rosbeef
22 -
Damne sorry! i did not have auto follow activted and not seen your message util now. i have not anymore this image but as i read, the new images includes a new uboot with drivers isn't it? so as you said, the new uboot shoud permits me to remove the blob i had to configure. i'm not sure to understand how a uboot upgrade could include something which make the blob not relevant anymore. so i don't know if flashing new uboot with the blob will confict. is someone can resolve this dubt? thks
@usual user@Efe Çetin it seem to work with i burned an sd card with the new compiled Armbian-unofficial_24.8.0-trunk_Orangepi5-plus_bookworm_legacy.5.10.160 image . I boot from the sdcard It seems to work as i have no crash copying a 250GB file between a usb ssd and the mvne. I'm trying now memtester 31G. ... ... trying mlock ...Killed BUT not crash trying memtester 30G is working ... ... and it does not crash. @Efe Çetin Is it possible to make the official release working for the 32Gb version ?
@Eddie as @MichaIng explain me did you add the next in the armbienEnv.txt ?
ok thankyou, that makes debian boot with 12G effectively and big file (250GB tested) coping is fully working. So it discard a hardware power failure. Sorry @Werner Now i have a half working memory. And if i want to get my fully working 32G memory i have to try the @Efe Çetin solution. just let me time to compile the new armbian with those blobs Thanks all.
Hum i saw that my power is 5.1v I removed the mvne and try to cp a big file, it crash too. Maybe the right way to explore is the bad memory managment. I could not reduce visible memory, sorry i'm noob here. I put the mem=12G in the /boot/armbianEnv.txt file then "update-initramfs -u" I tried directly in /boot/boot.cmd on the bootagrs parameter too without success. , i read that too : source https://github.com/linux-sunxi/u-boot-sunxi/issues/11#issuecomment-6358135 maybe there is an other way to shrink the memory or accept the 32G.
i don't have the tools to test the voltages and don't have a precise tunable powersource. as you seems to know about electronic can i ask you ? Is 6V will be too much overvoltage ?
i don't need 32 for now, i jut bought it for the future. Should it be possible to lie on the size of the memory and only declare 16Gb usable ?
More current (5A instead of 4A) did not resolve the problem for me. I tried the vendor distro (debian) and problem is not solved. Writing from SD to emmc makes crash too. even if no usb connected. A simple copy command make debian crash. i will go to orangepi forum 😕 for help.
Damn ! the opi5+ bundle from aliexpress includes a 5V-4A which should be short for a 32G+nvme. I will try a 5V-5A as i am not able to find a 5V-6A on amazon.
Hi ! i am in this situation: Orangepi 5plus 32gb ram , uboot on spi and root on nvme i experiment the crash on Armbian 24.5.1 Bookworm with Linux 5.10.160-legacy-rk35xx and 6.1.43-vendor-rk35xx and 6.8.10-edge-rk3588 too I would help you to resolve my bug but could you help me to send you all you could need. i recover some datas from the serial 409.837122] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 409.837821] CPU: 3 PID: 1 Comm: systemd Not tainted 6.8.11-edge-rockchip-rk3588 #1 [ 409.838494] Hardware name: Xunlong Orange Pi 5 Plus (DT) [ 409.838967] Call trace: [ 409.839191] dump_backtrace+0x94/0x114 [ 409.839538] show_stack+0x18/0x24 [ 409.839840] dump_stack_lvl+0x38/0xf0 [ 409.840173] dump_stack+0x18/0x24 [ 409.840473] panic+0x3b8/0x3f8 [ 409.840754] do_exit+0x898/0x9bc [ 409.841050] do_group_exit+0x34/0x90 [ 409.841376] copy_siginfo_to_user+0x0/0xc8 [ 409.841746] do_notify_resume+0x27c/0x1430 [ 409.842114] el0_da+0x8c/0x90 [ 409.842387] el0t_64_sync_handler+0xe4/0x158 [ 409.842772] el0t_64_sync+0x1a4/0x1a8 [ 409.843104] SMP: stopping secondary CPUs [ 409.843559] Kernel Offset: disabled [ 409.843871] CPU features: 0x0,c0000000,7002814a,2100720b [ 409.844345] Memory Limit: none [ 409.844629] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]--- other dump 279.842385] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP [ 279.842949] Modules linked in: macvlan nft_masq bridge snd_seq_dummy rfcomm snd_seq snd_seq_device nft_fib_inet nft_fib_ipv4 nft_fib_ipvb [ 279.843297] libarc4 gpu_sched drm_shmem_helper drm_exec rfkill_gpio rfkill dm_mod ip_tables x_tables autofs4 uas rockchipdrm drm_dma_hes [ 279.853805] CPU: 2 PID: 190 Comm: kworker/2:1 Not tainted 6.8.11-edge-rockchip-rk3588 #1 [ 279.854522] Hardware name: Xunlong Orange Pi 5 Plus (DT) [ 279.854995] Workqueue: events kernfs_notify_workfn [ 279.855439] pstate: a0400009 (NzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 279.856057] pc : find_inode_fast+0x38/0xe4 [ 279.856430] lr : ilookup+0x8c/0x118 [ 279.856747] sp : ffff80008353bca0 [ 279.857044] x29: ffff80008353bca0 x28: 0000000000000000 x27: ffff800081f57980 [ 279.857686] x26: ffff800081d5e000 x25: ffff00010048ebb0 x24: ffff800081172078 [ 279.858327] x23: ffff0001008a5800 x22: ffff0007d9300c00 x21: ffff0001008a5800 [ 279.858968] x20: 00000000000027c8 x19: 90d48fefa3653def x18: ffff80008c523c58 [ 279.859609] x17: 0000000000000000 x16: 1fffe0002046dc41 x15: 00000000000002e9 [ 279.860249] x14: 0000000000000000 x13: 0000000000000030 x12: 0101010101010101 [ 279.860889] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff x9 : 7f7f7f7f7f7f7f7f [ 279.861530] x8 : 8080808080808080 x7 : ffff00010048ebb0 x6 : ffff000100aa7380 [ 279.862170] x5 : d83827dd7f7cc000 x4 : 0000000000000015 x3 : d9bf05c4657e16ae [ 279.862810] x2 : 00000000000027c8 x1 : ffff0007d9300c00 x0 : ffff0001008a5800 [ 279.863451] Call trace: [ 279.863675] find_inode_fast+0x38/0xe4 [ 279.864016] ilookup+0x8c/0x118 [ 279.864303] kernfs_notify_workfn+0x12c/0x220 [ 279.864698] process_one_work+0x160/0x3a8 [ 279.865064] worker_thread+0x32c/0x438 [ 279.865404] kthread+0x118/0x11c [ 279.865701] ret_from_fork+0x10/0x20 [ 279.866030] Code: aa0003f5 f9001bf7 d503201f 54000140 (f9402263) [ 279.866441] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 279.866448] SMP: stopping secondary CPUs [ 279.866573] ---[ end trace 0000000000000000 ]--- [ 279.866610] Kernel Offset: disabled [ 279.868331] CPU features: 0x0,c0000000,7002814a,2100720b [ 279.868799] Memory Limit: none [ 279.869076] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
