6 -
Banana Pi Pro: Wifi Kernel Module ap6211 crashes
Chrissie Brown replied to Chrissie Brown's topic in Allwinner sunxi
Ok, finally i managed to resolve all issues and got USB Wifi and onboard Wifi working. At first, there is an issue about loading Firmware to USB Devices. This matters all devices, i testet two. To see this / fix this, do the following: Get a well-known Device like RT2800 compatible. Plug it in. You will see in dmesg: [...] [ 944.529335] usbcore: registered new interface driver rt2800usb [ 1005.163497] phy3 -> rt2x00lib_request_firmware: Error - Failed to request Firmware. [...] You can start # udevadm monitor --property and watch the events. No Firmware gets loaded. To fix this, i did: * clone firmware, maybe not neccesary / you can get firmware somewhere else git clone https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git cp rt2870.bin /lib/firmware/ * install the missing Firmware loading script and install. Get it for example from: wget https://raw.githubusercontent.com/msekletar/udev/master/extras/firmware/firmware.sh cp firmware.sh /lib/udev chmod 755 /lib/udev/firmware.sh * change loading udev rule, edit file: /lib/udev/rules.d/50-firmwarerule # stub for immediately telling the kernel that userspace firmware loading # failed; necessary to avoid long timeouts with CONFIG_FW_LOADER_USER_HELPER=y #SUBSYSTEM=="firmware", ACTION=="add", ATTR{loading}="-1" SUBSYSTEM=="firmware", ACTION=="add", RUN+="firmware.sh --firmware=$env{FIRMWARE} --devpath=$env{DEVPATH}" * now plug in and out the USB Device, firmware gets loaded. See in dmesg. * further working demo / debug with iPhone as an access point, orignal commands # dmesg [ 173.237800] Registered led device: rt2800usb-phy1::radio [ 173.242351] Registered led device: rt2800usb-phy1::assoc [ 173.251511] Registered led device: rt2800usb-phy1::quality [ 212.394061] ADDRCONF(NETDEV_UP): wlx7cdd901d63cb: link is not ready [ 306.550771] wlx7cdd901d63cb: authenticate with 80:2a:a8:d7:d1:fe [ 306.603112] wlx7cdd901d63cb: send auth to 80:2a:a8:d7:d1:fe (try 1/3) [ 306.609799] wlx7cdd901d63cb: authenticated [ 306.647584] wlx7cdd901d63cb: associate with 80:2a:a8:d7:d1:fe (try 1/3) [ 306.667489] wlx7cdd901d63cb: RX AssocResp from 80:2a:a8:d7:d1:fe (capab=0x431 status=0 aid=1) [ 306.716286] ADDRCONF(NETDEV_CHANGE): wlx7cdd901d63cb: link becomes ready [ 306.719199] wlx7cdd901d63cb: associated [ 317.426175] wlx7cdd901d63cb: no IPv6 routers presen # cat /etc/wpa_supplicant/wpa_supplicant.conf network={ ssid="Chrissie's iPhone" psk="asdf1234" } # wpa_supplicant -i wlx7cdd901d63cb -D wext -c /etc/wpa_supplicant/wpa_supplicant.conf -B # dhclient wlx7cdd901d63cb # ifconfig wlx7cdd901d63cb Link encap:Ethernet HWaddr 7c:dd:90:1d:63:cb inet addr:172.20.10.4 Bcast:172.20.10.15 Mask:255.255.255.240 root@bananapipro:/home/chrissie# ping 172.20.10.1 PING 172.20.10.1 (172.20.10.1) 56(84) bytes of data. 64 bytes from 172.20.10.1: icmp_seq=1 ttl=64 time=35.9 ms 64 bytes from 172.20.10.1: icmp_seq=2 ttl=64 time=30.4 ms The second issue is about the onboard wifi driver. If i blacklist the module, and modprobe it when the system has fully booted, it works. you can even automate this with rc.local See: resolve: blacklist module, load when system is fully booted via modprobe, race condition? # vi /etc/modprobe.d/blacklist.conf [...] blacklist ap6211 [...] # reboot # modprobe ap6211 # dmesg [...] [ 135.443706] [ap6211] Firmware up: op_mode=0x0001, Broadcom Dongle Host Driver mac=98:3b:16:e9:6c:36 [ 135.461025] [ap6211] Firmware version = wl0: Mar 10 2014 14:59:50 version 5.90.195.89.18 FWID 01-b13c09c7 [ 135.464100] [ap6211] Chip: a962 Rev 1 Pkg 9 # ifconfig [...] wlan0 Link encap:Ethernet HWaddr 00:90:4c:11:22:33 [...] * to make this permanent, insert the following to the end /etc/rc.local: # By default this script does nothing. sleep 5; modprobe ap6211 exit 0 Well Igor you said, this had worked somewhere in the past, and there havent been changed anything - this ist hard for me to believe. At least i worked it out - maybe this helps some other people :) Chris. -
Thanks for the insight. I got this Banana Pi board cheap. I installed kodi and did some configuration. Everything, except the Wifi works so far, so it fits for me. For example, i bought a random IR Remote, switched it to a NEC compatible mode which is actually a LG Sat Receiver, did some Kodi Keyboard Mapping, and it worked out of the box. I also thought about Orange Pi Board, maybe in the future But i can also wait for a newer Kernel to appear. If someone is interested, here a more detailed kernel module crash: root@bananapipro:/home/chrissie# modprobe ap6211 Segmentation fault root@bananapipro:/home/chrissie# dmesg [ 3854.897533] [ap6211] --->The Drive has been modified for BananaPro by LeMaker team<--- [ 3854.928517] [ap6211] select wifi ap6211 [ 3854.936175] ------------[ cut here ]------------ [ 3854.986149] WARNING: at fs/sysfs/dir.c:508 sysfs_add_one+0x94/0xb4() [ 3855.000240] sysfs: cannot create duplicate filename '/devices/platform/ap6211_gpio_wifi.0' [ 3855.027486] Modules linked in: ap6211(+) bnep disp_ump mali_drm drm cpufreq_userspace zram(C) zsmalloc(C) spidev mali ump a20_tp 8021q garp stp llc sunxi_ir hidp rfcomm hci_uart bluetooth ppdev lp parport [last unloaded: ap6211] [ 3855.077468] [<c001543c>] (unwind_backtrace+0x0/0x12c) from [<c0037108>] (warn_slowpath_common+0x54/0x64) [ 3855.108535] [<c0037108>] (warn_slowpath_common+0x54/0x64) from [<c0037148>] (warn_slowpath_fmt+0x30/0x40) [ 3855.131401] [<c0037148>] (warn_slowpath_fmt+0x30/0x40) from [<c014d7b8>] (sysfs_add_one+0x94/0xb4) [ 3855.150911] [<c014d7b8>] (sysfs_add_one+0x94/0xb4) from [<c014d994>] (create_dir+0x6c/0xe0) [ 3855.167544] [<c014d994>] (create_dir+0x6c/0xe0) from [<c014dd7c>] (sysfs_create_dir+0x98/0xec) [ 3855.195392] [<c014dd7c>] (sysfs_create_dir+0x98/0xec) from [<c03f9b38>] (kobject_add_internal+0xa8/0x254) [ 3855.213610] [<c03f9b38>] (kobject_add_internal+0xa8/0x254) from [<c03f9fec>] (kobject_add+0x4c/0x98) [ 3855.237438] [<c03f9fec>] (kobject_add+0x4c/0x98) from [<c047f590>] (device_add+0xec/0x5fc) [ 3855.255056] [<c047f590>] (device_add+0xec/0x5fc) from [<c0483974>] (platform_device_add+0x110/0x1e4) [ 3855.279062] [<c0483974>] (platform_device_add+0x110/0x1e4) from [<bf5df3c8>] (ap6211_gpio_wifi_init+0x138/0x154 [ap6211]) [ 3855.301991] [<bf5df3c8>] (ap6211_gpio_wifi_init+0x138/0x154 [ap6211]) from [<bf5df04c>] (dhd_module_init+0x4c/0x290 [ap6211]) [ 3855.328516] [<bf5df04c>] (dhd_module_init+0x4c/0x290 [ap6211]) from [<c0008698>] (do_one_initcall+0x10c/0x164) [ 3855.349721] [<c0008698>] (do_one_initcall+0x10c/0x164) from [<c0082eb8>] (sys_init_module+0x614/0x1ef4) [ 3855.380902] [<c0082eb8>] (sys_init_module+0x614/0x1ef4) from [<c000ecc0>] (ret_fast_syscall+0x0/0x30) [ 3855.399707] ---[ end trace 5eb9e7eb407dd508 ]--- [ 3855.408047] ------------[ cut here ]------------ [ 3855.427547] WARNING: at lib/kobject.c:198 kobject_add_internal+0x23c/0x254() [ 3855.451633] kobject_add_internal failed for ap6211_gpio_wifi.0 with -EEXIST, don't try to register things with the same name in the same directory. [ 3855.478570] Modules linked in: ap6211(+) bnep disp_ump mali_drm drm cpufreq_userspace zram(C) zsmalloc(C) spidev mali ump a20_tp 8021q garp stp llc sunxi_ir hidp rfcomm hci_uart bluetooth ppdev lp parport [last unloaded: ap6211] [ 3855.529102] [<c001543c>] (unwind_backtrace+0x0/0x12c) from [<c0037108>] (warn_slowpath_common+0x54/0x64) [ 3855.554844] [<c0037108>] (warn_slowpath_common+0x54/0x64) from [<c0037148>] (warn_slowpath_fmt+0x30/0x40) [ 3855.574847] [<c0037148>] (warn_slowpath_fmt+0x30/0x40) from [<c03f9ccc>] (kobject_add_internal+0x23c/0x254) [ 3855.593746] [<c03f9ccc>] (kobject_add_internal+0x23c/0x254) from [<c03f9fec>] (kobject_add+0x4c/0x98) [ 3855.619410] [<c03f9fec>] (kobject_add+0x4c/0x98) from [<c047f590>] (device_add+0xec/0x5fc) [ 3855.637036] [<c047f590>] (device_add+0xec/0x5fc) from [<c0483974>] (platform_device_add+0x110/0x1e4) [ 3855.657392] [<c0483974>] (platform_device_add+0x110/0x1e4) from [<bf5df3c8>] (ap6211_gpio_wifi_init+0x138/0x154 [ap6211]) [ 3855.681724] [<bf5df3c8>] (ap6211_gpio_wifi_init+0x138/0x154 [ap6211]) from [<bf5df04c>] (dhd_module_init+0x4c/0x290 [ap6211]) [ 3855.709220] [<bf5df04c>] (dhd_module_init+0x4c/0x290 [ap6211]) from [<c0008698>] (do_one_initcall+0x10c/0x164) [ 3855.728090] [<c0008698>] (do_one_initcall+0x10c/0x164) from [<c0082eb8>] (sys_init_module+0x614/0x1ef4) [ 3855.750010] [<c0082eb8>] (sys_init_module+0x614/0x1ef4) from [<c000ecc0>] (ret_fast_syscall+0x0/0x30) [ 3855.765294] ---[ end trace 5eb9e7eb407dd509 ]--- [ 3855.783489] Unable to handle kernel paging request at virtual address bf126050 [ 3855.794225] pgd = dd524000 [ 3855.800715] [bf126050] *pgd=6e400811, *pte=00000000, *ppte=00000000 [ 3855.814864] Internal error: Oops: 7 [#2] PREEMPT SMP ARM [ 3855.822061] Modules linked in: ap6211(+) bnep disp_ump mali_drm drm cpufreq_userspace zram(C) zsmalloc(C) spidev mali ump a20_tp 8021q garp stp llc sunxi_ir hidp rfcomm hci_uart bluetooth ppdev lp parport [last unloaded: ap6211] [ 3855.865012] CPU: 1 Tainted: G D WC (3.4.113-sun7i #16) [ 3855.874228] PC is at platform_match+0x60/0x74 [ 3855.881766] LR is at __driver_attach+0x20/0x90 [ 3855.895079] pc : [<c0483c00>] lr : [<c0482434>] psr: 600c0013 [ 3855.895084] sp : e60d3e20 ip : 00000001 fp : 00000124 [ 3855.910464] r10: 0000d905 r9 : bf5df000 r8 : ee481ca4 [ 3855.920891] r7 : edc20180 r6 : bf126058 r5 : bf5ab1fc r4 : 00000000 [ 3855.932714] r3 : c0483ba0 r2 : 00000002 r1 : bf5a0744 r0 : bf126058 [ 3855.945070] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 3855.956640] Control: 10c5387d Table: 5d52406a DAC: 00000015 [...Register dumps ...] [ 3856.735549] Process modprobe (pid: 4033, stack limit = 0xe60d22f0) [ 3856.745050] Stack: (0xe60d3e20 to 0xe60d4000) [ 3856.756534] 3e20: bf126058 bf5ab1fc c0482414 c0482434 00000000 bf5ab1fc c0482414 c04803ac [ 3856.771821] 3e40: ef023860 edc124b8 00000000 bf5ab1fc c0a68a60 c0481698 bf5a0744 bf5aace8 [ 3856.787152] 3e60: bf5ab1fc bf5aace8 00000001 bf5acfa0 ee481ca4 c0482a94 c0a90180 bf5aace8 [ 3856.802449] 3e80: 00000001 bf5acfa0 ee481ca4 bf5df04c c0a90180 e60d2000 00000001 ee481c80 [ 3856.817777] 3ea0: ee481ca4 bf5df000 0000d905 c0008698 00000124 c07226a4 c0a34f14 00000000 [ 3856.833135] 3ec0: 00000000 ee481ca4 00000001 bf5b2d30 bf5b2d78 00000001 ee481c80 ee481ca4 [ 3856.848474] 3ee0: 00000001 0000d905 00000124 c0082eb8 bf5b2d3c 00007fff 00000000 e60d3fb0 [ 3856.863841] 3f00: 00000000 00000000 c072645c bf5b2e74 bf5b2d3c f0cbbfb0 f0c68b50 c0a89380 [ 3856.879132] 3f20: e60d2000 f0c6e681 ee7eea80 bf591444 00000006 00000000 00000000 00000000 [ 3856.894462] 3f40: 00000000 f0bfc000 000bffd8 f0cbb628 f0c6e570 f0c86698 00072278 00088a18 [ 3856.909810] 3f60: bf5acd60 000003fe 0000003c 0000003d 00000032 00000036 00000015 00000000 [ 3856.925100] 3f80: 08000071 b6fca890 b6d25000 b7903fa0 00000080 c000ee44 e60d2000 00000000 [ 3856.940428] 3fa0: 00000000 c000ecc0 b6fca890 b6d25000 b6d25000 000bffd8 b6fc984c 00000026 [ 3856.955758] 3fc0: b6fca890 b6d25000 b7903fa0 00000080 00040000 00000000 b7903ed8 00000000 [ 3856.971121] 3fe0: b6f20161 be946310 b6fc150f b6f20168 000e0030 b6d25000 00000000 00000000 [ 3856.986927] [<c0483c00>] (platform_match+0x60/0x74) from [<c0482434>] (__driver_attach+0x20/0x90) [ 3857.003540] [<c0482434>] (__driver_attach+0x20/0x90) from [<c04803ac>] (bus_for_each_dev+0x68/0x9c) [ 3857.020322] [<c04803ac>] (bus_for_each_dev+0x68/0x9c) from [<c0481698>] (bus_add_driver+0xd0/0x28c) [ 3857.037172] [<c0481698>] (bus_add_driver+0xd0/0x28c) from [<c0482a94>] (driver_register+0x78/0x134) [ 3857.055043] [<c0482a94>] (driver_register+0x78/0x134) from [<bf5df04c>] (dhd_module_init+0x4c/0x290 [ap6211]) [ 3857.073853] [<bf5df04c>] (dhd_module_init+0x4c/0x290 [ap6211]) from [<c0008698>] (do_one_initcall+0x10c/0x164) [ 3857.092061] [<c0008698>] (do_one_initcall+0x10c/0x164) from [<c0082eb8>] (sys_init_module+0x614/0x1ef4) [ 3857.109391] [<c0082eb8>] (sys_init_module+0x614/0x1ef4) from [<c000ecc0>] (ret_fast_syscall+0x0/0x30) [ 3857.123654] Code: 13a00001 e8bd8070 e8bd8070 e5911000 (e5100008) [ 3857.140640] ---[ end trace 5eb9e7eb407dd50a ]--- -
Really? Never heard about such an issue. My Main Use ist Simple IP TV Plugin in Kodi, and when this works, i am satisfied. I think my DSL 16.000 is the limiting factor here? Should i use a USB Wifi Module in the meantime? Does this provide better performance? Cannot imagine. -
Ok. But Video Acceleration is the point for me, because i use it for Kodi Media Center. But for the moment, i can live without WLAN on this box, i can use LAN cable. Can i get video acceleration working on a newer Kernel, for example if i compile some librarys or other stuff? Regards, Chris. -
This verision is marked as stable from the Armbian Download Section. -
Validated yesterday on three different installs. Wifi is not working. Used Distro: Armbian Xenial desktop legacy kernel 3.4.y chrissie@bananapipro:~$ uname -a Linux bananapipro 3.4.113-sun7i #16 SMP PREEMPT Wed Jan 24 19:20:59 CET 2018 armv7l armv7l armv7l GNU/Linux [ 130.524044] [ap6211] dhd_bus_devreset: WLAN ON [ 130.535651] [ap6211] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin [ 130.541328] [ap6211] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt [ 130.548074] [ap6211] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin [ 130.802082] [ap6211] bcmsdh_set_irq Flag = 1 [ 130.805963] [ap6211] dhd_bus_devreset: WLAN ON DONE [ 132.783597] usb 5-1.3.1: reset low-speed USB device number 12 using sw-ohci [ 132.803123] [ap6211] dhdcdc_query_ioctl: dhdcdc_msg failed w/status -5 [ 132.808893] [ap6211] dhd_preinit_ioctls: can't get MAC address , error=-5 [ 134.813126] [ap6211] dhdcdc_set_ioctl: dhdcdc_msg failed w/status -110 [ 134.819848] [ap6211] dhd_check_hang: Event HANG send up due to re=0 te=2 e=-110 s=2 [ 134.828381] [ap6211] bcmsdh_set_irq Flag = 0 [ 134.832465] [ap6211] dhd_bus_devreset: WLAN OFF DONE [ 134.837648] [ap6211] Succeed to set the gpio ap6211_wl_regon to 0 [ 135.039727] [ap6211] WLAN placed in RESET [ 135.043599] [ap6211] dhd_open: failed with code -14 [ 135.047241] [ap6211] In : chip crash eventing [ 135.050892] ------------[ cut here ]------------ [ 135.057562] WARNING: at net/wireless/sme.c:744 cfg80211_disconnected+0xc0/0xc4() [ 135.059516] Modules linked in: cpufreq_userspace zram(C) zsmalloc(C) spidev mali ump ap6211 a20_tp 8021q garp stp llc sunxi_ir hidp rfcomm hci_uart bluetooth ppdev lp parport [ 135.080669] [<c001543c>] (unwind_backtrace+0x0/0x12c) from [<c0037108>] (warn_slowpath_common+0x54/0x64) [ 135.089070] [<c0037108>] (warn_slowpath_common+0x54/0x64) from [<c00371b4>] (warn_slowpath_null+0x1c/0x24) [ 135.097531] [<c00371b4>] (warn_slowpath_null+0x1c/0x24) from [<c07053f8>] (cfg80211_disconnected+0xc0/0xc4) [ 135.106831] [<c07053f8>] (cfg80211_disconnected+0xc0/0xc4) from [<bf1051a4>] (wl_cfg80211_hang+0x44/0xb4 [ap6211]) [ 135.115783] [<bf1051a4>] (wl_cfg80211_hang+0x44/0xb4 [ap6211]) from [<c004d048>] (process_one_work+0x138/0x3cc) [ 135.123740] [<c004d048>] (process_one_work+0x138/0x3cc) from [<c004d694>] (worker_thread+0x180/0x3c8) [ 135.135833] [<c004d694>] (worker_thread+0x180/0x3c8) from [<c00527f8>] (kthread+0x90/0x94) [ 135.142890] [<c00527f8>] (kthread+0x90/0x94) from [<c000f804>] (kernel_thread_exit+0x0/0x8) [ 135.146514] ---[ end trace f0624f4985e90226 ]--- [ 135.153069] cfg80211: Calling CRDA to update world regulatory domain What can i do? Thanks & regards, Chrissie.
