rin
7 -
# uname -a Linux odroidc4 6.6.63-current-meson64 #1 SMP PREEMPT Fri Nov 22 14:38:37 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux Installed latest "Armbian_24.11.1_Odroidc4_noble_current_6.6.60-kisak.img" ...with latest sudo apt update; sudo apt upgrade, rebooted... Hardware: - Odroid-C4 - Sabrent USB 3.0 to 2.5-Inch SATA Adapter; Model: EC-SSHD with latest firmware patch, connected to a Kingston SSD: SA400S37480G # dmesg -l emerg,alert,crit,err [ 0.879290] meson-drm ff900000.vpu: DSI transceiver device is disabled [ 3.402246] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. [ 4.327154] panfrost ffe40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found [ 4.871183] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. [ 5.093021] I/O error, dev sda, sector 2064 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2 [ 5.098203] I/O error, dev sda, sector 2088 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 2 [ 5.098226] I/O error, dev sda, sector 2120 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 2 [ 5.102570] Buffer I/O error on dev sda1, logical block 2, async page read [ 5.111428] Buffer I/O error on dev sda1, logical block 2, async page read I'm not worried about vpu, or panfrost errors, ..., since I don't care about gpu on this headless (non-desktop) cli mini-server. # dmesg | grep -i systemd-sysctl [ 3.331877] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 3.399999] systemd[1]: systemd-sysctl.service: Main process exited, code=exited, status=1/FAILURE [ 3.400501] systemd[1]: systemd-sysctl.service: Failed with result 'exit-code'. [ 3.402246] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. [ 4.822476] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 4.870046] systemd[1]: systemd-sysctl.service: Main process exited, code=exited, status=1/FAILURE [ 4.870601] systemd[1]: systemd-sysctl.service: Failed with result 'exit-code'. [ 4.871183] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. I checked /etc/sysctl.conf, and everything looks ok, afaik.? # cat /etc/sysctl.conf # # /etc/sysctl.conf - Configuration file for setting system variables # See /etc/sysctl.d/ for additional system variables. # See sysctl.conf (5) for information. # #kernel.domainname = example.com # Uncomment the following to stop low-level messages on console #kernel.printk = 3 4 1 3 ################################################################### # Functions previously found in netbase # # Uncomment the next two lines to enable Spoof protection (reverse-path filter) # Turn on Source Address Verification in all interfaces to # prevent some spoofing attacks #net.ipv4.conf.default.rp_filter=1 #net.ipv4.conf.all.rp_filter=1 # Uncomment the next line to enable TCP/IP SYN cookies # See http://lwn.net/Articles/277146/ # Note: This may impact IPv6 TCP sessions too #net.ipv4.tcp_syncookies=1 # Uncomment the next line to enable packet forwarding for IPv4 #net.ipv4.ip_forward=1 # Uncomment the next line to enable packet forwarding for IPv6 # Enabling this option disables Stateless Address Autoconfiguration # based on Router Advertisements for this host #net.ipv6.conf.all.forwarding=1 ################################################################### # Additional settings - these settings can improve the network # security of the host and prevent against some network attacks # including spoofing attacks and man in the middle attacks through # redirection. Some network environments, however, require that these # settings are disabled so review and enable them as needed. # # Do not accept ICMP redirects (prevent MITM attacks) #net.ipv4.conf.all.accept_redirects = 0 #net.ipv4.conf.default.accept_redirects = 0 # _or_ # Accept ICMP redirects only for gateways listed in our default # gateway list (enabled by default) # net.ipv4.conf.all.secure_redirects = 1 # # Do not send ICMP redirects (we are not a router) #net.ipv4.conf.all.send_redirects = 0 # # Log Martian Packets #net.ipv4.conf.all.log_martians = 1 # ################################################################### # Magic system request Key # 0=disable, 1=enable all, >1 bitmask of sysrq functions # See https://www.kernel.org/doc/html/latest/admin-guide/sysrq.html # for what other values do #kernel.sysrq=438 Swappiness for zram, see swapon vm.swappiness=100 # Decrease swap usage to a more reasonable level #vm.swappiness=30 # # Improve cache management #vm.vfs_cache_pressure=50 # # Improve writing to external media like USB memory sticks #vm.dirty_bytes=335544320 #vm.dirty_background_bytes=167772160 # ------------------------------- For the sake of brevity, I'm only running "transmission-daemon" on this successfully -sort of, with everything else being the default Armbian server settings, ... see: with: # cat /etc/udev/rules.d/99-usb-drive.rules ENV{ID_FS_UUID}=="501ce172-bc60-40db-90b6-9e025d2748bb", ACTION=="add", RUN{program}+="/usr/bin/systemd-mount --type=ext4 --no-block --collect $devnode /media/USB01/" ...so as to mount my USB-SSD-drive upon boot. But that's for another topic, since the "Failed to start systemd-sysctl.service - Apply Kernel Variables." were there before, and nothing else was changed. Basically, are the errors in my "dmesg" output above anything to really worry about.?
I can not reiterate enough just how easy it is to "clone" your modified emmc, or microSD card OS, ... into an image file that you can easily restore with (balena)Ethcher afterwards, and all withiin Linux. 1:/ you'll need a USB-card-reader-adapter. 2:/ no matter how your USB-reader card reader sees your emmc, microSD card, ..., it'll most likely be mounted on a /dev/sda1 partition. 3:/ sudo dd bs=4M if=/dev/sda of=~/tmp/armbian_odroidc4_11_01_2025.img (you don't dd the partition, you dd the drive). 4:/ (optionally) sudo xz -v armbian_odroidc4_11_01_2025.img (this will take some time). ...and that's it, ... and you know the rest.
I can't even imagine the amount of work involved on both sides of the (debian) development fence, as well as the admins, mods, community contributors, ..., here, that help make Armbian a viable SBC (ARM) whatever OS. -and here's to RISC-*, and let it not be too encumbered. My "Armbian_24.11.1_Odroidc4_noble_current_6.6.60-kisak.img" works very well on my lowly Odroid-C4. I don't know your names, but Thankyou all.
1
[SOLVED]: Odroid-C4 can not mount external USB drive via fstab on boot?
rin replied to rin's topic in Amlogic meson
Automounting, (even permanently on reboot), a portable/external USB-Drive is not as simple as adding a line in /etc/fstab,-like you would do for any internal sata/hdd/ssd/nvme/... I initially tried installing "autofs" and "udisks2", and fiddling with that and "/etc/fstab", ... and I could get it to automount with the system up, and it would survive the first reboot, but it would NOT mount-at-boot after other consecutive reboots.?! Instead, I ended up re-flashing "Armbian_24.11.1_Odroidc4_noble_current_6.6.60-kisak.img" on my emmc, and followed basically this below guide: https://unix.stackexchange.com/questions/765721/trying-to-automatically-mount-a-usb-drive-on-debian-bookworm-when-connected (see "1 Answer" in above link). -I commented out|removed the "UUID=<output-of-bklid-for-sda1> /media/USB01 ..." line in my /etc/fstab, since the "systemd-mount" command, triggered by the new udev rule, is now doing the heavy lifting. The important thing is, I needed my USB-drive to survive reboots and to automount on boot, but before my network comes up, which it now does. I'm not exactly sure why this all works, and I still need to fine tune some "systemd-mount" options, ... That said, years ago, on my x86_64-ubuntu-desktop, with "usbmount", lol, I remember simply having to add a line in my /etc/fstab and my USB-drive would automount on boot. anyway, it appears systemd is everywhere these days, including mounting. I'll mark this as SOLVED. -
Hi @c0rnelius Sorry for not being more clear in my Title|Subject, (which I since edited a bit), and thanks for reply, and yes, I tried auto,nofail, ... (in /etc/fstab), and a few other combo's but they didn't work. -It would not consistently mount at boot. I will post what finally worked for me in a bit. -
I successfully flashed the "Armbian_24.11.1_Odroidc4_noble_current_6.6.60-kisak.img" on my emmc, and everything boots, runs, and updates fine... My 2TB USB3.0 seagate HD, /dev/sda, is seen fine in "dmesg", as well as "lsblk" and "blkid", but when I add my UUID, ..., in /etc/fstab it fails to mount at boot. see below line in /etc/fstab for above /dev/sda1 : UUID=<output-of-bklid-for-sda1> /media/USB01 ext4 defaults 0 1 To test the above /etc/fstab mount I ran: sudo findmnt --verify (which completes successfully) Also, if I run: sudo mount -a (it manually automounts /dev/sda1 -> /media/USB01 successfully). But, whenever i reboot, it does not come up mounted.? -this is driving me crazy. Do I also need udisks2 ?, or autofs>, and/or, manually edit udev*?, and/or "systemd-mount" to get this thing to mount on every boot. ?
