Slack
Posts
5 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by Slack
Looks like kernel is not patched correctly. For example. DWC modules are from future kernel versions, thus it is not possible to compile. Phy infustructure may be not correct with USB3 too.
Also, no correct dts files: board has Longsys LTM8830 wi-fi/bt chip.
23 hours ago, Igor said:
Do you have those two things enabled?CONFIG_FW_LOADER_USER_HELPER=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
yes.
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
# CONFIG_STANDALONE is not set
# CONFIG_PREVENT_FIRMWARE_BUILD is not set
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y -
my experience. H96 board with rk3399.
Take the distro from Orangepi site, dd it on the SD-card. insert and turn on power. It is running.
Later, the kernel changed (recompiled by me) to
root@localhost:~# uname -a
Linux localhost 4.4.114 #11 SMP Mon Mar 12 08:46:26 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
The problem is with dtb file: partially it works.
USB2 is ok, HDMI is ok, Ethernet is ok.
But:
[ 0.809301] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
(file dptx.bin present)
So, USB3 (and DP) is off (both type-C and normal USB3 blue socket; it works in Android on the same board; dtb file taken is the same as in Android distro).
Also, I cannot check AV output and ALSA shows only SPDIF, that has no controls.
I think the only need is any correct dtb file to work with the board. -
Very simple. Take the distro from Opi site, dd it on the SD-card. insert and turn on power. It is running.
But:
So, USB3 (and DP) is off (both type-C and normal USB3 blue socket; it works in Android).
Rockchip RK3399
in Rockchip
I think, that I can decompile dtb file (for android, that is working well), and create one for Linux. But I have no dtb/dts file for the board and no working android firmware found.
