picocom v3.1
port is : /dev/tty.usbserial-A5069RR4
flowcontrol : none
baudrate is : 1500000
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
hangup is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
logfile is : none
initstring : none
exit_after is : not set
exit is : no
Type [C-a] [C-h] to see available commands
Terminal ready
?DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
ch0 ttot7
LPDDR5, 2400MHz
channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
ch1 ttot7
channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
ch2 ttot7
channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
ch3 ttot7
channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
Manufacturer ID:0xff
DQS rds:h1,l0,
CH0 RX Vref:26.7%, TX Vref:20.0%,0.0%
DQ rds:h7 l0 h2 l0 l0 h1 h1 l0 , h2 h1 l0 h1 h4 h3 h2 h1
DQS rds:h1,h1,
CH1 RX Vref:26.7%, TX Vref:20.0%,0.0%
DQ rds:h4 h3 h1 h3 l0 h2 h1 h1 , h2 h5 h3 h1 h7 l0 h5 h2
DQS rds:h1,h1,
CH2 RX Vref:26.3%, TX Vref:21.0%,0.0%
DQ rds:h2 h3 h1 h4 h6 h1 h4 h7 , h1 h1 h4 h1 h5 h6 h4 h3
DQS rds:l0,l0,
CH3 RX Vref:28.5%, TX Vref:21.0%,0.0%
DQ rds:h1 h2 h3 l0 h3 h2 h1 h1 , h1 h2 h1 h1 h4 l0 h6 h1
stride=0x2, ddr_config=0x2
hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x0
change to F1: 534MHz
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
change to F2: 1320MHz
ch0 ttot8
ch1 ttot8
ch2 ttot8
ch3 ttot8
change to F3: 1968MHz
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
change to F0: 2400MHz
ch0 ttot7
ch1 ttot7
ch2 ttot7
ch3 ttot7
out
U-Boot SPL board init
U-Boot SPL 2017.09 (Feb 16 2026 - 04:05:08)
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK
## Checking uboot 0x00200000 ... sha256(31ad8d4f92...) + OK
## Checking fdt 0x003495b0 ... sha256(0195fe7e17...) + OK
## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK
## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 353.110 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48
NOTICE: BL31: Built : 15:02:44, Dec 19 2024
INFO: spec: 0x13
INFO: code: 0x88
INFO: ext 32k is valid
INFO: ddr: stride-en 4CH
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: l3 cache partition cfg-0
INFO: system boots from cpu-hwid-0
INFO: enable memory repair
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Feb 24 2026 - 17:20:14 +0000)
Model: RK3588 Orange Pi 5 Pro
PreSerial: 2, raw, 0xfeb50000
DRAM: 8 GiB
Sysmem: init
Relocation Offset: eda2d000
Relocation fdt: eb9f9268 - eb9fecb8
CR: M/C/I
Using default environment
mmc@fe2c0000: 0, mmc@fe2e0000: 1
Bootdev(atags): mmc 0
MMC0: Legacy, 52Mhz
PartType: EFI
DM: v2
boot mode: None
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 24000 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 24000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
4149 bytes read in 11 ms (368.2 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0:1
286 bytes read in 10 ms (27.3 KiB/s)
15612135 bytes read in 1264 ms (11.8 MiB/s)
47405568 bytes read in 3810 ms (11.9 MiB/s)
244832 bytes read in 479 ms (499 KiB/s)
325 bytes read in 201 ms (1000 Bytes/s)
Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-pro-disable-leds.dtbo
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
## Loading init Ramdisk from Legacy Image at 0a200000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 15612071 Bytes = 14.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 0x0a100000
Booting using the fdt blob at 0x0a100000
reserving fdt memory region: addr=a100000 size=a2000
'reserved-memory' ramoops@110000: addr=110000 size=e0000
Using Device Tree in place at 000000000a100000, end 000000000a1a4fff
Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000)
Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000)
Total: 6405.175 ms
Starting kernel ...
[!p]104[?7h[6n[32766;32766H[6n[40;1H[!p]104[?7h[6n[32766;32766H[6n[40;1H
Armbian_community 26.2.0-trunk.493 Trixie ttyFIQ0
orangepi5pro login:
