I'm having a strange error. I have been enjoying OMV on my new Helios 4. After powering on the Helios one day I noticed I couldn't access it. I connected via the USB serial cable and noticed that eth0 was not showing a configured IP address. I had been using DHCP reservation from my router. I assigned a static IP to eth0. That static IP did show up however I'm unable to ping the gateway or anything else on my LAN. I can however ping the loopback address. I decided to wipe the image and I flashed the "Jessie_4.14.20-OMV_3.0.97" build again. No luck with the clean image.
Finally, in desperation (thinking maybe it was a hardware issue) I flashed the "Stretch_4.14.20" image and DHCP worked fine and I have fully connectivity. BTW I tried different ports on my managed switch, different patch cables just to eliminate these items.
What am I doing wrong? I'm at a loss on this issue??
Thanks,
Jake
