SES
  1. I use an 18W tablet charger. Maximum consumption 1.4A when executing the command dd if=/dev/sda... At rest, with the HDD spindle rotating, the consumption is 0.7A. I found a solution to the problem I described (a crutch, of course, but still): query the disk status (hdparm -C /dev/sda) every 60 seconds. And the disk never resets. Maybe someone will suggest the right solution. Thank you.
  2. Hello! How to turn off Wi-Fi and Bluetooth devices to reduce power consumption? armbianmonitor -U -> result in attachment. Thank you. armbian-hardware-monitor.log
  3. > sudo armbianmonitor -u System diagnosis information will now be uploaded to https://paste.armbian.com/Error adding document. Please post the URL in the forum where you've been asked for. > armbianmonitor -U -> result in attachment. armbian-hardware-monitor.log
  4. Hello! Board: Orange Pi 3 LTS SATA-USB3: Bus 002 Device 003: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. JMS578 SATA 6Gb/s Speed after load: sudo dd if=/dev/sda of=/dev/null status=progress ... (5,8 GB, 5,4 GiB), 50 s, 115 MB/s Speed after spindown: sudo dd if=/dev/sda of=/dev/null status=progress ... (4,5 GB, 4,2 GiB), 71 s, 62,9 MB/s After reboot the speed is again 115 MB/s The drive does not respond to changes in Power Management settings. Help me solve the problem. Sometimes the disk cannot start after spindown. Thanks!
