14 -
Profile Information
Gender
Male
Location
Canada
Interests
FillingMachineOrRinsingMachine@gmail.com
ChocolateOrMintOrBoth@gmail.com
Contact Methods
Mastodon
hachyderm.io/@GameFan90
Website URL
http://geocities.ws/bensretrohub/
Github
github.com/RetroFan90
Discord
retrofan90#8516
Ben Voutour replied to jock's topic in Rockchip CPU Boxes
here is the English Translation for the Rk3318 TRM Rockchip+RK3318+Datasheet+V1.0-20190806.en.ru en.pdf -
Happy New Year! More DTB Shenanigans ahead for the new year maybe perhaps the tv out can work after all... (Maybe?) For The Next Task , I'll Upload DTB files from my archive on gdrive there is a crap ton of weird features that armbian is missing the ball on... But With That, I'm Gonna Be Testing rk3318 noble nightly builds i might tweak the dtb to not even use the internal emmc (due to bad solder job on 33x8 TV-BOX Hardware 3308/3318/3328 what is the best tool to dump dtb and such into a human readable file? -
get flathub installer and some of the issues are more or less resolved -
i could also update the bootloader and set up the DDR to 666MHz. could someone help me clock my cpu to 1.5 GHz? (I have a heatsink and fan. and could the sd bus mode be changed for more speed? (Just Curious) since it it sdio 3.0 my particular card is a legit sandisk 256 GB micro SD card Class 10 U1 A1 Features Ideal for Android smartphones and tablets, Chromebooks, and Windows laptops Load apps faster with A1-rated performance View, access, and back up your phone’s files in one location with the SanDisk Memory Zone app Capacity 256GB Form Factor microSDXC™ Compatibility Compatible with all microSDHC and microSDXC supporting host devices Sequential Read Performance Up to 150MB/s Interface microSDXC I In The Box SanDisk Ultra microSD card SD adapter Warranty 10-Year Limited Warranty Dimensions (L x W x H) 14.99mm x 10.92mm x 0.76mm Weight 0.01lbs Model Number SDSQUAC-256G-GN6MA Operating Temperature -25°C to 85°C Non-Operating Temperature -40°C to 85°C Certifications CE, FCC, C-Tick/RCM, UKCA, EAC, ICES My MicroSD Card -
i use linux mint as my flash tool so i use the dd command so what do i have to do to put the 800MHz Android U-Boot on the Micro SD card? "dd if="800mhz_u-boot.bin" of=path-to-sd-card status=progress seek=???" -
My RAM Chips (x8 4GB Has 3HE77 D9PQL Printed on them. could we get it to work at 800 MHZ? on RK3318-box? and would it work for LibreElec? -
how do i flash this to the existing armbian sd card since my build is for 333MHz. and i want to add this RK3318 DDR 666 Mhz V1.16 instead of being clock-blocked to 333MHz. where would i find a trust blob for RK3318 with 1.5GHz Working? once the cpu and memory is at 1.5Ghz and 666 Mhz Respectively might make kodi and retroarch run much better than they do ATM. Can Someone Build The Kernel Module for the LED Indicator Panel and bundle all the other stuff like CVBS/RCA_Left/Right Kernel Blobs someone please upload the dtb with all the components present for rk3318? where can we get a TRM Specifically for RK3318 and not RK3328? since the two are similar and software locked to show as either RK3318 or RK3328 so we need a cert file to unlock the cpu clock (TRUSTED_FIRMWARE_BIN-BLOB) so in a weird way it is a Software Defined ASIC that targets RK3318/RK3328 as Two Separate Hardware Device Tree Bin-Blobs (DTB) then again i might be wrong... and will the dtb from armbian work on LibreElec v12 Nightly? -
is there any chance since rk3318/rk3328 are ARM64(AARCH64), Could Windows 10 or 11 For ARM run on it? and where can i get a retroarch/emulation/kodi based JEOS for rk3318? Kinda Like Batocera Linux / EmuElec / LibreElec ? and can i boot android from the microSD slot? (my eMMC is DEAD.) (Removed from Board) and what can i use the usb 3.0 port for? i only have a 500GB Samsung Story Station Drive (USB 3.0) and the 2.0 port is connected to a hub for the keyboard/mouse , controllers/etc and is there a way to get optical audio out of the box? is there some hidden solder points? (The only way i managed to do it is through HDMI to a TV with Optical Audio Out and a Cheap Ass External DAC powered by usb 5v) -
i'm gonna be testing Trixie With RK3318 and can you make it so that the composite video and audio actually work on ntsc/pal 720x480 and 720x576? my SoC is Clocked At 1,200 MHz ~ 1,296 MHz with OnDemand Governor how is the dtb going? and is it possible to boot android from the sd card instead of the EMMC (Since I Removed it.)? and is acceleration gonna work properly? -
is there a build of Trixie for this system? i just blocked them from my github list thanks for the heads up. -
i'm testing dietpi 8.23 so far so good. -
should i use a 5v 5a power brick? -
could you tell me if there is a working memory oc with working trust blob and get my cpu to hit 1.5 GHz (It has a nice cooler on it already. is there a higher verbosity other than 10? if so , what is it? -
here is the dmesg with verbosity=10 I booted with no emmc as I removed it...(Poor BGA Solder Job) the boot source is a legit 256GB microSD card the system has a 1,296 MHz clock but i assume that the ddr clocking is default... can it be overclocked further? i have a fan and heat sink on the cpu the power supply is a 5v 2a D-Link Power Supply (Wall Brick) (Hardwired to PCBA) the case is gone in favor of open board design the cvbs+Analog Left/Right is Also Hard-Wired as well. the issue is atm i'm on bookworm (6.6.1) (Nightly) and my LED Clock is Not Working... And Yes, I'm Back again dmesg.txt
