BlueFlame
  1. I tried to install armbianmonitor on the opi zero 2, but unfortunately this fails: orangepizero2:~$ sudo armbianmonitor -r Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor /usr/bin/armbianmonitor: line 697: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory /usr/bin/armbianmonitor: line 193: /etc/rpimonitor/template/raspbian.conf: No such file or directory /usr/bin/armbianmonitor: line 196: cd: /etc/rpimonitor/: No such file or directory sed: can't read /etc/rpimonitor/template/temperature.conf: No such file or directory sed: can't read /etc/rpimonitor/template/cpu.conf: No such file or directory sed: can't read /etc/rpimonitor/template/version.conf: No such file or directory Can I do something to resolve this or do I just need to have patience
  2. Hi All, I bought a nice SD to eMMC adapter with a 32GB eMMC module for the orange PI PC. Unfortunately it does not go through first boot. Formatting goes okay, flashing goes okay, booting does not. With Armbian_20.08.1_Orangepipc_focal_current_5.8.5.img.xz image there is no more terminal output after "Uncompressing Linux... done, booting the kernel.". With the Armbian_20.05.4_Orangepipc_focal_current_5.4.45.img.xz image I had laying around (and have successfully used on this OpiPC on a normal SD card before), this is the terminal output: U-Boot SPL 2020.04-armbian (Jun 15 2020 - 06:08:51 +0200) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2020.04-armbian (Jun 15 2020 - 06:08:51 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC DRAM: 1 GiB MMC: mmc@1c0f000: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@1c28000 Out: serial@1c28000 Err: serial@1c28000 Net: phy interface0 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 Bus usb@1c1d000: USB EHCI 1.00 Bus usb@1c1d400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning bus usb@1c1d000 for devices... 1 USB Device(s) found scanning bus usb@1c1d400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3789 bytes read in 1 ms (3.6 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 152 bytes read in 1 ms (148.4 KiB/s) 11634345 bytes read in 551 ms (20.1 MiB/s) 7163872 bytes read in 341 ms (20 MiB/s) Found mainline kernel configuration 29475 bytes read in 4 ms (7 MiB/s) 4185 bytes read in 4 ms (1021.5 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11634281 Bytes = 11.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 494e7000, end 49fff669 ... OK Loading Device Tree to 49477000, end 494e6fff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 5.496839] sunxi-mmc 1c0f000.mmc: data error, sending stop command [ 5.503254] sunxi-mmc 1c0f000.mmc: send stop command failed [ 5.509577] sunxi-mmc 1c0f000.mmc: data error, sending stop command [ 5.515900] sunxi-mmc 1c0f000.mmc: send stop command failed [ 6.874824] sun4i-codec 1c22c00.codec: Failed to register our card [ 6.908187] sun4i-codec 1c22c00.codec: Failed to register our card [ 6.936994] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present! [ 12.084564] sunxi-mmc 1c0f000.mmc: data error, sending stop command [ 12.090920] sunxi-mmc 1c0f000.mmc: send stop command failed [ 12.151934] sunxi-mmc 1c0f000.mmc: data error, sending stop command [ 13.155270] sunxi-mmc 1c0f000.mmc: send stop command failed Any help greatly appreciated.
