ff480000.bootdev': 1 script ready mmc 1 mmc@ff480000.bootdev.part /boot/boot.scr ** Booting bootflow 'mmc@ff480000.bootdev.part_1' with script Boot script loaded from mmc 0 234 bytes read in 3 ms (76.2 KiB/s) 11012819 bytes read in 889 ms (11.8 MiB/s) 5713472 bytes read in 463 ms (11.8 MiB/s) Failed to load '/boot/dtb/rockchip/rk3506b-luckfox-lyra-ultra.dtb' libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Failed to load '/boot/dtb/overlay/-fixup.scr' Kernel image @ 0x2080000 [ 0x000000 - 0x572e40 ] ## Loading init Ramdisk from Legacy Image at 02800000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11012755 Bytes = 10.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree Boot failed (err=-14) Unknown uclass 'nvme' in label Unknown uclass 'scsi' in label dwc2_usb usb@ff780000: Can't get reset: -2 USB DWC2 Bus usb@ff780000: 3 USB Device(s) found Scanning bootdev 'ethernet@ff4d0000.bootdev': BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 Retry time exceeded; starting again Scanning bootdev 'ethernet@ff4d0000.bootdev': BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 Retry time exceeded; starting again No more bootdevs --- ----------- ------ -------- ---- ------------------------ ---------------- (2 bootflows, 2 valid) => <INTERRUPT> => LOG2 DDR d27ac532c4 typ 25/03/11-14:46:28,fwver: v1.06 tREFI:4x, sr_idle:93, pd_idle:13 SRX get rd_skew=0x2e, wr_skew=0x21 PHY drv:clk:40,ca:48,DQ:40,odt:240 vrefinner:50%, vrefout:50% dram drv:40,odt:120 sr_dq:0, sr_ca:0, sr_clk:0 rg:0x5-0x1-0x2, 0x3b-0x0-0x2,status:a007 DDR3, 750MHz BW=16 Col=10 Bk=8 CS0 Row=15 CS=1 Size=512MB out U-Boot SPL 2025.10-rc4_armbian-2025.10-rc4-S0b8e-P474e-H4702-V3bf2-Bbf55-R448a (Dec 04 2025 - 04:42:05 +0000) Trying to boot from MMC1 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image op-tee ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK I/TC: I/TC: OP-TEE version: 3.13.0-958-g46dcf51e88a #chenjh (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Thu Mar 6 10:17:27 CST 2025 arm, fwver: v2.10 I/TC: Status: cluster=0xc00, core=0xe100, bootcpu=0 I/TC: Next entry point address: 0x00100000 I/TC: OP-TEE memory size: TEEOS 0x5e000 TA 0x1000 SHM 0x1000 I/TC: Primary CPU initializing I/TC: Primary CPU switching to normal world boot ns16550_serial serial@ff0a0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.10-rc4_armbian-2025.10-rc4-S0b8e-P474e-H4702-V3bf2-Bbf55-R448a (Dec 04 2025 - 04:42:05 +0000) Model: Luckfox Lyra Ultra SoC: RK3506B DRAM: 512 MiB (total 511 MiB) Core: 85 devices, 30 uclasses, devicetree: separate MMC: mmc@ff480000: 0 Loading Environment from nowhere... OK In: serial@ff0a0000 Out: serial@ff0a0000 Err: serial@ff0a0000 rockchip_dnl_key_pressed: no saradc device found Net: eth0: ethernet@ff4d0000 Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Cannot persist EFI variables without system partition 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'mmc 0' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@ff480000.bootdev': 1 script ready mmc 1 mmc@ff480000.bootdev.part /boot/boot.scr ** Booting bootflow 'mmc@ff480000.bootdev.part_1' with script Boot script loaded from mmc 0 185 bytes read in 3 ms (59.6 KiB/s) 10866313 bytes read in 878 ms (11.8 MiB/s) 5694528 bytes read in 462 ms (11.8 MiB/s) 545230 bytes read in 48 ms (10.8 MiB/s) Working FDT set to 1e00000 Failed to load '/boot/dtb/overlay/rockchip-fixup.scr' Kernel image @ 0x2080000 [ 0x000000 - 0x56e440 ] ## Loading init Ramdisk from Legacy Image at 02800000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 10866249 Bytes = 10.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01e00000 Booting using the fdt blob at 0x1e00000 Working FDT set to 1e00000 Loading Ramdisk to 1c1a3000, end 1cbffe49 ... OK Loading Device Tree to 1ce28000, end 1cf15fff ... OK Working FDT set to 1ce28000 Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot E/TC:1 plat_shm_get_page_num:386 plat_shm_get_page_num: type 6 alloc is not supported Loading, please wait... Starting systemd-udevd version 257.9-1~deb13u1 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.41 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 armbi_root: clean, 54290/91584 files, 334609/366336 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Armbian-unofficial 26.02.0-trunk trixie! [ OK ] Created slice system-modprobe.slice - Slice /system/modprobe. [ OK ] Created slice system-serial\x2dget…slice - Slice /system/serial-getty. [ OK ] Created slice user.slice - User and Session Slice. [ OK ] Started systemd-ask-password-conso…equests to Console Directory Watch. [ OK ] Started systemd-ask-password-wall.…d Requests to Wall Directory Watch. Expecting device dev-ttyFIQ0.device - /dev/ttyFIQ0... Expecting device dev-ttyS2.device - /dev/ttyS2... [ OK ] Reached target paths.target - Path Units. [ OK ] Reached target remote-fs.target - Remote File Systems. [ OK ] Reached target slices.target - Slice Units. [ OK ] Reached target swap.target - Swaps. [ OK ] Listening on syslog.socket - Syslog Socket. [ OK ] Listening on systemd-creds.socket - Credential Encryption/Decryption. [ OK ] Listening on systemd-initctl.socke…- initctl Compatibility Named Pipe. [ OK ] Listening on systemd-journald-dev-…socket - Journal Socket (/dev/log). [ OK ] Listening on systemd-journald.socket - Journal Sockets. [ OK ] Listening on systemd-networkd.socket - Network Service Netlink Socket. [ OK ] Listening on systemd-udevd-control.socket - udev Control Socket. [ OK ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket. Mounting dev-mqueue.mount - POSIX Message Queue File System... Mounting run-lock.mount - Legacy Locks Directory /run/lock... Mounting sys-kernel-debug.mount - Kernel Debug File System... Starting fake-hwclock-load.service - Restore the current clock... Starting keyboard-setup.service - Set the console keyboard layout... Starting kmod-static-nodes.service…eate List of Static Device Nodes... Starting modprobe@configfs.service - Load Kernel Module configfs... Starting modprobe@drm.service - Load Kernel Module drm... Starting modprobe@efi_pstore.servi… - Load Kernel Module efi_pstore... Starting modprobe@fuse.service - Load Kernel Module fuse... Starting systemd-modules-load.service - Load Kernel Modules... Starting systemd-network-generator…k units from Kernel command line... Starting systemd-udev-load-credent…Load udev Rules from Credentials... Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ OK ] Mounted dev-mqueue.mount - POSIX Message Queue File System. [ OK ] Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ OK ] Mounted sys-kernel-debug.mount - Kernel Debug File System. [ OK ] Finished fake-hwclock-load.service - Restore the current clock. [ OK ] Finished kmod-static-nodes.service…Create List of Static Device Nodes. [ OK ] Finished modprobe@configfs.service - Load Kernel Module configfs. [ OK ] Finished modprobe@drm.service - Load Kernel Module drm. [ OK ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ OK ] Finished modprobe@fuse.service - Load Kernel Module fuse. [ OK ] Finished systemd-modules-load.service - Load Kernel Modules. [ OK ] Finished systemd-udev-load-credent…- Load udev Rules from Credentials. [ OK ] Finished systemd-network-generator…ork units from Kernel command line. [ OK ] Reached target network-pre.target - Preparation for Network. Mounting sys-kernel-config.mount - Kernel Configuration File System... Starting systemd-remount-fs.servic…unt Root and Kernel File Systems... Starting systemd-sysctl.service - Apply Kernel Variables... Starting systemd-tmpfiles-setup-de… Device Nodes in /dev gracefully... [ OK ] Finished keyboard-setup.service - Set the console keyboard layout. [ OK ] Mounted sys-kernel-config.mount - Kernel Configuration File System. [ OK ] Finished systemd-sysctl.service - Apply Kernel Variables. [ OK ] Finished systemd-remount-fs.servic…mount Root and Kernel File Systems. Starting systemd-random-seed.service - Load/Save OS Random Seed... [ OK ] Finished systemd-tmpfiles-setup-de…ic Device Nodes in /dev gracefully. Starting systemd-sysusers.service - Create System Users... [ OK ] Finished systemd-sysusers.service - Create System Users. Starting systemd-resolved.service - Network Name Resolution... Starting systemd-timesyncd.service - Network Time Synchronization... Starting systemd-tmpfiles-setup-de…eate Static Device Nodes in /dev... [ OK ] Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ OK ] Finished systemd-tmpfiles-setup-de…Create Static Device Nodes in /dev. [ OK ] Reached target local-fs-pre.target…Preparation for Local File Systems. Starting systemd-udevd.service - R…ager for Device Events and Files... Mounting tmp.mount - /tmp... [ OK ] Mounted tmp.mount - /tmp. [ OK ] Reached target local-fs.target - Local File Systems. [ OK ] Listening on systemd-sysext.socket… System Extension Image Management. Starting armbian-zram-config.service - Armbian ZRAM config... Starting console-setup.service - Set console font and keymap... [ OK ] Started systemd-timesyncd.service - Network Time Synchronization. [ OK ] Reached target time-set.target - System Time Set. [ OK ] Started systemd-udevd.service - Ru…anager for Device Events and Files. Starting systemd-networkd.service - Network Configuration... [ OK ] Found device dev-ttyFIQ0.device - /dev/ttyFIQ0. [ OK ] Listening on systemd-rfkill.socket…ll Switch Status /dev/rfkill Watch. Starting systemd-rfkill.service - Load/Save RF Kill Switch Status... [ OK ] Finished systemd-random-seed.service - Load/Save OS Random Seed. Starting systemd-machine-id-commit…ave Transient machine-id to Disk... [ OK ] Started systemd-rfkill.service - Load/Save RF Kill Switch Status. [ OK ] Started systemd-networkd.service - Network Configuration. Starting systemd-networkd-persiste…tent Storage in systemd-networkd... [ OK ] Finished systemd-machine-id-commit… Save Transient machine-id to Disk. [ OK ] Started systemd-resolved.service - Network Name Resolution. [ OK ] Reached target nss-lookup.target - Host and Network Name Lookups. [ OK ] Finished systemd-networkd-persiste…istent Storage in systemd-networkd. [ OK ] Finished armbian-zram-config.service - Armbian ZRAM config. Starting armbian-ramlog.service - Armbian memory supported logging... [ OK ] Finished armbian-ramlog.service - Armbian memory supported logging. Starting systemd-journald.service - Journal Service... [ OK ] Started systemd-journald.service - Journal Service. Starting systemd-journal-flush.ser…sh Journal to Persistent Storage... [ OK ] Finished systemd-journal-flush.ser…lush Journal to Persistent Storage. Starting systemd-tmpfiles-setup.se…ate System Files and Directories... [ OK ] Finished systemd-tmpfiles-setup.se…reate System Files and Directories. Starting ldconfig.service - Rebuild Dynamic Linker Cache... Starting systemd-journal-catalog-u…ervice - Rebuild Journal Catalog... [ OK ] Finished systemd-journal-catalog-u….service - Rebuild Journal Catalog. [ OK ] Finished ldconfig.service - Rebuild Dynamic Linker Cache. Starting systemd-update-done.service - Update is Completed... [ OK ] Finished systemd-update-done.service - Update is Completed. [ OK ] Reached target sysinit.target - System Initialization. [ OK ] Started apt-daily.timer - Daily apt download activities. [ OK ] Started apt-daily-upgrade.timer - …y apt upgrade and clean activities. [ OK ] Started dpkg-db-backup.timer - Daily dpkg database backup timer. [ OK ] Started e2scrub_all.timer - Period…Metadata Check for All Filesystems. [ OK ] Started fake-hwclock-save.timer - Periodically save current clock. [ OK ] Started fstrim.timer - Discard unused filesystem blocks once a week. [ OK ] Started logrotate.timer - Daily rotation of log files. [ OK ] Started man-db.timer - Daily man-db regeneration. [ OK ] Started systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories. [ OK ] Reached target timers.target - Timer Units. [ OK ] Listening on dbus.socket - D-Bus System Message Bus Socket. [ OK ] Listening on sshd-unix-local.socke…temd-ssh-generator, AF_UNIX Local). [ OK ] Listening on systemd-hostnamed.socket - Hostname Service Socket. [ OK ] Reached target sockets.target - Socket Units. Starting armbian-hardware-monitor.…ce - Armbian hardware monitoring... Starting armbian-hardware-optimize… - Armbian hardware optimization... Starting armbian-led-state.service - Armbian leds state... Starting armbian-resize-filesystem…vice - Armbian filesystem resize... [ OK ] Finished armbian-hardware-monitor.…vice - Armbian hardware monitoring. [ OK ] Finished armbian-led-state.service - Armbian leds state. [ OK ] Finished armbian-hardware-optimize…ce - Armbian hardware optimization. [ OK ] Finished armbian-resize-filesystem…ervice - Armbian filesystem resize. [ OK ] Reached target basic.target - Basic System. [ OK ] Started cron.service - Regular background program processing daemon. Starting dbus.service - D-Bus System Message Bus... Starting e2scrub_reap.service - Re…ne ext4 Metadata Check Snapshots... Starting rsyslog.service - System Logging Service... Starting systemd-logind.service - User Login Management... [ OK ] Started dbus.service - D-Bus System Message Bus. Starting wpa_supplicant.service - WPA supplicant... [ OK ] Started wpa_supplicant.service - WPA supplicant. [ OK ] Reached target network.target - Network. Starting rc-local.service - /etc/rc.local Compatibility... Starting ssh.service - OpenBSD Secure Shell server... Starting systemd-user-sessions.service - Permit User Sessions... [ OK ] Started rsyslog.service - System Logging Service. [ OK ] Started rc-local.service - /etc/rc.local Compatibility. [ OK ] Finished systemd-user-sessions.service - Permit User Sessions. [ OK ] Started serial-getty@ttyFIQ0.service - Serial Getty on ttyFIQ0. [ OK ] Started systemd-logind.service - User Login Management. [ OK ] Started ssh.service - OpenBSD Secure Shell server. [ OK ] Started armbian-firstrun.service - Armbian first run tasks. [ OK ] Created slice system-getty.slice - Slice /system/getty. [ OK ] Finished e2scrub_reap.service - Re…line ext4 Metadata Check Snapshots. [ OK ] Finished console-setup.service - Set console font and keymap. luckfox-lyra-ultra-w login: root (automatic login) Waiting for system to finish booting ... Stopping ssh.service - OpenBSD Secure Shell server... [ OK ] Stopped ssh.service - OpenBSD Secure Shell server. Starting ssh.service - OpenBSD Secure Shell server... [ OK ] Started ssh.service - OpenBSD Secure Shell server. Stopping ssh.service - OpenBSD Secure Shell server... [ OK ] Stopped ssh.service - OpenBSD Secure Shell server. Starting ssh.service - OpenBSD Secure Shell server... [ OK ] Started ssh.service - OpenBSD Secure Shell server. As you can see from the logs, there is a problem with loading either boot or rk3506b-luckfox-lyra-ultra.dtb
So, I bought a good TTL adapter and managed to capture the boot log after flashing the device. I hope I can get some help now! don't know if this is correct or not. For some reason, the device isn't receiving an IP address on the local network. Is there a DHCP client issue? Another device, a Luckfox Pico Pro Max, receives an IP address without any problems after a firmware update with the same firmware installed. root@luckfox-lyra-ultra-w:~# ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:95:55:d5:00:1c brd ff:ff:ff:ff:ff:ff altname enx029555d5001c root@luckfox-lyra-ultra-w:~# root@luckfox-lyra-ultra-w:~# ip route root@luckfox-lyra-ultra-w:~# sudo ip address add 192.168.1.111/24 dev end1 root@luckfox-lyra-ultra-w:~# sudo ip link set end1 up RTNETLINK answers: Cannot allocate memory root@luckfox-lyra-ultra-w:~# root@luckfox-lyra-ultra-w:~# free total used free shared buff/cache available Mem: 502048 61416 312852 1120 140100 440632 Swap: 251020 0 251020 root@luckfox-lyra-ultra-w:~# sudo ip route add default via 192.168.1.1 Error: Nexthop has invalid gateway. root@luckfox-lyra-ultra-w:~# root@luckfox-lyra-ultra-w:~# dhclient -bash: dhclient: command not found root@luckfox-lyra-ultra-w:~# dhcpcd -bash: dhcpcd: command not found root@luckfox-lyra-ultra-w:~# nmcli device status -bash: nmcli: command not found root@luckfox-lyra-ultra-w:~# rfkill ID TYPE DEVICE SOFT HARD 0 bluetooth bt_default blocked unblocked LOG dmesg root@luckfox-lyra-ultra-w:~# dmesg [ 12.347098] systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl). [ 12.348163] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 12.378655] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 12.405293] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line... [ 12.406603] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.407623] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.440229] cpu cpu0: bin=0 [ 12.440299] cpu cpu0: leakage=4 [ 12.440367] cpu cpu0: Failed to get reg [ 12.440386] cpu cpu0: soc version=0, speed=0 [ 12.440498] cpu cpu0: failed to set opp config [ 12.440514] cpu cpu0: failed to init opp info [ 12.446781] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials... [ 12.478445] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 12.543552] cpu cpu0: bin=0 [ 12.543616] cpu cpu0: leakage=4 [ 12.543688] cpu cpu0: Failed to get reg [ 12.543707] cpu cpu0: soc version=0, speed=0 [ 12.543811] cpu cpu0: failed to set opp config [ 12.543825] cpu cpu0: failed to init opp info [ 12.546917] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 12.548819] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ 12.557284] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 12.561114] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 12.565736] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 12.626730] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 12.646891] cpu cpu0: bin=0 [ 12.646961] cpu cpu0: leakage=4 [ 12.647033] cpu cpu0: Failed to get reg [ 12.647052] cpu cpu0: soc version=0, speed=0 [ 12.647166] cpu cpu0: failed to set opp config [ 12.647182] cpu cpu0: failed to init opp info [ 12.647807] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 12.650302] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 12.655510] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 12.658127] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 12.665290] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 12.668129] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 12.672568] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 12.675374] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 12.682766] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 12.687615] systemd[1]: Finished systemd-network-generator.service - Generate network units from Kernel command line. [ 12.694297] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 12.697519] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials. [ 12.704996] systemd[1]: Reached target network-pre.target - Preparation for Network. [ 12.706087] systemd[1]: sys-fs-fuse-connections.mount - FUSE Control File System was skipped because of an unmet condition check (ConditionPathExists=/sys/fs/fuse/connections). [ 12.712801] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 12.713450] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 12.737667] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 12.750229] cpu cpu0: bin=0 [ 12.750306] cpu cpu0: leakage=4 [ 12.750383] cpu cpu0: Failed to get reg [ 12.750404] cpu cpu0: soc version=0, speed=0 [ 12.750519] cpu cpu0: failed to set opp config [ 12.750537] cpu cpu0: failed to init opp info [ 12.758268] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 12.781710] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully... [ 12.840144] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 12.853542] cpu cpu0: bin=0 [ 12.853637] cpu cpu0: leakage=4 [ 12.853712] cpu cpu0: Failed to get reg [ 12.853733] cpu cpu0: soc version=0, speed=0 [ 12.853846] cpu cpu0: failed to set opp config [ 12.853863] cpu cpu0: failed to init opp info [ 12.892411] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: disabled. [ 12.900244] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 12.912688] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 12.913688] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 12.922292] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed... [ 12.922949] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.938881] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 12.956894] cpu cpu0: bin=0 [ 12.956960] cpu cpu0: leakage=4 [ 12.957030] cpu cpu0: Failed to get reg [ 12.957050] cpu cpu0: soc version=0, speed=0 [ 12.957152] cpu cpu0: failed to set opp config [ 12.957167] cpu cpu0: failed to init opp info [ 13.018349] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully. [ 13.020159] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 13.033094] systemd[1]: Starting systemd-resolved.service - Network Name Resolution... [ 13.054629] systemd[1]: Starting systemd-timesyncd.service - Network Time Synchronization... [ 13.060388] cpu cpu0: bin=0 [ 13.060461] cpu cpu0: leakage=4 [ 13.060544] cpu cpu0: Failed to get reg [ 13.060569] cpu cpu0: soc version=0, speed=0 [ 13.060693] cpu cpu0: failed to set opp config [ 13.060713] cpu cpu0: failed to init opp info [ 13.088211] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 13.163561] cpu cpu0: bin=0 [ 13.163630] cpu cpu0: leakage=4 [ 13.163703] cpu cpu0: Failed to get reg [ 13.163724] cpu cpu0: soc version=0, speed=0 [ 13.163836] cpu cpu0: failed to set opp config [ 13.163854] cpu cpu0: failed to init opp info [ 13.266907] cpu cpu0: bin=0 [ 13.266976] cpu cpu0: leakage=4 [ 13.267049] cpu cpu0: Failed to get reg [ 13.267070] cpu cpu0: soc version=0, speed=0 [ 13.267184] cpu cpu0: failed to set opp config [ 13.267200] cpu cpu0: failed to init opp info [ 13.274715] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 13.289922] systemd[1]: Finished systemd-tmpfiles-bin=0 [ 13.473591] cpu cpu0: leakage=4 in=0 [ 13.473591] cpu cpu0: leakage=4 in=0 [ 13.473591] cpu cpu0: leakage=4 in=0 [ 13.473591] cpu cpu0: leakage=4 [ 13.473658] cpu cpu0: Failed to get re[32m[ 13.473658] cpu cpu0: Failed to get re[32m[ 13.473658] cpu cpu0: Failed to get re[32m[ 13.473658] cpu cpu0: Failed to get re[32m[ 13.473658] cpu cpu0: Failed to get re[32m[ 13.473658] cpu cpu0: Failed to get re[32m[ 13.m[ 13.473677] cpu cpu0: soc version=g [ 13.473677] cpu cpu0: soc version=g [ 13.473677] cpu cpu0: soc version=g [ 13.473677] cpu cpu0: soc version=g [ 13.473677] cpu cpu0: soc version=g [ 13.473677] cpu cpu0: soc version=g [ 13.473677] cpu cpu0: soc version=0, speed=0 [ 13.473789] cpu cpu0: fa] systemd[1]: systemd-binfmt.service - S13.735411] systemd[1k_gmac-dwmac ff4d0000.ethernet: Idded device: zram1ndystemd-binfmt.service - S13.735411rk_gmac-dwmac ff4d0000.ethernet: Can not read property: tx_delay.stemd-binfmt.service -[ 14.659770] rk_gmac-dwmac ff4d0000.ethernet: set tx_delay to 0xffffffffmac ff4d0000.eth9783] rk_gmac-dwmac ff4d0000.ethernet 14.659829] rk_gmac-dwmac ff4d0000.ethernet: rk_gmac-dwmac ff4d0000.ethernet: rk_gmac-dwmac ff4d000014.659842] cannot get clock mac_clk_rxbecause of an unmeet Up Additional Binary Formats was skipped because of an unme[ 14.659842] cannot get clock mac_clk_rxd because of an unmeet Up Additional Binary F[ 14.659842] cannot get clock mac_clk_rx Additional Binary Formats was skipped becaus[ 14.659842] cannot get clock mac_clk_rxthIsMountPoint=/proc/sys/fs/binft condition c[ 14.659842] cannot get clock mac_clk_rxfs/binft condition check (ConditionPathIsMoun[ 14.659842] cannot get clock mac_clk_rx(ConditionPathIsMountPoint=/proc/sys/fs/binft[ 14.659842] cannot -dwmac ff4d0000.ethernet: cannot get clock m3mrk_gmac-dwmac ff4d0000.ethernet: cannot get clock m3mrk_gmac-dwmac ff4d0000.ethernet: cannot get clock m3mrk_gmac-dwmac ff4d0000.ethernet: cannot get clock m3mrk_gmac-dwmac ff4d0000.ethernet: cannot get clock m3mrk_gmac-dwmac ff4d0000.ethernet: cannot get clock m3mrk_gmac-dwmac ff4d0000.etherneition check (ConditionFirstBoot=yhine-id-commit.service - Savservice - Journal Service.[WLAN_RFKILL]: Enter rfkill_wlan_init [ 18.132686] systeservice - Journal Service._parse_dt: uart_rts_gpios is no-in-use. [ 18.132686] systeservice - Journal Service. [ 18.132686] systeservice - Journal Service. [ 18.132686] systeservice - Journal Service. [ 18.132686] systeservice - Journal Service. [ 18.132686] systemd-journald[441]: Received client request to flush runtimemd-journald[441]: Received client request to flush runtimemd-journald[441]: Received client request to flush runtimemd-journald[441]: Received client request to flush runtimemd-journald[441]: Received client request to flush runtimemd-journald[441]: Received client request to flush runtimemd-journald[441]: 19.662697] systemd-journald[441]: journal. [ 19.662697] systemd-journald[441]: journal.ut/input0 [ 19.662697] systemd-journald[441]: journal.ut/input0 [ 19.662697] systemd-journald[441]: journal.ut/input0 [ 19.662697] systemd-journald[441]: journal.ut/input0 [ 19.662697] systemd-journald[441]: journal. bound 14.996070] rockchip-drm display-su[ 19.662697] systemd-journald[441]: Received client request to relinquish /var/log/journal/c2gsubsystem: bound 14.996070] rockchip-drm display-subsystem: bound 14.996070] r[ 25.083239] platform ff4a8000.sai: defg6070] rockchip-drm display-subsystem: bound f[ 25.083239] platform ff4a8000.sai: defg [ 25.083239] platform ff4a8000.sai: defg: first-boot-complete.target - First Boot Com[ 25.083239] platform ff4a8000.sai: deferred probe pendingomplete was skipped becauseroot@luckfox-lyra-ultra-w:~# erred probe pending=yes). root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending root@luckfox-lyra-ultra-w:~# erred probe pending
Hello! I'm so glad you responded! I've been trying to reflash this device for three days. Unfortunately, the behavior after reflashing is always the same: the red LED lights up, goes out after 15-20 seconds, and the device no longer shows any signs of working. I've reflashed the device about 50 times with different settings. And of course, I checked the "Write to address" box. I built the firmware from your git - https://github.com/vidplace7/armbian-build/tree/luckfox-lyra-ultra I also built the firmware from the Armbian office git. There were no errors during the build. I've built the firmware from Debian and Ubuntu. I've also tried various methods (again, I've been trying to reflash the device for three days now). I'm desperate. Would you be so kind as to post the firmware that works 100% for you and tell me how to flash it correctly? I'm pinning all my hopes on you!
Unfortunately, there's no TTL data after the firmware update. RX and TX are silent.
