bellad
1 Follower
3559 profile views
  1. i see in /lib/firmware/ aic8800 , i've this in usb key how to install it ??
  2. ah ok , thank you , I'm going to test a usb key wifi
  3. thank's , but i no understand with lsmod ssv6051 exist !! Module Size Used by snd_soc_hdmi_codec 16384 1 snd_soc_spdif_tx 12288 1 ir_nec_decoder 12288 0 gpio_ir_recv 12288 0 cpufreq_dt 12288 0 snd_soc_simple_card 16384 0 snd_soc_simple_card_utils 20480 1 snd_soc_simple_card ssv6051 151552 0 dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 hantro_vpu 237568 0 rockchip_vdec 65536 0 lz4hc 12288 0 rockchip_rga 20480 0 rockchip_iep 16384 0 lima 40960 0 v4l2_vp9 20480 2 rockchip_vdec,hantro_vpu v4l2_h264 12288 2 rockchip_vdec,hantro_vpu videobuf2_dma_contig 16384 3 rockchip_iep,rockchip_vdec,hantro_vpu gpu_sched 24576 1 lima v4l2_mem2mem 20480 4 rockchip_iep,rockchip_vdec,hantro_vpu,rockchip_rga lz4 12288 0 snd_soc_rk3228 12288 1 snd_soc_rockchip_spdif 12288 2 snd_soc_rockchip_i2s 20480 4 rockchip_thermal 20480 0 snd_soc_core 159744 7 snd_soc_spdif_tx,snd_soc_rockchip_spdif,snd_soc_rockchip_i2s,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_rk3228,snd_soc_simple_card snd_pcm_dmaengine 12288 1 snd_soc_core snd_pcm 94208 4 snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_core snd_timer 28672 1 snd_pcm dw_wdt 12288 0 rk_crypto 24576 0 snd 57344 4 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm crypto_engine 12288 1 rk_crypto soundcore 12288 1 snd zram 28672 3 binfmt_misc 16384 1 sch_fq_codel 16384 2 fuse 114688 1 ip_tables 24576 0 gpio_keys 16384 0
  4. hello , i've install armbian on my box tv rk3229 with Multitool and Armbian_24.2.5_Rk322x-box_jammy_current_6.6.22_minimal.img.xz my problem is error : SSV WLAN driver ssv6200: calibation fail after 1 iterations [ 74.050778] SOS!SOS! [ 74.050797] SSV WLAN driver ssv6200: Failed to initialize mac, ret=-1 [ 74.075988] SSV WLAN driver ssv6200: chip id: SSV6006C0 , tag: 0 [ 74.116548] ERROR!!Please check interface! [ 74.116580] [0xca000200]: 0x0c000000!=0x00000000 i've put in /etc/modprobe.d/ssv6051.conf options ssv6051 stacfgpath=/lib/firmware/ssv6051-wifi.cfg but no work can you help , please
  5. hello géraldine adi , i've same box ,did you find the armbian firmware ??
  6. hello luis , try this :https://drive.google.com/drive/folders/1ls4jTIl00CJ3UFQipGdOYmrN0XBnfJlS?usp=sharing
  7. hello , it's possible upgrade armbian Linux vegas812 3.10.108 #5 SMP PREEMPT Sat Jan 13 10:50:53 MSK 2018 armv7l GNU/Linux if yes how to ? thank you
  8. hi , no problem https://drive.google.com/drive/folders/1ls4jTIl00CJ3UFQipGdOYmrN0XBnfJlS?usp=sharing
  9. well, I found an image for my m8s ji want remove desktop for only console , how to proceed ?? thank you
  10. Hello, I took out my old m8s (s812) 2go 8go, i put Armbian_21.11.0-trunk_Aml-s812_focal_current_5.14.0.img with meson8m2-m8s.dtb it stop at "starting hostname service " can you help ? thank you
  11. i've try Armbian_21.11.0-trunk_Aml-s812_focal_current_5.14.0.img with dtb file : meson8b_hd18q meson8b_m200_1G meson8b_m201_1G meson8b_m201C_512M meson8b_m201d meson8b_m203a meson8b_m202_512M meson8b_m203b meson8b_mk808bplus meson8b_mxq meson6-atv1200 meson8b-ec100 meson8b-mxq meson8b-odroidc1 meson8m2-m8s meson8m2-mxiii meson8m2-mxiii-plus meson8m2-wetek-core meson8-minix-neo-x8 meson8-tronsmart-s82 no result good i search dtb file with AP6330 wifi can you help , please thank you
  12. hello , where to find the armbian img for s805,s812 ?? please thank you
  13. sorry my box tv is burned Hello , I got out my old cs918 1GB Ram 8GB Rom RK3188 with rtl8201 rj45 and rtl8723 wifi i search armbian img for this , no desktop just console does it still exist ? if where i can dowload ? thank you
