Guilherme
16 -
I'm having a problem with my Raspberry Pi 5, which I describe below. I have a DVR connected to it via Ethernet. If I connect both at the same time, dmesg reports a failure and I can't ping the DVR to establish a connection; I have to run `ifconfig eth0 down` and `ifconfig eth0 up`. Can anyone help or know if there's a bug in the kernel version? I'm using Ubuntu 22.04. jammy root:~# dmesg | grep eth0 [ 1.312167] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 108 (2c:cf:67:81:d6:2a) [ 3.237493] systemd[1]: Found device /sys/subsystem/net/devices/eth0. [ 3.453483] systemd[1]: Started ifup for eth0. [ 3.573655] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL) [ 3.573668] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode [ 6.441950] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 11.560707] macb 1f00100000.ethernet eth0: Link is Down [ 13.605678] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off root:~# ping 192.168.200.201 PING 192.168.200.201 (192.168.200.201) 56(84) bytes of data. ^C --- 192.168.200.201 ping statistics --- 6 packets transmitted, 0 received, 100% packet loss, time 13305ms root:~# ifconfig eth0 down root:~# ifconfig eth0 up root:~# dmesg | grep eth0 [ 1.312167] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 108 (2c:cf:67:81:d6:2a) [ 3.237493] systemd[1]: Found device /sys/subsystem/net/devices/eth0. [ 3.453483] systemd[1]: Started ifup for eth0. [ 3.573655] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL) [ 3.573668] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode [ 6.441950] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 11.560707] macb 1f00100000.ethernet eth0: Link is Down [ 13.605678] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 147.034711] macb 1f00100000.ethernet eth0: Link is Down [ 151.855860] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL) [ 151.855871] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode [ 152.869842] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off root:~# ping 192.168.200.201 PING 192.168.200.201 (192.168.200.201) 56(84) bytes of data. 64 bytes from 192.168.200.201: icmp_seq=1 ttl=64 time=1.01 ms 64 bytes from 192.168.200.201: icmp_seq=2 ttl=64 time=1.01 ms ^C --- 192.168.200.201 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 1.007/1.007/1.007/0.000 ms
But I already tried that and it didn't work.
I'm using the command ./compile.sh build BOARD=rpi4b BRANCH=current KERNELBRANCH=current SKIP_ARMBIAN_REPO=yes SKIP_ARMBIAN_CONFIG=yes SKIP_EXTERNAL_TOOLCHAINS=yes BUILD_DESKTOP=no BUILD_MINIMAL=yes CLEAN_LEVEL=make-kernel,alldebs,images,cache EXPERT=yes KERNEL_CONFIGURE=no NEWPKG=true OFFLINE_WORK=no KERNEL_BTF=no RELEASE=noble
The image is generated, but when I put it in the Raspberry Pi, it displays the screen.
I need help. Every version I generate for Raspberry Pi 5 Armbian-unofficial_25.08.0-trunk_Rpi4b_noble_current_6.12.32_minimal shows the error shown in the photo.
I constantly get this error message when I try to generate the version for rpi4. : Unable to correct problems, you have held broken packages. [💥] Error 1 occurred in main shell [ at /home/raspberry/build/lib/functions/logging/runners.sh:15 chroot_sdcard_apt_get_install() --> lib/functions/logging/runners.sh:15 pre_install_distribution_specific__add_rpi_packages() --> config/sources/families/bcm2711.conf:227 pre_install_distribution_specific() --> <extension_magic>:184 call_extension_method() --> lib/functions/general/extensions.sh:57 build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:19 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:36 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] When this happens I have to delete the build folder and redo everything. git clone --depth=1 --branch=main https://github.com/armbian/build cd build ./compile.sh Can someone help me solve this without having to start from scratch?
I've tried this one and it didn't work because it returns saying that it's legacy and it didn't work see /home/custela/uv4l2# insmod uv4l2.ko insmod: ERROR: could not insert module uv4l2.ko: Invalid module format /home/custela/uv4l2# dmesg [ 782.935603] uv4l2: disagrees about version of symbol module_layout /home/custela/uv4l2# modinfo uv4l2.ko filename: /home/custela/uv4l2/uv4l2.ko author: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> license: GPL srcversion: 8A60DC9287145B2DA7A51CE depends: videobuf2-v4l2,videodev,videobuf2-common,videobuf2-vmalloc name: uv4l2 vermagic: 6.6.78-legacy-bcm2711 SMP preempt mod_unload modversions aarch64 /home/custela/uv4l2# uname -r 6.6.78-current-bcm2711 /home/custela/uv4l2#
igor, is it possible to set the kernel version to 6.6.58 in the image generation line below? I know it's in KERNELBRANCH but I don't know how to set it to 6.6.58. Can you help? ./compile.sh build BOARD="rpi4b" BRANCH="current" KERNELBRANCH="current" BUILD_DESKTOP="no" BUILD_MINIMAL="yes" CLEAN_LEVEL="make-kernel,alldebs,images,cache" EXPERT="yes" KERNEL_CONFIGURE="no" NEWPKG="true" OFFLINE_WORK="no" RELEASE="jammy"
But in my case, it's the WIFI that stopped in the kernel Armbian-unofficial_24.11.0-trunk_Rpi4b_jammy_current_6.6.58_minimal. I didn't do any of that and it works because I now have to change /boot/firmware/config.txt. Note that the wifi also presents this error [7.388838] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
