Helder Freitas
  1. weird thing. nmcli dev wifi sees all networks but armbian-config doesn't think i have wifi. weirder. After installing network-manager armbian-config started seeing wifi.
  2. Board says: ROCK PI 4 SE trying Armbian_community_24.11.0-trunk.130_Rock-4se_bookworm_current_6.6.51_minimal.img.xz boots via console, no hdmi no wifi. Detected as Radxa ROCK Pi 4A (should be 8b according to doc). HDMI works if forced to fullhd (monitor 4k) U-Boot 2023.10-rc2-armbian-2023.10-rc2-Sa169-P0000-H8c72-Va6f9-Bda0a-R448a (Jul 22 2024 - 17:36:28 +0000) SoC: Rockchip rk3399 Reset cause: RST Model: Radxa ROCK Pi 4A DRAM: 4 GiB (effective 3.9 GiB) PMIC: RK808 Core: 288 devices, 30 uclasses, devicetree: separate MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from MMC... Card did not respond to voltage select! : -110 *** Warning - No block device, using default environment trying Armbian_community_24.11.0-trunk.130_Rockpi-4b_bookworm_current_6.6.51_minimal.img.xz boots via console. no hdmi no wifi on startup or via armbian-config. iwconfig lists wlan0. ethernet works. Detected as 4B. hdmi works if forced to fullhd. the old official radxa image successfully detects and uses 4k out of box U-Boot 2022.07-armbian-2022.07-Se092-Pfa03-H8c72-V70f2-Bda0a-R448a (Jul 22 2024 - 17:36:01 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 Core: 285 devices, 31 uclasses, devicetree: separate MMC: mmc@fe310000: 2, mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from SPIFlash... jedec_spi_nor flash@0: unrecognized JEDEC id bytes: ff, ff, ff *** Warning - spi_flash_probe_bus_cs() failed, using default environment
  3. Tried installing rock 4se image and rockpi 4b image. Both blink the blue led but none gives me hdmi output or network connection. What is the correct image for this sbc? The silkscreen says rockpi 4 SE Thanks
