Serg2140
  1. Hi! I have an OrangePi3 (not Zero!) running Armbian (H6), with a TFT ILI9486 display connected via the 26-pin header. The screen works fine, but the XPT2046 touch controller does not initialize. Here’s the situation: CS0 on PH5, DC on PD16, RESET on PD21. XPT2046 (CS1) on PL8, IRQ on PD24. I tried adding XPT2046 to the overlay with all parameters configured (ti,x/y-min/max, pressure, swap-xy, etc.). The overlay compiles successfully, but when loading the module it says: ads7846 spi0.1: probe with driver ads7846 failed with error -22 I also tried loading the ads7846 module with parameters via modprobe — all parameters are ignored because the driver only supports configuration via Device Tree. Here is my current overlay: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 3 0>; display: display@0 { compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <20000000>; txbuflen = <65536>; rotate = <90>; bgr = <0>; fps = <30>; buswidth = <8>; regwidth = <16>; height = <480>; width = <320>; dc-gpios = <&pio 3 16 0>; reset-gpios = <&pio 3 21 1>; debug = <3>; init = <0x10000b0 0x00 // Interface Mode Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x10000C0 0x0D 0x0D // Power Control 1 0x10000C1 0x43 // Power Control 2 0x10000C5 0x00 0x48 0x80 // VCOM Control 1 0x10000C7 0x00 // VCOM Control 2 0x1000036 0x28 // Memory Access Control (Rotação) 0x100003A 0x55 // Pixel Format Set (16bit) 0x10000B1 0xB0 0x11 // Frame Rate Control 0x10000F0 0x01 // Enable Extended Comand Set 0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control 0x1000026 0x01 // Gamma Set 0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00 // Positive Gamma Correction 0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F // Negative Gamma Correction 0x10000B6 0x02 0x02 0x3B // Display Function Control 0x1000011 // Sleep Out 0x20000ff // Delay (255ms) 0x1000029>; // Display ON }; /* --- ADS7846 (XPT2046) --- */ ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <3 24 2>; pendown-gpio = <&pio 3 24 1>; cs-gpios = <&pio 11 8 0>; /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; Could anyone advise how to properly connect XPT2046 so that PD24 is used as IRQ? Is there a working example overlay for TFT ILI9486 + XPT2046 on OrangePi3 / H6? Or has anyone managed to use the touch controller via a module without overlay? Or is that simply impossible on this kernel? I would really appreciate any working examples or advice!
